Results 1 to 5 of 5
    Oct 2014
    Rear rack full suspension
    I have a Trek Fuel 100 Carbon that I use both for commuting and for trail. I want to put on a seat-tube rear rack for the commuting part and am looking for suggestions. I would like it to be:
    Light weight
    Strong
    Easy to remove
    Good fit for my carbon 1.24" seat tube
    I've done a lot of searching and found some prospects and opinions, especially the "never put one on a carbon seat tube" and some who say "it'll be fine, just don't put a lot of weight on it". Prior to choosing one I would like to hear from some of you who have one, both good and bad. Manufacturer & model please.
    Thanks,
    Darrel
    NE Michigan
    A good rack for full suspension is the Thule Pack N Pedal. It mounts to the rear triangle. Thule Pack ?n Pedal Tour Rack - Thule
    Oct 2014
    Quote Originally Posted by the-one1 View Post
    Thank you for the response. I guess my first observation is that it would seem that with the rack mounted to the triangle on a full suspension that every little bump would be bumping the rack and whatever is on it up and down. With a seat post unit the triangle can beebop up and down all it wants and the seat post would remain relatively level. I guess my main question is will a seat post unit work OK with carbon fiber seat post? That stuff is supposed to be stronger than steel, pound for pound.
    Darrel
    Reputation: zahgurim's Avatar
    Aug 2005
    Check out the Arkel randoneuring rack.
    It mounts to your saddle rails, and uses the post only as a stabilizer.
    Arkel Randonneur Rack - Seat Post Rack - Carbon Seat Post Friendly
    Any seatpost rack will do, it may scratch up your carbon post a little but all seatpost racks are essentially the same. They don't hold a lot of weight but can be used to carry a change of clothes and some lunch to work. If you are worried about your carbon post buy a cheap aluminum post to go with the rack.
  1. Rear suspension designs....full floater vs CVA?
    By stygz1 in forum Shocks and Suspension
    Last Post: 04-24-2014, 06:14 PM
  2. Rear suspension designs....full floater vs CVA?
    By stygz1 in forum General Discussion
    Last Post: 04-12-2014, 07:09 PM
  3. Help with creaking rear end on full suspension
    By sasquatch rides a SS in forum Shocks and Suspension
    Last Post: 04-21-2012, 07:17 PM
  4. Full Suspension car trunk rack????
    By scottie mac in forum Car & Biker
    Last Post: 04-04-2012, 12:19 PM
  5. Problems hauling full suspension bike on hanging rack
    By Jnthomps08 in forum Car & Biker
    Last Post: 03-27-2012, 03:34 PM
