Results 1 to 10 of 10
    Reputation: stunnerable's Avatar
    Fuel EX stem advice.
    Hey guys. I have a mostly stock 2012 ex8 in 17.5. I was considering going with a shorter stem an wider bars. Anyone have any experience with this or suggestions? Any help would be great.
    Sep 2012
    I went from a 110mm stem down to 70mm and an 745mm bar. And I'm 6'4". Setup is excellent. Steering is much more responsive. I may even go down to 50mm stem next year. Is say pull the trigger and go shorter.
    Sent from my PC36100 using Tapatalk 2
    Jun 2010
    Is there a particular reason you are wanting to go wider/shorter? I have the same size EX8 (although a 2010) and have been thinking about going with slightly narrower bars (stock width is 650mm). I just prefer it that way. It may adjust my weight and position slightly back to keep the rear wheel a bit more planted on climbs and descents.
    Sep 2012
    I have a 2013 19.5 EX 8 and changed out my stock 720 mm bars & 80 mm stem for 785 mm Race Face Atlas 1"1/4 rise & 60 mm Turbine stem.
    For me it's a huge improvement with all aspects of handling, climbing, & DH.
    I'm 5' 11" with broad shoulders.
    Thanks guys. Sounds good.
    I just prefer a more upright wide stance. Its a personal preference.
    Reputation: shanem's Avatar
    A shorter stem and wider bar completely changes the Fuel EX (for the good). I had a 2011 and ran it with both 70 and 60 mm stems and a 720 bar. Bike went from being awesome to a trail beast.
    Mar 2011
    I have a 2011 EX8..... 80mm Bontrager Rhythm Pro Stem, and 730mm Bontrager Rhythm Pro carbon bar. I love how it handles.
    Re: Fuel EX stem advice.
    Anyone ever go 750/50? It's a bit extreme but I'm considering it.
    Guess not.
    Mar 2013
    Quote Originally Posted by sum1noc View Post
    Nice! post a pic up if you can. I have a 10' ex 8 and Im the same height as you with broad shoulders too.. Ive been wanting to go with a shorter stem for sure.. Im on the 21.5(virtual) frame, cause I got a good deal.
