Page 1 of 4 1234 LastLast
Results 1 to 25 of 82
    How much does your Marlin, Mamba, Cobia, X Calibur, Paragon weigh?
    Hello everyone,
    I've recently purchased a 2012 Trek Marlin, and I'm under the impression that the other bikes in this "29er Sport" (Wahoo, Marlin, Mamba) and 29er Race (Cobia, X Calibur, Paragon) series are exactly the same frame, with upgraded Fork, drivetrain/brakes, wheels, etc. based on their respective MSRP.
    What I want to know is how much does your bike weigh?
    What model and size frame?
    What parts did you upgrade to achieve this weight?
    Any recommendations on upgrade path?
    Thanks for all your input, I'm excited to upgrade as my skillset improves, and eventually end up with a kick-ass aluminum hard-tail
    you are partially correct in thinking the 29er HT family using the same frame. the only exception of the paragon frame being different than that of the rest. the paragon uses press fit BB instead of the standard 73mm threaded type and also has a tapered head tube.
    i too own a marlin 19" but mine is a 2011. i have not weighed the bike stock but i have weighed it with my bathroom scale (weigh myself first, then weigh myself hold bike, subtract my weight = bike weight). i have done a couple of upgrades before the weigh in.
    mine so far has the following mods:
    easton ea50 30mm riser bar
    truvativ hussefelt 40mm stem
    sette s lock on grips
    speed dial 7 levers
    bb7 brakes w.185mm rotors f/r
    panaracer rampage 2.35 front tire/ tioga psycho genius 2.25 rear (slime tubes f/r) -- soon to be tubeless
    shimano slx double crankset
    wellgo mg52 platform pedals
    hurricane mini pump
    with these mods my bike weighed in at ~30lbs (all reflectors removed)
    i have in my possession these components awaiting my stan's wheelset so they can be installed.
    2010 fox f29 fit rlc100 15qr
    salsa 32t chainring, sram x9 9spd shifter, x9 rd, mrp 1x chain guide, pg990 cassette (1x9 convert)
    cane creek 40 series zs headset
    looking to change out the saddle and seatpost too...
    i know ive overbuilt this bike but i really like the frame's geo and i like to mod!
    i think the best path for entry level upgrade is better brakes, mid level fork, better crankset should be more than adequate in reducing weight and upping performance.
    Reputation: HighLife420's Avatar
    In the pic (bike is sold now) the bike weighed in at 22lbs. Only thing left from stock bike was the Frame, Fork and RD.
    Shimano XT M775 brakes
    Gatorbrake Aries rotors
    Bonty RL seat
    Thomson elite post
    Easton Monkeylite SL
    ESI Chunky grips
    MRP x1 BB mount
    Shimano XT M760
    Shimano XT 11/34 Cassette
    Sram X.7 shifters
    2 Racing Ralphs.. 2.4 (FR) 2.25 (R).
    Wheelset is Velocity VXC on Halo 6 hubs
    Salsa Skewers
    Think thats it =)
    [/QUOTE]
    My 2011 Paragon 19" frame with only ergon grips and pedals (shimano 820?) is right around 26.5 pounds on the bikeshop scale.
    If I recall from previous searches on this site the 2011 x-cal is right arouns 27.5 to 28 with pedals.
    Biggest recomendation for weight loss is wheels and tires. Stock tires can be 700 to 800 grams each. A set of 600gr. tires save almost a pound. Farily easy to drop another pound on the wheels.
    So I weighed my bike using the digital bathroom scale method, so my info is:
    32.2lbs
    2012 Marlin, 15.5" (small)
    Only upgrades so far are 2012 XT pedals (trail) and a Planet Bike gel seat. I think both maybe even added weight
    I think my next upgrades are going to be a Bontrager RXL/RXXXL stem and handlebar to get the cockpit right.
    Then for next summer I think I'm going to do a full 2012 XT group set. Probably do wheels/tires around the same time too, but so far I'm uneducated on wheelsets and don't know what will suit me and the terrain here.
