Results 1 to 5 of 5
    Stache Closed Convert axle indexing?
    Morning all- I just picked up my Stache 8 last night and took it for a quick ride. Love it! My question is this- can you index the rear QR somehow like you can on the Fox QR15 fork? When properly tensioned and closed, the QR hangs down between 6 and 7 o'clock, making it really vulnerable to branches and rocks. I could not see any other adjustments. Maybe a super thin shim on the brake side of the axle? At least this would tension it earlier so it pointed back at 3 or 4 o'clock.
    Thanks in advance for any help or suggestions.
    Reputation: bigkat273's Avatar
    Re: Stache Closed Convert axle indexing?
    Hex key on the lever side will snug up the tension. Had to tighten mine once as the axle rattled loose.
    Here is the thing about equality, everyone's equal when they're dead. - Gavroche, Les MisÚrables
    Step 1 - Tighten it down
    Step 2 - Hex key in Drive Side to hold the axle in place
    Step 3 - Hex key on brake side and loosen (keep the hex on the drive side still)
    Step 4 - Rotate your lever to wherever you want it when the axle is tight (I set mine to the 1 o'clock position)
    Step 5 - Tighten back down.
    BTW - It's the same for other Trek axles as well.
    Muchas Gracias!
    Jun 2013
    Quote Originally Posted by bigkat273 View Post
    I had the same issue the other day. Trek store said it happens frequently on these wheels. Check your QR's before each ride and pay attention while on the ride. Mine came loose while riding.
    Still looking for mountains in Florida
  1. Really??! Can't convert Shimano hub 15mm thru axle to 9mm QR?
    By ewarnerusa in forum Wheels and Tires
    Last Post: 10-12-2015, 08:00 AM
  2. question about thru axle on Trek Stache hardtail
    By hord1080 in forum Bike and Frame discussion
    Last Post: 06-04-2015, 10:36 AM
  3. Stache 8 rear axle issue
    By jcerion929rr in forum 29er Bikes
    Last Post: 04-26-2013, 05:48 PM
  4. 142mm rear axle convert to 135 QR?
    By WVJon75 in forum 29er Components
    Last Post: 12-03-2012, 02:27 PM
  5. Looking for help trying to convert my QR to a standard axle
    By Yeti Clyde in forum Wheels and Tires
    Last Post: 12-09-2011, 03:16 PM
