Results 1 to 81 of 81
    Weiner Dog Connoiseur
    Reputation: SaxMan's Avatar
    May 2005
    Strangest Klein Pulse I've Seen
    http://cgi.ebay.com/1997-Klein-Pulse...QQcmdZViewItem
    I'd say the tubing looks a little thin to be a Klein...and the "internal cables" are routed on the outside?
    By '97 the Klein Pulse was a Trek-built frame with banjo-type cabling over the top tube. I'd venture a guess that this is probably not a Klein.
    Mantis, Paramount, Campy
    Reputation: Shayne's Avatar
    Looks Thin 'Cause Its Steel
    Deffinately not a Klein Pulse in any way, shape, or form.
    No good in rock gardens..
    Reputation: Sideknob's Avatar
    What a scammer.
    Clearly a choromoly bike with a threaded headset to boot.
    I just HAD to ask:
    Hi there. Are you sure this bike is a Klein? It appears to have the cables running outside the frame - Kleins had them inside. It also appears to be a steel frame - Kleins are aluminium. A 1997 bike would also have a threadless, inch and an eighth head tube - your bike is one inch threaded by the looks.
    Less isn't MOAR
    monkey's throw poo
    huh?
    Quote Originally Posted by Sideknob
    What a scammer.
    I just HAD to ask:
    This Klein has Internal tubing very Light and Fast...what the hell does this mean?
    two six is bet-ta
    Righto. Here's the question I asked this guy:
    "Hi there. Are you sure this bike is a Klein? It appears to have the cables running outside the frame - Kleins had them inside. It also appears to be a steel frame - Kleins are aluminium. A 1997 bike would also have a threadless, inch and an eighth head tube - your bike is one inch threaded by the look."
    And here's the answer!
    "Yes it is a Klein Pulse.It is all aluminum frame,this is special made 4 racing down hill.thanks."
    So! A VALUABLE and RARE limited Klein Pulse special downhill racer!!
    Less isn't MOAR
    Hmmm
    That guy is semi-local to me.
    I should borrow my buddy's Pulse II and ride over there to check that bike out in person and see what he has to say then.
    I better check my Pinnacle to see if it's one of them special downhill models.
    Less isn't MOAR
    God someone's bid $152 on it. And $67 postage on top!
    Most expensive lemon I've ever seen.
    Less isn't MOAR
    The Machine Is Forever
    Reputation: The Machine's Avatar
    Mar 2005
    I seriously doubt that is a '97 Klein Pulse frame....
    Here are three pics of a circa 1995 Klein Pulse frame that I happened to spot on eBay. You can clearly see the internal cable routing already in place, with the more customary Klein tubing.
    He be a moose too.
    Reputation: pinguwin's Avatar
    Didn't sell
    The reserved wasn't reached. For cripes sakes, if you're scamming someone, you don't set a reserve. You take the money and run...fast! Perhaps this person really believed they had a Klein?
    I sent a message to the two highest bidders and pointed them out to this thread. One said something seemed fishy, the other was surprised he could have been fooled.
    I told him that a lot of people didn't groove on people exploiting someone regarding older Kleins, but if it had been a Cannondale scam...eh, who cares.
    Penguin
    Mar 2005
    Quote Originally Posted by pinguwin
    Penguin
    There was just too much that was too obvious. From the frame tubing to the component spec, it just SCREAMED "scam"...
    What I found hilarious was when the seller stated in an earlier post to "Sideknob" that the bike was "especially made for racing downhill". I guess the seller thinks he's John Tomac, too
    Quote Originally Posted by The Machine
    Nah, no Tioga Tension Disc in sight......
    Less isn't MOAR
    Reputation: lebikerboy's Avatar
    Jan 2005
    You can spot a Klein right away by the "micro" rear entry dropouts.
    This bike is crap.
    CoroKatana
    Mar 2006
    "Crap" is an understatement....
    It's a real POS. And the guy is a J@ckass for scamming.