    I'm interested on how other people have built up their G2 hardtails, I'd appreciate if you posted.
    Thanks and Regards.
    2011 Paragon - 17.5" frame - 25.0lbs on my friends scale.
    Although listed with Bontrager tires, mine (and other peoples I've seen) came with Schwalbe Rocket Rons.
    Aug 2010
    Quote Originally Posted by qa_bugfinder View Post
    You are right on, my 2011 21" X-Cal weighs 28lbs with XT pedals and TLR Nobby Nic tires (with tubes for now).
    Reputation: FZJ80's Avatar
    2012 Trek Marlin 29er-100% Stock, no upgrades.
    19'' Frame-36lbs Bathroom Scale confirmed with full waterbottle.
    What I plan to upgrade:
    1. The Tektro brakes are total ass.
    2. The stock fork is equally useless. I really thought that at this stage in my life (31,kids,etc) I would be doing light trails and mainly sticking to pavement. Well, I basically push the limits everytime I ride and pretty much expect to seriously F something up sooner or later. So when that happens, I'll buy a new fork and some additional life insurance.
    2012 Trek Marlin
    noob
    Reputation: trueblue01gt's Avatar
    2011 19" paragon
    easton ec70 wide bars
    odi lock on grips
    rxl cage
    shimano 540 pedals
    thomson masterpiece post
    crest wheel set with ck hubs
    RoRo
    just under 25#
    2007 Fisher Rig
    2011 Trek Paragon
    2013 Trek Madone 2.1
    2011 Paragon - 19" frame - 26.5# - stock
    Rockhopper Expert
    cobia is 13.8kg
    Oct 2011
    Got my 2011 19" Mamba down to 24.60lbs with pedals, water bottle cage, cateye and sensors. It weighed 31lbs stock. I dropped 7lbs with the following mods: Stans Crest Wheels, racing ralph tires, thomson seatpost and stem, truvativ bars, x0 brakes, 2x10 x9 groupset- frnt der, rear der, crank, shifters, etc. fizik tundra seat, crank brother candy pedals, fox g2 rlc100 front fork.
    Dec 2010
    2011 Trek Marlin 29er 17.5" frame with my old bar ends = 14.65 kg ~ 32 lbs 4 oz.
    29.0 pounds on the nose (bathroom scale, I get on and then get on with the bike)
    2011 X-Caliber 21 inch frame
    Odyssey trail mix pedals, Sunline twisted waffle lock on grips, Garmin handlebar mount as weighed otherwise it is as it came from the factory.
    2011 x-cal 17.5 inch frame
    Digital bathroom scale
    Stock with some old shimano spd platform pedals = 27lbs
    Upgraded parts
    Egg beater sl pedals
    Lizard skins lock on grips
    Easton Ec90 carbon low rise bars
    Easton Ec90 stem
    SDG Fly seat
    SDG carbon I beam seat post
    Currently weighs in at just under 26lbs
    Wheels will probally be next
    Jun 2010
    @HighLife420
    Beautiful bike, I'm jealous
    2011 marlin XL...30lbs deore ext bb crankset deore front deraileur captin tires diamond back pedals
    Just picked up a 2012 Trek Mamba 19' today. Its my first 29r. I came off a Giant Trance to this cause I wanted to see what the 29rs are all about! I wieghed it stock and its 31lbs....
    Photobucket
    Oct 2011
    My 2012 Marlin 15.5 weighs 35 lbs.
    Added gel seat, Bontrager flat kit, Cat eyes computer and wider pedals.
    I really need to get the weight down, she is fat and the brakes and fork is ****. I cant lock the rear and wipped out twice already.
    Oct 2011
    Whats lighter brakes are you guys upgrading to?
    I'm about three weeks into a squealing 2012 Trek Marlin 29er (purchased for under 600) and thinking of returning/selling it for something else. I can get my hands on a 12Y Trek Mamba for about $750 and a 12Y Cobia for $950. Also, I could probably use those prices to bargain down a selection from another manufacturer.
    A Talon 29er 0, a Felt Sport, a Cannondale 29er SL3 are a few that come to mind… all retail at roughly the same point as the Cobia and I could probably get them for 20% less.
