    Session 77 Suspension
    I got a Session 77 last spring. It is one of the best bikes I have ever had. Climbs amazing for it's size and goes down like no other. Use it as my all mountian bike. The bearing on drive side (seat stay to chain stay) Is no longer pressure fit in. When i took apart the linkgae the bearing falls out. The bearing seems fine no play and rolls smooth. Any one else had this problem or any suggestions?
    Reputation: FrankH's Avatar
    Mar 2006
    Looks like the same as my Liquid.
    You need some Loctite Bearing Retainer - I used #638. Clean the circumference of the bearing and the frame, scraping off any old residue and wipe down with some alcohol. Apply the Loctite, use a clamp to keep the bearing in place, and leave to set overnight before reassembling.
    use 680!
    Use 680 Loctite!
    It is curing as we speek. There was no good way to clamp it so I just put it back in the frame and set it back up so it could apply pressure.
