Results 1 to 5 of 5
    Jan 2009
    Replacing crankset on Trek 4500
    what's up all? I'm trying to replace my crankset on my Trek 4500 since it bent out of place (actually came off during a ride!). Just want to get it back into working order. I've removed the crankset, but the Shimano FC-MC08, 22/32/42 teeth, is a pretty old crankset so they don't sell them anymore. I need a replacement.
    All I know about the original crankset is that it's 170mm and that it is a 110-113 mm spindle length.
    http://www.shimano.com/publish/conte...on%20Chart.pdf
    Will this one fit?
    Shimano Alivio Square Taper & Rings MC20 | Buy Online | ChainReactionCycles.com
    Jan 2009
    any help would be great ya'll
    Sep 2012
    Hi there.
    I am just in the process of replacing the crankset of my 6000. It originally had Shimano Alvio's 175mm 42 32 22 with a 73 x 113 BB.
    I am replacing this set with a Deore Crankset. It is a step up and comes complete with the bottom bracket as mine is shot. I am changing the 175mm crank arm for 170mm as personal preference.
    My Alivios were set up with a 73 x 113 square taper bottom bracket. So it sounds like your set up will work fine if you have a square tapered bottom bracket.
    Hope this helps
    Sep 2012
    I bought the Trek 8.3 DS back in March 2012. Long story short I had the remote lockout fork that is on the Trek 8.5 DS put on my 8.3 DS. I noticed that when I ride the bike with the remote fork on lockout for a long duration the fork slowly compresses as I'm riding so when I stop and unlock the fork it "springs" back up. Also, the remote fork does not totally 100% lock out as there is about 1/4" "give" to it (when I press down it bounces). Are the two things I mentioned normal for the remote lockout fork, or is there something wrong with the fork?
    The original 8.3 DS mechanical lockout fork (that comes with the 8.3) seems to 100% lockout and has no "give" to it when I press down on it. And it does not seem to compress as I ride it on lockout. So I was thinking of going back to the mechanical lockout fork that comes with the 8.3 DS because I want the fork to be rigid when I ride it on the pavement.
    If you can answer my questions and give me any additional information/advice I would appreciate it. Thank you!
    Dec 2012
    Same problem
    Deezy3z,
    Any luck with the crankset replacement? Had mine fall off on the trail... need a replacement... did the Shimano Alivio Square Taper & Rings MC20 fit?