    While we're scrutinizing for discrepancies, check out the chainstays on the Silver Pulse pics. I've owned 5 Kleins over a 15 year period, and IMO, the square-to-circular chainstay design still remains one of the sexiest frame details ever .
    ...I guess the "special downhill frame" used conventional chainstays with off-the-shelf dropouts complete with braze-ons for a bike rack.
    Yep...that guy's selling one special Klein all right.
    Up to $152 now.
    Less isn't MOAR
    Mar 2005
    Up to $152 now.
    It seems that the bidding has ended for that auction...boy, I hope the poor guy who bid the $152 looked elsewhere for his rig.
    However, that frame looks eerily similar to a steel 1996 Specialized Hardrock. I have one of those bikes as a beater, and if you remove the clearcoat and decals, you'd have a dead ringer right down to the dropouts for that "Klein-terfeit"
    He be a moose too.
    It didn't reach reserve and the two high bidders, once alerted, weren't going any higher.
    Penguin
    He be a moose too.
    It's back and even better than before!
    Yep, "Klein Pulse" has made a return and it's even better than before. This time it even says "Klein Pulse" on it. It wasn't there on the first posting but it's there now. It says it's a Pulse, so who are we to pontificate, arrogantly pontificate, and say, "It's not a Pulse."
    Previously, one could (I say could, it's a stretch, but work with me) have come to the conclusion that it was an ignorant seller. Now it's blown way past that into outright fraud. The least the guy could do is to try a little harder, you know, honor among thieves sort of thing.
    Heh-heh.
    Penguin
    Now the bike is relisted, and it magically has Klein logos on the frame.
    Check it out:
    May 2005
    Quote Originally Posted by john2006
    Check it out:
    That would be like me scrawling "Hummer" logos on my Toyota 4Runner and trying to pass it off as a Hummer...of course, in my case, that would be a step backwards (we're talking about the H2 & H3).
    Reputation: noslogan's Avatar
    Check it out now
    The seller had to create a NEW account in order to buy it over the reserve.
    When it pops up again it may be the new seller auctiobid12345.
    John2006,
    What a cowinkadink. You are from the same state as the seller. Go knock on his door and crack his aggies.
    He is in Little Chute.
    Mar 2005
    Heh-heh.
    Penguin
    Aaaah, our favorite "Klein-terfeit" is back....superb
    Has anyone reported that clown to eBay yet?
    No, he's definately legit, he owns a bike shop too... he said so.
    and to quote him, when I decided to question his bike...
    Yes,It sure is a Klein,Look at the other Klein Pulse mountain bike on ebay.Its a Klein Pulse Comp.Thanks.Clint S.I own a bike shop.
    May 2005
    the sudden appearance of the klein stickers is hilarious
    what a piece of crapp this guy is
    i would never buy a bike on ebay
    a friend of mine made 3 attempts to buy a used trek fuel on ebay, and each time it turned out to be a scam
    he would get "outbid" at the last minute, then get this email message in broken english telling him that he could still get the bike at his last bid price - all he had to do was send his money to a listed addresss, and they would send the bike right to him
    he finally picked up a demo model at the lbs for cheap, and is very happy with it
    you just can't beat having the opportunity to actually look at the bike you are buying
    clunger
    He be a moose too.
    Yeah, I did last night. Don't know what they do afterwards, but due to privacy regs, I doubt they would tell anyone anything they do.
    'Guin
    That guy
    That guy is a nascar goob.
    I am extremely sorry if I offended any true goobs that detest nascar.
    Me, I like a little nascar now and then.
    Mar 2005
    Quote Originally Posted by clunger
    Looks like he "outbid" himself again
    Who knows? Maybe next time, he'll remember to put the word "Comp" on the bike
    Reputation: kenjihara's Avatar
    Mar 2006
    The stem says 'Spectre'... my recollection is that Spectre was the in-house / OEM equipment name for Jamis parts, so that's probably a very early 90's Jamis. Dunno' why he'd have to scam on the name, early Jamis bikes were pretty good. Looking at the lug-thingy at the seatpost clamp area, it definitly looks like an old Jamis frame.
