    Aug 2010
    Older 4300- Disk Adapter
    I have a 2005 (maybe 2004) trek 4300 disk that needs a rear brake adapter however I have no idea what kind. I figured the wealth of knowledge on here may help. I can upload a pic later if that helps. Here is the link to the frame. Thanks for any advice.
    2005 4300 (Disc) - Bike Archive - Trek Bicycle
    I hate that name.
    Reputation: blunderbuss's Avatar
    Any Trek dealer can get what you need. It's the adapter and two bolts. Part #s 210648, 210821 and 211045.
    Worked at Trek/Fisher dealer 2008-2013. Only a little biased.
    Aug 2010
    Thanks for your help. Just put in the order.
    Aug 2005
    It's probably the same adapter as the one I just installed on my 2005 Trek 3700. If the dealer tells you that the kit is on indefinite backorder, you should be able to order just the bracket by itself. You would then need to go to a hardware store to find the correct bolts. Older 4300- Disk Adapter-20130830_111110s.jpg
  1. Replies: 104
    Last Post: 12-29-2016, 08:05 AM
  2. Replies: 6
    Last Post: 07-05-2013, 04:04 AM
  3. Replies: 2
    Last Post: 04-14-2013, 01:14 AM
  4. a2z disk break adapter?
    By kitts21j in forum Brake Time
    Last Post: 03-25-2011, 01:57 AM
  5. hope disk adapter
    By robski21 in forum Brake Time
    Last Post: 02-23-2011, 06:46 PM
