Replacing your Trek's FOX shock
So, I'm looking to replace my 2013 Remedy's FOX Float DRCV CTD shock. From the website, it's length is 7.75x2.25"
However, at the FOX website, the Float shocks they have have the following lengths:
7.50 x 2.00
7.875 x 2.00
7.875 x 2.25
8.50 x 2.50
8.75 x 2.50
9.50 x 3.00
Can I use the Float shock with 7.875 x 2.25 length? Is it compatible, will it fit in my bike?
Thanks guys.
It should fit. I'm not so sure about how this would effect sag, travel, etc. You blew up your DRCV shock? You might be able to find a boost value version of the same shock if you prefer that.
The Trek Remedy and all Trek DRCV bikes for that matter use a trunnion style upper shock mount. All the shocks on the Fox site are a standard mount so you can not use them without some type of modification which I know has been done but is probably not the easiest or cheapest conversion.
Why are you looking to change your shock?
Thanks guys. I'm just looking to replace it in the future with the newer Float X CTD shocks that's coming out: FLOAT X CTD w/Trail Adjust Bike Shock | FOX
OhGee: other than FOX, what other shocks out there can I use to replace the DRCV without complicated mounting conversions?
Fox is the only company I know of that makes a Trek DRCV compatible shock with the side or trunnion mount. You could maybe switch to a standard top mount by acquiring the right parts from Trek. You might need a new evo link or maybe just the right spacers, not sure, but then you would lose the advantage of the larger air volume that DRCV gives you.
It's quite possible that Fox will use the new technology in the DRCV shock as well next year. Then you can buy a new shock from Trek and bolt it on.
By the way Trek lists the non DRCV shock as a 7.25 X 2.00. They use these on the lower level Fuels.
By the way Trek lists the non DRCV shock as a 7.25 X 2.00. They use these on the lower level Fuels.[/QUOTE]
Just a note: The Fuel uses a shorter length/travel shock than the Remedy. This is according to the Trek web site.
There are threads on converting Remedy's to coil shocks. The same method can be used to fit many brands of air shocks. As popular as Treks are you may find a hardware "kit" somewhere.
Oops, my bad I meant Remedy. I have Fuel on the brain since I own one.
By flipnidaho in forum Yeti
Last Post: 05-12-2013, 12:30 PM
Last Post: 04-07-2013, 06:56 AM
By MordiDP in forum 29er Bikes
Last Post: 11-22-2012, 07:29 PM
By danridesbikes in forum Santa Cruz
Last Post: 06-19-2012, 07:34 AM
By vqdriver in forum Titus
Last Post: 08-21-2011, 06:27 PM
Members who have read this thread: 4
- You may not post replies
- You may not edit your posts
Forum Rules
