    Apr 2013
    Ordering xx1 for 2012 superfly 100 pro
    What bottom bracket do I order, I know it uses bb95 press fit bearings is there different spindal sizes or caps ect.... Gxp, bb30 pf30 bb92 are the options, I know it comes with the 168q factor but the 156q will work with about 1/8 less room per sides on the chain stay. Any info would be good thanks!
    If you have the complete bike, you already have the GXP BB in the frame - order the GXP spindle crank. If you just have the frame, order the BB Trek Madone SRAM Kit - Trek Part #404700. I have also heard you should stick with the 166 Q-factor crank on the full suspension Superfly - that's what came on the bike. The narrower crank might work on the stand, but I have heard that it can rub in use.
    Make sure your rear wheel is compatible with the XD Driver Body.
    I got these GXP CHROMIUM STEEL BEARING KITS FOR TREK BB90 AND BB95 for my XX1 system a year ago and they have worked great. I have had much better luck with the Enduro bearings than the Sram kit. The site has a lot of other options but the 18.00 bearings work great.
  1. 2012 Superfly 100 AL Pro
    By blunderbuss in forum Trek
    Last Post: 02-07-2015, 10:51 PM
  2. 2012 Salsa Horsethief vs 2012 Superfly 100 Al Elite
    By Radioface in forum 29er Bikes
    Last Post: 01-28-2013, 08:50 AM
  3. 2012 Superfly 100 Elite vs. Superfly 100 (base)
    By Andy13 in forum 29er Bikes
    Last Post: 03-12-2012, 04:38 AM
  4. 2011 Superfly vs. 2012 Superfly
    By silves1171 in forum Trek
    Last Post: 02-06-2012, 01:02 PM
  5. 2012 Superfly Elite vs. Superfly
    Last Post: 11-15-2011, 09:04 AM
