Page 11 of 12 FirstFirst ... 789101112 LastLast
Results 501 to 550 of 590
  1. #501
    Training for the Darwin's
    Reputation: Forster's Avatar
    Sep 2013
    Quote Originally Posted by ncruz408 View Post
    Sweet bikes everyone. Limey Johnson, that marlin looks sharp in that color. I was skeptical at first when I first saw it but yours looks sweet! Are those stock handlebars? I am thinking about swapping mine out but not sure what to get. It feels to wide for me and I notice my forearms hurt after a ride. I know I can cut it but wanted to know if it would be better to swap it out for more comfort and also to shed some weight. Any recommendations anyone?
    ncruz, I've got a '11 Paragon (Stealth Grey Paint Job) that came with the somewhat maligned 17 degree big sweep bars. I cut mine to fit my perception of what works and would recommend you consider cutting yours before buying replacements (even if you are buying replacements anyway) to see what you like (width wise). If you cut your stock bars too narrow, you can fix that with the planned replacement, if you cut your replacement bars too narrow you're buying a third set. I'm a big believer in my bars supporting a "neutral wrist" position where the wrist is neither turned inward or outward and where the wrist is not bent with fingers on the controls (in your primary riding position you should be able to lay a flat edge (ruler) along the forearm and back of the hand and approximate a straight line. I've used risers and non-risers, always with at least 10 degrees of sweep.
    The most expensive bike in the world is still cheaper than the cheapest open heart surgery.
  2. #502
    Mar 2012
    A little late to reply to this, but when I switched from my 3x10 to XX1, my bike dropped a little over 800 grams.
    Quote Originally Posted by HawkGX View Post
    What do you figure your weight savings was with your 1x10 conversion? I still have the stock triple and cogset on my 2013 Mamba, but I'm never in the small ring. Was considering a switch to either a double or single ring crank.
  3. #503
    Reputation: DethWshBkr's Avatar
    All changes are to make it more my style, not for a performance upgrade necessarily, although the brakes are major upgrades.
    X9 rear derailleur
    X0 gripshift
    Hope Tech3 E4 front brake, Tech 3 X2 rear brake
    203mm rotors front and rear
    XR4 front tire
    I did dump the large ring, since I am not nearly strong enough to need it. Added a RaceFace bash guard.
    Otherwise stock. I tried the triggers, just could not get used to them, so I had to go with a Sram rear derailleur. I have always liked gripshift. The shifters are 3x10, even though I did remove the large ring. If I find I eventually need the large ring, I will toss it on, and can still use the shifters!
    After that, the Shimano brakes would NOT fit in a safe manner (I figured they woulnd't) so I was going to get a set of Hayes Prime experts, but instead decided to splurge on the brakes with large rotors.
    I LOVE the XR4 tire on my 26" Fuel EX9, so I knew I wanted that tire up front.
  4. #504
    Reputation: trey_sd's Avatar
    Mar 2013
    2013 Superfly 100 AL Elite
    It's stock except tubeless tires and Shimano MD's
  5. #505
    Mar 2013
    Nice rig man. Very clean looking
  6. #506
    Reputation: akaBrowntown's Avatar
    Nov 2012
    New commuter/rehab bike - broke my leg a month ago trail riding. Scored it rediculous cheap and have a rigid fork and super moto tires on the way. Dont dig road bikes, and a 29er will be way cooler.
    Potato pic of stock Wahoo.
  7. #507
    Apr 2014
    trek wahoo from belgium
    Trek 29er's roll call-1475844_10151976988928961_1457766353_n.jpgTrek 29er's roll call-65198_10151677187523961_941795570_n.jpg
    hello
    this is my wahoo
    fork reba
    xt-slx
    ztr crest
    seatpost vannicholas titanium
  8. #508
    Nov 2012
    Funny you posted the second pic haha, we will have similar builds. Are they Big Apples? Looks like it - I have some Super Motos on the way and a carbon fork. With slx crank, narrow wide and xtr rear mech.
    Here is the best phone pic - its without BB now. All the parts are trickling in this week. Really stoked.
  9. #509
    Feb 2013
    Looking to put beefier tires on my 13 Superfly AL! Kind of curious what everyone else running on their bikes? Thanks
    SWING YOUR LEG OVER IT AND PEDAL
  10. #510
    Mar 2013
    I'm using conti xkings. They aren't s beefy as maxxis ardents, or bontrager tr's, but they are like Velcro on the trail. Anything is better than the tires that came on my SF elite. Garbage !!!
  11. #511
    Quote Originally Posted by Bryan1113 View Post
    I have the same bike and immediately upgraded to the bontrager's 29-3 team issue tires (the shop I go to only carries Trek stuff so I'm not familiar with other brands so much). But I love the 3s (I think they've been renamed XR3 now). I live in New England so rocky, rooty trails but these tires are still great in wet and dry conditions and absolutely rail turns. But as always, I recommend talking to your LBS and seeing what they feel is best.
