    May 2012
    Noob wheel builder question
    So I'm going to be building my first wheelset and I feel a bit like an idiot but here it goes anyway. I have a 2012 trek superfly al 100 elite and I'm wondering what hub to get for the front. Will a 15mm qr hub fit on current fork? If not what will work for me? After a 15 year hiatus from mountain biking I feel a little lost with all of the different choices. Thanks for any help you can offer up
    I hate that name.
    Reputation: blunderbuss's Avatar
    I don't remember what the 12 Elite came with... Whatever you have now, is the type you need. It should be fairly obvious if your fork takes a 15mm thru axle or a 9mm standard hub with a 5mm skewer. The hub type can't be can't be changed without changing the fork.
    Worked at Trek/Fisher dealer 2008-2013. Only a little biased.
    Mar 2013
    I have a 2012 trek superfly 100 al elite too and no we don't have a 15qr we have a 9mm standard.
    we have to get new fork bottoms to run a 15qr and matching wheel/hub. For new Fox fork bottoms it's apparently approx $200 i just started the researched but hope that helps
    MTB B'dos
    Reputation: LyNx's Avatar
    I highly suggest that you builds up your front wheel with something like a Hope Pro2 EVO that uses end caps, so switching axle size is simply a matter of switching end caps. There are a number of different brands who offer this sort of solution, just Hope is one I'm familiar with, is inexpensive and very popular. Front Pro2 will do QR, 15mm, 20mm and I think even 32mm.
  1. Pro Wheel Builder
    By rockintheshed in forum Wheels and Tires
    Last Post: 06-12-2017, 04:01 PM
  2. noob wheel question...
    By mrcyrus16 in forum Wheels and Tires
    Last Post: 03-12-2013, 07:39 PM
  3. In need of a Wheel Builder
    By hazmazk in forum California - Socal
    Last Post: 05-29-2012, 10:56 AM
  4. Wheel Builder
    By bigpete61 in forum California - Norcal
    Last Post: 03-02-2012, 12:33 AM
  5. Wheel Builder
    By Tripower in forum California - Norcal
    Last Post: 04-09-2011, 05:32 PM
