Results 1 to 5 of 5
    fuel external BB issues?
    i am about to put a XT 760 crank on my fuel and i was wondering if there were any clearance issues between the shell and swing arm, it looks close.
    S-Works all the bikes!
    Just another used cat for sale
    bang
    Reputation: Cyco-Dude's Avatar
    not sure why there would be? higher end fuels come with external bottom bearing cranksets. just make sure your shell is faced and chased.
    i just remeber someone with some type of GF having issues and it had a similar design
    I run that setup; no issues.
    Jan 2005
    You need to make sure you use the correct spacers
    Just make sure you follow the Shimano instructions and use the correct number of spacers. You need two on the drive side and one spacer on the non drive side if you are running a standard tripple ring.
