Results 1 to 5 of 5
    Aug 2014
    Rockshox Stealth Reberb, Can in Install the lever on the other side?
    I picked up a new Reverb Stealth with a left hand handle bar mount. The install was easy, but I prefer it on the right side. I installed it on the right side and it seems to work fine. Any issue doing this? See pictures below.
    Rockshox Stealth Reberb, Can in Install the lever on the other side?-reverb1.jpgRockshox Stealth Reberb, Can in Install the lever on the other side?-reverb2.jpgRockshox Stealth Reberb, Can in Install the lever on the other side?-reverb3.jpg
    R.I.P. DogFriend
    Reputation: jeffj's Avatar
    AFAIK, it should work on either side if you can get along with it ergonomically.
    Aug 2014
    It just seems easier to reach and a little more hidden on the right. I did not like the way it stuck up on the left side. I was not sure if I would get air bubbles with it upside down, but it seems to work great.
    Oct 2011
    I have a reverb and don't use it often because the lever is in such an awkward position. I like what you did there. Must have long fingers
    Reputation: DethWshBkr's Avatar
    No problem at all with it like that.
    Same as mine.
    Rockshox Stealth Reberb, Can in Install the lever on the other side?-reverb-button.jpg
  1. Rockshox Reverb Stealth 100
    By mkitch in forum All Mountain
    Last Post: 02-06-2014, 12:20 PM
  2. Rockshox stealth and slayer 70 2013
    By karlfoto in forum Rocky Mountain
    Last Post: 01-15-2014, 01:40 AM
  3. Drive side noise/drag on new GXP BB & crank install
    By vikingshelmut in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-13-2013, 06:37 PM
  4. Why is 15mm QR lever on right side?
    By redline9k in forum Shocks and Suspension
    Last Post: 01-20-2012, 01:27 PM
  5. Rockshox Reverb Stealth on a Delirium
    By meeeeep in forum Knolly
    Last Post: 10-09-2011, 04:49 PM
