Results 1 to 6 of 6
    How big a axle in a Trek series 4 can be run
    I am ordering new wheels for mine and want to run heavy axel's,or can I lightly drill the frame for larger diameter?. Thanks!
    Warrior's Society
    Reputation: mtnbikej's Avatar
    Sep 2001
    IF you need heavier duty axles than what came on your "4x00" series bike.......you bought the wrong bike.
    Sorry, but they are entry level XC bikes......not designed to be jumped and dropped.
    I crashed hard enough on my Tallboy to break my leg,
    The carbon is way more durable than most people.
    Very bad idea! The above guy is right- if you are doing that kind of stuff then you need a true dual suspension bike like a Fuel Ex.
    Save your $$$ and move up when you can. Keep your 4500 for light and fast courses.
    Tim
    I hate that name.
    Reputation: blunderbuss's Avatar
    Worked at Trek/Fisher dealer 2008-2013. Only a little biased.
    i am changing the rear wheel to a Sun MTX 33 and want to run a heavier axle the stock axels are cheesy, I weigh over 300. I jump alot of curbs.
    Quote Originally Posted by Realslowww
    You need a hub that will accept a 10 x 135mm axle like :
    http://www.transitionbikes.com/Store_Detail.cfm?Token={ts_2011-05-24_10:56:49}-70793143&P=1425&o=2
