Results 1 to 7 of 7
    Mar 2013
    New question here. Stache 7 Brake size/ spec question. Noob......
    I am looking to switch out the brakes on my 2013 Stache 7. Looking to swap out the Avid brakes for the SLX. My only questions is I'm not sure what the spec/size is for the mounting options on my bike (i.s., 51mm, 74mm) I a noob with this stuff and have no idea what means what, just want to make sure I order the correct size for my bike. Thanks guys/gals
    I hate that name.
    Reputation: blunderbuss's Avatar
    The frame and fork are both 74mm post mount. Shimano brakes don't come with caliper adapters, so if you want to stick with the 180 front, you'll need to get one of those too. Shimano calls it F180P/P2. Since the frame is post mount also, no adapter is needed for the 160.
    Worked at Trek/Fisher dealer 2008-2013. Only a little biased.
    Mar 2013
    Thank you very much for the info. Just what I needed to know.
    Recommend getting the Ice Tech rotors...
    I hate that name.
    Agreed.
    When I switched from Elixer 5 brakes to SLX on my Fuel I just used whatever bolts/hardware/adaptors from my Elixer brakes. I have Avid rotors stock and also used those. I beleive my front rotor is 185mm and rear 160mm. I had zero issues. I only had to shorten my brakes lines.
    2017 Santa Cruz Tallboy CC
    Oct 2013
    How have the brakes held? Thinking if keeping the rotors and changing to SLX brakes.
    Quote Originally Posted by stygz1 View Post
    • Trek Stache
    • Giant XTC
    • BMX
  1. Noob question about old brake levers
    By BowHopper in forum Brake Time
    Last Post: 08-30-2012, 09:32 AM
  2. Noob brake adjustment question after new rotors...
    By madsedan in forum Brake Time
    Last Post: 11-11-2011, 05:26 PM
  3. Spec Pitch comp size question?
    By atitagain in forum All Mountain
    Last Post: 08-10-2011, 03:56 PM
  4. Noob Brake/Chain Question?
    By jacoboda in forum Beginner's Corner
    Last Post: 06-14-2011, 09:04 AM
  5. Another noob brake question...rubbing
    By jeffvb9 in forum Brake Time
    Last Post: 05-19-2011, 08:21 AM
