Thread: new crank
    new crank
    Hi a friend of mine wants to change his crankset on his 2012 superfly 100 AL. I searched abouth this and its spinning my mind, I don't want to order the wrong crank, He just needs the crank not the bottom bracket so what
    crank will fit no problem on the superfly AL ??? its a 3x10 .
    shimano xt ? xtr ? sram xo x9 ?
    I hate that name.
    Reputation: blunderbuss's Avatar
    Base SF100AL? It's got to be Sram if he doesn't want to get a new bottom bracket also.
    Worked at Trek/Fisher dealer 2008-2013. Only a little biased.
    yes base SF 100 AL its the black & orange one, so any sram crank will fit this bike ? what abouth the ones they say are compatible with the bb30 bottom bracket .
    what kind of bottom bracket must I get if I want to run a xt crank ? thanks
    I hate that name.
    BB30 cranks will not work. GXP is what you need. The SF100AL frame is BB92. There are a few bb options, sometimes referred to as BB86-91. If you want to go Shimano, just make sure sure the bb says it's for Shimano.
  1. Help upgrading Shimano 8spd IG crank to 9spd HG crank.
    By kryten in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-29-2013, 05:40 PM
  2. should i spend the extra $100 and get the xt deore 2x10 crank over the sram x7 crank
    By crclawn in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-18-2012, 11:27 AM
  3. Replies: 1
    Last Post: 03-11-2012, 06:18 AM
  4. loose crank, rounded taper..bottom-bracket & crank damaged?
    By chimpanzee00 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-14-2012, 03:21 PM
  5. crank/bb removal trek 3700 - sr suntour crank
    By Jason B in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-27-2012, 12:03 PM