    He be a moose too.
    Klein Pulse...the Return Pt. III
    Yep...it's back! Not once, not twice, but it's back for the third time.
    'Guin
    Mar 2005
    'Guin
    This bike is starting to become like one of those bugs that you just can't kill
    ...and once again, he lists it as a "downhill racer"
    So, I guess THIS time, he chose to spiffy the bike up and hang it in a garage with other bikes to make his "bike-shop-owner" claim legit (as well as to make the "Klein-terfeit" look authentic as well)
    Some people just never learn
    He be a moose too.
    Well, he spiffed up the background to give it that authentic feel, but the pictures are all kind of fuzzed...that way it's harder to see that it's not what it's supposed to be.
    Hey, you have to give him credit. He is trying.
    'Guin
    Mar 2005
    'Guin
    I will admit...his persistence is admirable
    Imagine how much he could sell if his items were actually legitimate
    monkey's throw poo
    stopped
    i contacted klein/trek and they're looking into it.....
    two six is bet-ta
    Mar 2006
    What's funny is that it's probably a Jamis, and a vintage Jamis wouldn't be too bad. If he took the Klein sticker off and put on a Jamis sticker nobody would be bothering him at all. Why try to sell it as a Klein? Older steel bikes are damn nice. All he'd have to do is re-sticker it as a Jamis Dakota or Dakar and he'd fall off our radar entirely and have a (semi) legit auction on his hands. Duh.
    Spectre was the house brand parts for Jamis- the bike has Spectre stem and bar. Seat post clamp detail pretty much confirms that it's a Jamis. He's got a halfway decent bike on his hands, he's just ignorantly passing it off as something else. My boss at the shop I used to work at had one of the early 90's Jamis Dakars, and it was a great hardtail.
    Mar 2006
    ...So I emailed the guy, told him that he had a Jamis, not a Klein, politely explained that a Jamis was a pretty good bike and that he should just sell it as a Jamis. That would get us off his back, make his auction legit, etc.
    He sent back this message:
    "YA SURE,GET A REAL BIKE.I OWN 100,S OF THEM."
    I think he must be retarded.
    Mar 2006
    Check out some of his past auctions:
    http://cgi.ebay.com/ws/eBayISAPI.dll...tem=7228993057
    Sold a Gary Fisher Marlin for $320 plus 67.40 shipping. Check out the description:
    Hi,,Up 4 Auction is my,2005 Gary Fisher 18inch Marlin,Gold Series all Aluminum 24 Speed Genesis Frame Mountain Racing Bike,This bike has,Extra Big tubing on top and down end tubes,Bike weighs only 22 pounds,It has Disc set up,!.It has Tektro brakes,with Kalloy stem and Ritchey force Lite 2014 T6 180gms Aluminum handlebars,with Roost bar ends,Shimano speed shifters and Shimano Deore rear and front deraillers,Bontrager Sport crank spocket and arms,Race Pedals,Bontrager sport seat post,with Select Cro-mo rails and racing saddle,Heavy Duty Axel Manitou racing fork with lockouts,WTB Duel Duty 6061 Rims with Shimano Parallax sealed Hubs,with Jones XR 26x2.20 Bontrager racing tires,I,m selling at a,(,LOW RESERVE,).If ya have any questions,Just ask me,Thank you,
    You've got to love that 22 lb weight and the 'disc setup'.
    Not to mention the feedback he got:
    Poor communication, item was sent incomplete, would not resolve. Never again!
    Mar 2006
    Mar 2006
    Look at the kind of stuff he buys:
    http://cgi.ebay.com/ws/eBayISAPI.dll...tem=7217114498
    Mar 2006
    In fact, a lot of what he buys is bike decals. Suspicious?
    You buy alot of decals from me,and its always great and no problems. A+A+A+A+A+
    Seller rideviciouscycle ( 83)
    Dabney Coleman
    Let's see if we can get him interested... here's a copy of the email I just sent him.