  12. #512
    29ers Forever
    Reputation: CannondaleF9's Avatar
    Nov 2012
    Quote Originally Posted by trey_sd View Post
    I am using Schwalbe Hans Dampf 2.35s on my Cobia.
  13. #513
    Mar 2013
    It's all about where you live and trail conditions. I'm in AL and it's humid and the trails are super dry. So the contis are perfect for me. So like Kevin said, hit up your LBS
  14. #514
    J79
    J79 is offline
    Oct 2012
    I'm running Michelin Wildgripper 29x2.25 on mine...
    Had a good test with them in Austria last week...
    Attached Thumbnails Attached Thumbnails Trek 29er's roll call-oostenrijk7.jpg
  15. #515
    Oct 2013
    My LBS sells a lot of Maxxis Ignitors, so I have taken their advice and run them on my Superfly FS 9. I'm no expert, but I like them for leafy, rooty, rocky terrain. It came with Bontrager XR1 Team Issue, which work well for me with dry, packed dirt and gravel.
    2014 Trek Superfly FS 9; 2013 Trek Domane 4.5
  16. #516
    Reputation: coling's Avatar
    Mine aren't really beefier but I love them for my XC Pacific NW riding. I run Specialized S-Works Ground Control 2.1 front and back.
    Although this season I'm thinking of swapping the rear for a Maxxis but I can't decide which.
    GO COUGS
    GO HAWKS
  17. #517
    Feb 2013
    I live in So Cal desert area! Dry, rocky conditions...LBS steering me into Trail King direction so just checking to see what everyone else rolling with! Thanks for feedback
  18. #518
    Apr 2014
    I'm riding a completely stock 2011 Marlin, got it and love it! Now, thanks to all of ya'll on mtbr, I have the upgrade bug. Any ideas for some "must" upgrades? Btw I live in New Orleans and ride muddy trails since it rains constantly.
  19. #519
    Mar 2013
    Wheels and tubeless setup
  20. #520
    Mar 2013
    A fork
  21. #521
    Apr 2014
    Any suggestions on wheels and tires? I've heard a lot of good things about hope hubs but have no idea about tires at all.
  22. #522
    Just picked up an X-Caliber 6. Haven't been on a bike since 2007 and haven't been on a hard tail since 2009. Have about 40miles on it so far and it's been interesting. Wasn't sure what to expect from it being low spec, I've never owned such a low spec bike but finances right now won't allow anything nicer. Let's see how long I can keep this one for.
  23. #523
    Reputation: Sickmak90's Avatar
    May 2012
    Just picked up this 2013 x-cal. Liking it so far!Trek 29er's roll call-imageuploadedbytapatalk1399000553.050887.jpg
  24. #524
    Mar 2013
    Conti's alllll day
  25. #525
    Mar 2013
    Quote Originally Posted by dlafleur View Post
    Anything Stan's is good. You can find them on eBay with tires and ready to roll for around $400. That's what I did on my other bike before I sold it.
  26. #526
    Mar 2013
    Quote Originally Posted by J79 View Post
    Where did you get that jersey ?
  27. #527
    J79
    J79 is offline
    Oct 2012
  28. #528
    Dirt, Sweat and Gears
    Reputation: Tomahawk3Niner's Avatar
    Feb 2014
    Re: Trek 29er's roll call
    X Cal 7 out playing in the rocks.
    Noob on a 2014 Trek X-Caliber 7
    Dirt, Sweat and Gears - my new outdoors blog
  29. #529
    Feb 2014
    Chris
    Seattle, Wa
    First 29er, Trek X-caliber 8
    I really enjoy the ride. Handles terrain really nice. Changed the saddle, specialized white pedals, added some fenders and Lizard skin grips (not seen).
    Mainly use it for XC, some downhill and moderate jumps.
    I like it
  30. #530
    Biocoug? When did you graduate? I was '09 and I'm in Renton. Is that silkworm behind you?
    GO COUGS
    GO HAWKS
  31. #531
    Feb 2014
    Quote Originally Posted by coling View Post
    Ha! small world man! I graduated in 07. That is Paradise Valley in Mill Creek/Woodinville. I just got my Trek couple months ago so I'm looking to get out to different spots. My normals are Des Moines Creek park, Paradise and Duthie.
    Go Cougs/Go Hawks my brother.
  32. #532
    A few of us are riding duchies this Saturday, be there around lunchtime if you want to ride. I'll be on a navy Rumblefish, buddy with a black remedy and other buddy on a red Yeti.
    GO COUGS
    GO HAWKS
  33. #533
    **Duthie
    GO COUGS
    GO HAWKS
  34. #534
    Mar 2013
    I've already posted here, but put an upgrade or two on my superfly. Conti xkings, and raceface 1x10 32t conversion. New pedals in the mail because I've destroyed my shimano md's.
