..and another smal issue with my Rumblefish (not related to the other one).
The rear wheel had a little bit of play, if i don't torque down my Maxle like a maniac.
I'm aware of the adjustment procedure of the Maxle (Not using it as a wing nut, internal adjustment with the inner hex bolt). The ABP bolts seem to be torqued down okay. Haven't checked the bearings.
Maxle closure needs a lot of force too, when i adjust the inner hex to remove the play in the system.
Any ideas?
Any ideas?
