Results 1 to 3 of 3
    kabouterclan member
    Rear Maxle problem on '12 Rumblefish
    ..and another smal issue with my Rumblefish (not related to the other one).
    The rear wheel had a little bit of play, if i don't torque down my Maxle like a maniac.
    I'm aware of the adjustment procedure of the Maxle (Not using it as a wing nut, internal adjustment with the inner hex bolt). The ABP bolts seem to be torqued down okay. Haven't checked the bearings.
    Maxle closure needs a lot of force too, when i adjust the inner hex to remove the play in the system.
    Any ideas?
    Sent from my HAL 9000
    Reputation: SlowMTBer's Avatar
    Dec 2011
    I had a similar issue that was caused by too much play in the hub bearings.
    2017 YT Jeffsy AL Two 29
    2011 Trek Rumblefish 1
    kabouterclan member
    Thanks, i'll check the hubs. They're Hopes, by the way. They don't seem to be running too well, but it would surprise me if the bearings would've gone bad after just one year of riding.
  1. Replies: 0
    Last Post: 03-30-2013, 07:07 PM
  2. SIR 9 maxle
    By tocoldmn in forum Niner Bikes
    Last Post: 02-11-2013, 05:32 AM
  3. Rumblefish or Rumblefish Elite?
    By Haymarket in forum 29er Bikes
    Last Post: 04-03-2012, 07:54 PM
  4. 2011 Rumblefish V. Rumblefish 1
    By GatorB in forum Gary Fisher
    Last Post: 01-01-2012, 12:07 AM
  5. Maxle lite vrs old Maxle
    By Jaybo in forum Shocks and Suspension
    Last Post: 12-20-2011, 07:30 AM