    Hi, I'm interested in bidding on your Klein, but can you give me some history behind it? Where did you get it? How much has it been ridden? What size is it?
    Thanks so much for your time!
    -Fred
    (Fred's not really my name, but hey, anyone bidding on this is probably named Fred anyway, right?)
    Mar 2006
    Quote Originally Posted by floatch
    -Fred
    That's hilarious; you're the man.
    Dabney Coleman
    Okay guys, he's bitten. Here's his response, copied and pasted. The CAPS are all his. I guess I could have guessed his response would be in all capital letters.
    HI,FRED,IT WAS MY FRIENDS,HE OWNED ME MONEY,ABOUT 300 MILES IT WAS RIDDEN,SIZE LARGE,THANKS,CLINT,
    So, in which direction shall we take this? I must reply, that much is certain. What should I say?
    Mar 2005
    Have we stumbled on to something bigger here?
    Quote Originally Posted by kenjihara
    Interesting.
    Now I'm starting to wonder if some of those bikes we see in the background were obtained via a five-finger discount
    That could explain his buying the decals to slap on some of those rides
    (My theory might be a reach...but it makes sense at the same time)
    He be a moose too.
    Gone, with a BIN!
    Ok, looks like auctionbid12345 (with feedback of -1, nope not a misprint, -1) has bought it with a buy-it-now.
    This is the same "bidder" who did a BIN for the last time the bike was on auction. Looks like he left the "bidder" i.e. himself, negative feedback yet still allowed the "bidder" to do a BIN again.
    The seller & auctionbid12345 must have had a reconciliation...I'm sure they shared a hug afterwards. I might add him to my favorite sellers and watch what other stuff comes out.
    Heh-heh.
    'Guin
    He be a moose too.
    It's Back!
    Coming at you once again, not once, not twice, not thrice, not...ah..not...err, what would be the fourth time?
    http://cgi.ebay.com/ws/eBayISAPI.dll...MEWA%3AIT&rd=1
    The Machine, you're right, it is like one those bugs that just keeps coming back or perhaps it's like the picture.
    'Guin
    Mar 2005
    'Guin
    I was wondering when someone would post a pic of the Energizer Bunny
    As crazy as this may sound, I'm actually looking FORWARD to seeing what the "Klein Con" comes up with next
    Mar 2006
    http://cgi.ebay.com/ws/eBayISAPI.dll...Pr4_PcY_BIN_IT
    Once again. How much do you suppose the listing and the ebay fees are on this bike by now? He pays for the extra photos, the reserve price, and the buy it now, lists it five times... think about it. I remember that ebay charged kind of a lot for that, plus the final sale fee which is based on a percentage... He could've saved himself a lot of money just by listing it as a vintage Jamis. Hell, I like Jamis bikes. What a dip.
    Mar 2006
    Wow, now he's only accepting check or money order. That's not a red flag right there or anything.
    Mar 2006
    I added this nut to my favorite sellers, so I can keep tabs on him. I just find him to be infinitely entertaining.
    He be a moose too.
    Maybe someone else is...
    Hey, maybe there is a white knight out there. Instead of blabbing wildly like us, auctionbid12345 bid on the bike and left negative feedback. So it doesn't look like auctionbid is something the seller set up.
    http://feedback.ebay.com/ws/eBayISAP...521093&frm=284
    I wonder if the bidders on his other auction should be notified, hmmmm.....
    'Guin
    Mar 2005
    Looks like his name is "mtnbiker6789" now
    Looking at all of the other bikes this guy has, I can't help but wonder if this is just the tip of the iceberg to something much bigger (like a bunch of stolen bikes)
    The purchasing of decals...the request for ONLY a check or money order...
    All of this is way too suspicious not to think otherwise
    Maybe "auctionbid12345" is either someone who's been scammed by this guy or someone who's wise to his scheme and is looking to "blow up his spot" (as we say here in NYC...LOL)
    Dabney Coleman
    Here's another of his auctions, just for fun. Nasty trend indeed! Look at that seatpost! The paint! The 80's horror!
