Results 1 to 3 of 3
    EEB
    EEB is offline
    Gary Fisher Tass. disc & HKEK
    How much do these bikes weigh stock?
    Reputation: CrankyMonkey's Avatar
    The 19 inch HKEK is about 29 lbs. I weighed it at a bike shop on a hanging scale. It feels lighter when you ride it. You could probably shave at least 3-4 pounds off it but it would require to switch out a bunch of components. If your worried about weight then look at the Gary Fisher with the carbon seat stays.
    EEB
    EEB is offline
    Quote Originally Posted by CrankyMonkey
    Would the 17.5" HKEK weigh about the same? Probably the tass disc would be over 30 lb if the HKEK is about 29 lbs since they are different frames.
    If I get the HKEK I would probably switch some of the components down the road...