    So if you had your choice of any mtb in the 1200 range that you could buy for 950, one for which you could easily get service and support, which would you buy and why?
    Reputation: Britishnate's Avatar
    The biggest upgrade that will also save weight and improve performance will be the fork and then the wheelset.
    2011 Trek Cobia 21 inch
    From the bathroom scale method, the bike started out at 29.5 Lb. I used an accurate scale to weigh each piece that I upgraded to get an accurate change in weight.
    The first column is the weight of the newer or different part. The next column gives the weight of the part from the original Cobia. Next column is the weight difference in grams and the final column is the weight gain or loss in Lbs.
    How much does your Marlin, Mamba, Cobia, X Calibur, Paragon weigh?-bike-weight.png
    After swapping out some parts with my older 26 inch bike that I am retiring, I dropped a touch over 2.7 Lbs off of the original weight for a new estimate of about 26.7. I can see a few things to do that would bring me under 26 like the grips, the pedals, and going tubeless.
    The table gives a quick idea of where some potential weight savings could come from on these bikes.
    Edit. Bathroom scale is not too good in this case apparently. Table weights are good for what I put on the scale but total start and finish weights are off. See updated post below.
    Final weight of bike is actually 28.14 according to local bike shop digital scale.
    2012 Superfly AL Elite, basically stock except for Tubless-ready & some little piddly stuff.
    Bongrager tubeless-ready system with Stans goo. 85 g savings per wheel using 2 oz of goo per tire.
    2" cut from handlebars 18g savings plus now it fits between the trees.
    2" cut from seatpost. 15g savings
    Bottle cage bolts replaced with nylon screws to fill holes. About 15 g savings
    Carbon headtube spacers saved 5 grams ($1 per gram but it looks cool. I actially added an extra 5mm carbon spacer so weight savings is down to 2 grams.
    Add:
    Eggbeater 3 pedals.
    Cateye strada wireless.
    Total weight 26.6#.
    Here are the weights of some of the components:
    Tube2 & valve cap2 180g each
    Tires 625g each
    Stock rim strops 20g each
    Replacement tubeless rim strips 50g each
    Tubeless stems 5g each
    Front wheel & rotor 1075g (not sure if this was with rim strip or not).
    Front skewer 55g
    Rear skewer 64g
    Rear wheel, rotor, cassette, wheel, & stock rim strip 1775g
    Headtube top 10g
    Headtube bolt 8g
    Headtube spacers 3x10mm 22g total
    Water bottle bolts & spacers 17g
    Cassette 448g (The cassette is very low-end. I will replace it with SLX or X7 (is X7 posible?) when it wears out).
    Seatpost (before cutting) 270g.
    Saddle 270g
    May 2012
    @ Chris5107
    Curious if you have weighed just the frame to find out what it weighs as I have the exact same frame size as you. Trek doesn't readily give out that info because according to them there are variances in weight due to manufacturing processes (duh!). I was planning on breaking down the bike completely this winter to find out, but perhaps you have already weighed it. I have been thinking about converting it to a 1X9 race bike, but if the frame is a porker then I will probably look at a lighter frame to use as a platform.
  1. 2012 Trek Rig, Cobia, Mamba
    By imprezawd in forum 29er Bikes
    Last Post: 05-12-2012, 01:49 PM
  2. Trek/Fisher Marlin or Mamba?
    By TennisPlaya in forum Gary Fisher
    Last Post: 01-06-2012, 10:02 PM
  3. 2011 Mamba vs. 2012 Mamba or Marlin
    By sxshep in forum Trek
    Last Post: 09-16-2011, 03:16 PM
  4. Marlin or Mamba
    By rideintpa in forum 29er Bikes
    Last Post: 01-19-2011, 10:40 AM
  5. Fish weights (Cobia/X-Calibur)
    By DezFX in forum Gary Fisher
    Last Post: 01-29-2010, 06:58 PM
Hot Deals
Contests
Latest Mountain Bike Articles