    This bike makes me want to claw my eyes out.
    He be a moose too.
    Seems like this guy now has two "Kleins" for sale.
    Not one, but two "Kleins" are for sale. One is being bid on by a zero feedback buyer, so seems like someone is messing with him again. Heh-heh....
    Guin
    SS Pusher Man
    Reputation: mtnbikej's Avatar
    Sep 2001
    Guin
    Yeah, well check out this one he sold a while back:
    http://cgi1.ebay.com/aw-cgi/eBayISAP...tem=7228993057
    GF Marlin.......weighs only 22 lbs.....RIGHT?!?!?!
    Mar 2006
    I don't get it... how does this guy think he's going to make any money, after fees? He's insane!!
    Mar 2005
    I think one look at that "Klein-terfeit", and we can see just how insane he is
    This guy has bikes coming out the wazoo. I'm surprised that eBay hasn't shut this boob down, especially after that first bike...geez, what an obvious scam that is.
    He be a moose too.
    Aw, you gotta give him credit for persistence
    Yep, it's back and it's no longer a Pulse, but a Pulse Comp. He's given all new decals and taken new pictures of it. It's no longer "fast and light" rather it's now "This klein was special made". That's a good word for that bike: Special.
    Yep, give him credit for persistence and that indefatigable spirit of trying something new when the situation warrants it.
    Penguin
    Mar 2005
    Penguin
    LMAO @ the $9.95 bid posted
    Yes....his persistence is admirable, but futile.
    Oh, well
    May 2005
    Oh, well
    Man, it's like the guy is doing it just to entertain us. What's next? Will it become a Klein Attitude with the work ATTITUDE stretching from the seatpost to the headset. Maybe if I put the words "GERMAN SHEPHERD" on my miniature dachshund I can pass him off as one.
    Mar 2005
    Quote Originally Posted by SaxMan
    Funny you mention that...
    I'm thinking maybe...just maybe...he's getting ideas just by reading this thread. I noticed that as soon as we discussed the omission of the word "Comp" from the bike, lo and behold, there it is a few days later
    I wouldn't be surprised to see the word "ATTITUDE" on that bike sooner or later, as you mentioned
    I guess the irony of this whole thing is that this guy HAS to know that people are on to his scam, and yet, he continues to try to bag (or may have already bagged) someone with that garbage.
    He be a moose too.
    There is a thread about this bike in VRC:
    Vintage Klein on ebay
    A few people there have reported this fraud to ebay, I've reported him twice, yet he still is out there. I'm not impressed at ebay at all. I guess they're so busy keeping our buying experience safe that they don't have time do deal with fraud (or something like that).
    Penguin
    Reputation: Clyde Sdale's Avatar
    Mar 2006
    Wow! Just reading this thread now. You know, I would never have picked up on the Klein Pulse fakaroony. What jumped out at me was the the fork. No way in hell was that fork put on any bike in 1997. 1" steer tube, threaded, 1.5" of good old elastomer travel. My brother had a '92 Stumpjumper S-Works hardtail with a Manitou III fork on the front. Jumping on the handlebar you were lucky to get 3" of travel on that thing. It was way more sophisticated than that Manitou fork pictured. Aside from it not being a Klein, no way was that made after '93. Can you cough and say rip off at the same time???
    the person stole the description
    the auction has almost the same description
    http://cgi.ebay.com/ws/eBayISAPI.dll...DME:L:RTQ:US:1
    Same guy! He keeps putting it up and keeps buying it himself. Apparently he is changing his buyers name now.
    He be a moose too.
    Quote Originally Posted by narf1997
    It is the same bike. Read some of the other posts and you'll see where it went from a Pulse without stickers -> pulse with pulse stickers -> pulse comp
    That's what so funny about this. I see it's got a bid on it, suppose I have to warn this bidder like I have the rest.