  35. #535
    https://www.facebook.com/MountainBikesLeaningOnThings
    hahaha!!!
  36. #536
    Mar 2013
    Lol^^
  37. #537
    Reputation: Robg68's Avatar
    Oct 2013
    I got a killer deal on this new 2013 Trek Superfly 100AL 29er. Bought it for my wife for our Anniversary.
    My current bike--2014 Trek Fuel EX 8 29er.
  38. #538
    Oct 2012
    New Pony!
    2014 9.8 Superfly - 20.9lbs
    The only thing not stock are the Bars, Seatpost and Saddle.
    Swapped out to XXX and a Fizik Tundra w/carbon rails…
    Crankbros Pedals.
    Attached Thumbnails Attached Thumbnails Trek 29er's roll call-superfly-9.8a.jpg
  39. #539
    May 2014
    Trek Superfly 5!
  40. #540
    Oct 2013
    My Trek Fuel 8 29er and my wife's 2013 Trek Superfly AL 100. Took a nice ride today.
  41. #541
    Nov 2012
    Training rig.
  42. #542
    Got this 2013 Rumblefish late last year. First time on a 29er and I like it. Already have a few upgrades and I am waiting for more in the mail.
    Already installed are XT shifters, ENVE bar and seatpost, WTB Silverado saddle XTR cassette with Wolftooth 42tooth cog and ODI XTrainer grips, and I converted to tubeless.
    Waiting for I9/Stans Arch wheels, Race Face 30tooth NW ring, XTR crank and XTR rear derailleur.
    My fork was part of the recall, and I have a few rides on the new damper, and I must say it is a world of difference. CTD actually does something, and I get just about full travel, still dialing the pressure.
  43. #543
    Reputation: Wisconsinite762's Avatar
    May 2014
    2013 Trek Marlin
    Owner: Cody
    Bike/Setup: 2013 Trek Marlin - Stock except for the pedals and gel seat cover
    How long have you owned it: 2 Days
    Thoughts so far: Haven't taken it to a trail yet, so I am not sure how it will ride. But I took it for a 30 mile road cruise today and it performed better than expected!
    Cons so far: The brakes suck, definitely need to upgrade.
  44. #544
    My hard tail is a 2011 Cobia, my full suspension is a 2013 Super Fly AL 100. Have only took the SF on 2 rides but I am well pleased with it. At my age the suspension sure does make a big difference, I'm almost 56 years young.
  45. #545
    Oct 2013
    Trek Stache 7, all stock except. Bontrager Tublees tires Team issue. For the price, this is one heck of a bike!
    • Trek Stache
    • Giant XTC
    • BMX
  46. #546
    Aug 2010
    Finally done upgrading my Stache, love the way this thing rides, now all that's left is for me to continue to get faster
    Trek 29er's roll call-20140611_215920.jpgTrek 29er's roll call-20140612_205044.jpgTrek 29er's roll call-20140612_205055.jpgTrek 29er's roll call-20140612_205107.jpg
    -Spank Oozy Trail295 Bead Bite Wheelset
    -KS Lev 150 routed through my old fd internal routing
    -Ice Tech rotors and pads
    -70mm Rhythm Pro stem and 750mm Rhythm Pro carbon bar
    -XT chain and cassette
    -Saint rd and shifter
    -Race Face 30t narrow wide chainring
    Just under 26 lbs
  47. #547
    Jun 2014
    New X-Cal 8 in the house.
    Http://www.cordslash.com
    Trek X-Caliber 8 w/ tasteless mods
  48. #548
    Jun 2014
    Quote Originally Posted by Scishfottman View Post
    What pedals are those? Thanks-
  49. #549
    Jun 2014
    Quote Originally Posted by Mapcinq View Post
    Deity Decoy. Purple makes you go faster.
  50. #550
    Jun 2014
    Thanks.. I just bought the same bike, really like the purple you put on it.
  1. Re-Roll Call
    By motobutane in forum Southeast/Midsouth - GA, TN, AL, FL, MS, LA, AR
    Last Post: 09-03-2010, 05:17 AM
  2. P36 Roll-call!
    By pisgahproductions in forum North & South Carolina
    Last Post: 02-13-2010, 07:27 AM
  3. Frostbike Roll Call - Who's Coming and Call to Action
    By Salsa Cycles in forum 29er Bikes
    Last Post: 02-15-2008, 08:44 AM
  4. Roll Call
    By sarge12 in forum Midwest - IL, IN, OH, KY, IA, MO, MI
    Last Post: 07-06-2005, 01:13 PM
  5. SS Roll Call
    By mergs in forum New York - New Jersey
    Last Post: 12-01-2004, 12:10 PM
