Results 1 to 5 of 5
Thread: Remedy 6
    Swedish!
    Reputation: Don_Tomazo's Avatar
    Remedy 6
    Baught it for a month ago but I got it just now and yesterday I took my first testrun on it. It is not a very good climber but I guess I knew that before I baught it. Downill is really fun on thos bike and when my buddy hit the breaks I just kept peddaling to increase speed.
    Feb 2006
    A remedy not a good climber? Please check your legs!
    Y a pas d'frontières
    Reputation: psunuc's Avatar
    Mar 2005
    Quote Originally Posted by Becobus
    Yeah. Mine climbs very well for a 6" AM rig. Change out the tires to something less nobby if you want less rolling resistance, it was a notable change for me.
    Feb 2006
    the problem of the remedy (especially the 6) is that everybody do think it is a freeride bike due of the impressive rocker link and the burly frame. In fact it is excellent bike for improving stamina as it climbs very well, it will be very comfortable for light downhill but not engaged. The only weaknes is the Nixon fork wich is not elaborate enough to play with on uphills or downhills. Trek should adapt a real AM fork blockable (same for the swinger). This bike is designed for a long lifeime, the maintenance is limited compared to an other bike (my Ransom 40 for example) and the quality of the components is very good (except of course the Manitous stuff). On technical section it is more precise and will respond straight to your requests.
    Swedish!
    Well allright, it doesent climb bad but a stiff frame climbs better and thats what I hade before this one.
    I have a cuestion fore you experts out there; The Remedy didnt have all the eqipment that was listed in the specs. Among other things it was supposed to have a 20 mm front wheel-axle but it didnt. The breakes were supposed to be Avid juicy 5 with an 8" disc in front and 7" in the back but it is two 6" disc and breakes from Hayes. They are very good but offcourse I want the bigger discs.
    When Im looking at Manitous homepage and the Nixon elite fork that the Remedy has I see that there is a 20 mm axle on and it doesns seem to have a another version with a thinner axle. Is my fork not a -07?
    Im gonna talk to the company that delivered the bike about this offcourse.
    These are the specs that the bike should have: (swedish)
    Artikelnr 1187600117 | 1187600217 | 1187600317 | 1187600417
    Storlek 15.5" | 17,5" | 19,5" | 21,5"
    Ram Trek ZR 9000 Alu
    Bak ram Trek ZR 9000 Alu
    Framgaffel Manitou "NEW" Nixon Elite 130-160, SPV, volume, 160mm, 20mm axle
    Bakdmp. Manitou "New" Swinger Air 3 Way 7.875X2.25
    Styrlager VP A51A 1 1/8"
    Vevparti Bontrager Race 22/32/44
    Vevlager Giga X Pipe
    Framvxel Shimano LX M581, 34.9mm
    Bakvxel Shimano M751 XT (switch to M761 when available)
    Reglage Shimano Deore M510
    Kassett Sram PG970 11-34, 9spd
    Kedja Shiamno HG53, 112
    Fram dck " New" Jones ACX 2.35 127tpi kelvar folding
    Bak dck " New" Jones ACX 2.35 127tpi kelvar folding
    Fram broms Avid Juicy 5, hydraulic disc 8in
    Bak broms Avid Juicy 5, hydraulic disc 7in
    Bromshandtag Avid Juicy 5
    Styre Bontrager Race , 31.8x40mm
    Styrstam Bontrager Race 31.8 x 7 deg
    Handtag Bontrager Lock-ons
    Sadel Race saddle; Hollow cr-mo w/ti finish.
    Sadestolpe Bontrager Race 27.2