    'Guin
  67. #67
    monkey's throw poo
    this guy is full of shXt
    http://cgi.ebay.com/ws/eBayISAPI.dll...Pr4_PcY_BID_IT
    his other auctions, last i knew in 2004 fisher was with Subaru, back in 2001 they were with Saab. someone needs to stop this guy....
    two six is bet-ta
  68. #68
    Reputation: revmonkey's Avatar
    Jun 2005
  69. #69
    gbnemba.org
    Reputation: Chris_T's Avatar
    Feb 2005
    Didja notice that all the photos have the same date superimposed on them? Even photos with two different sticker styles? I think he's Photoshopping the stickers onto the frame.
    The GF Saab was available with the purchase of the 2000 Saab 9-5 Gary Fisher wagon. No way it's a 2004.
    -C
  70. #70
    Jun 2005
    HAHA, you may be right, as in the newest auction, the decals are different from the previous auctions!
  71. #71
    gbnemba.org
    Feb 2005
    I'm having great fun with this guy now. I've notified the bidders that this is a fake (pointing them to this thread) and telling him that we're on to him. He says "No.We are on 2 you.Air-Head"
    Too funny. I also told him to get eBay after me so they could check this whole thing out.
    -C
  72. #72
    He be a moose too.
    I've been notifying bidders also.
    I don't think it's a photoshop job. If it is, it's pretty skillful. The reason I say that is that the perspective is reasonably good. View it from different angle the letters look different, they wrap around the tubes, shading, disappear behind the brake levers, etc.
    I do a little work with photoshop and I think this would take a reasonable amount of time to do. Much easier to get some stickers and paste them. If he was photoshopping, I would take some pleasure in knowing he spent a lot of time to sell a bike that wouldn't sell for more than several hundred dollars if it was legit in the first place.
    'Guin
  73. #73
    Quote Originally Posted by Chris_T
    -C
    Im thinking his camera has a dead battery and defaulting to the old date each time it is turned on. This b00b isn't smart enough to use photoshop. If he were, the klein stickers would have the right graphics.
  74. #74
    gbnemba.org
    Feb 2005
    Quote Originally Posted by skifastchad
    When was the last time you were able to take a picture with a camera with a dead battery :-)
    -C
  75. #75
    Mar 2006
    Um, how about he replaced the battery and never set the date? Don't worry skifastchad, we know what you meant.
  76. #76
    May 2005
    Hmmmm.....it's been kind of quiet from our favorite Klein Pulse seller...too quiet! I wonder if he either a) foisted the bike off on an unsuspecting individual or b) got tired of being constantly smacked down or c) out buying decals to change the bike into another brand.
  77. #77
    He be a moose too.
    I think he has learned his lesson. Take a look at this:
    http://cgi.ebay.com/2-Huffy-1977-Huf...QQcmdZViewItem
    He does come out and tell you what it is he is selling and I doubt it's fake. However, one has to wonder about the $144 for shipping.
    'Guin
    P.S. Oh wait, I just noticed he set a reserve. This is bizarre.
  78. #78
    May 2005
    'Guin
    Well, those Huffys did weigh a ton. That bike is probably well over 40 pounds. It could be a "special vintage rigid fork freeride bike".
  79. #79
    Reputation: YETI_Chris's Avatar
    Smile That dude is Nuts
    Hi every1 new here but a klein owner for over 10 years, This tread is so funny that i had to sign up for. That By far is NO Klein what so ever just like every one says.. I will be looking out for that dude as well from now on to make sure he gets cought by the ebay police LOL Klein has only use stickers on the pulse comp bikes and the pulse pro got a paint on from klein them selfs.
    I use to work in a shop on Nyc that we sold the most in so i have some know how's of what klein did the the 90's
    Later
  80. #80
    May 2005
    UPDATE:
    Seems like we chased our friend who listed the bogus Klein away. He is "no longer a registered user" within eBay. Hopefully, he won't resurface under another pseudonym.
    Score one for the good guys!
  81. #81
    Yahoo this is great news. I hope some one did not buy it!!!
