Results 1 to 6 of 6
    ex7 bottom bracket
    What are all the compatible BBs for this bike. It's confusing to me, especially since I don't do my own work . Thx
    2012
    Sep 2012
    What year ex7?
    2012
    I am not sure which type they used on it that year. It will either be a Press fit in which case your trek dealer can order them and advise you on compatible cranks etc. I have a friend with a 2013 EX6 that has a threaded BB, and if that is the case your options are unlimited pretty much.
    Can you take some pictures for us?
    The best things in life are not things.
    I just did some looking around and it appears that bike came with the press fit BB. Basically you can run Shimano 24mm spindle cranks which is pretty much all of them, SRAM GXP cranks and some others with a different bearing set. However any 30mm spindle cranks are not going to work. You can order the press fit bearings from an online place, or go to your Trek dealer and they can set you up. Are you trying to change cranks, or just the BB?
  1. Fat bottom bracket
    By Dr.Mushy in forum Fat bikes
    Last Post: 10-15-2014, 03:51 PM
  2. Bottom bracket help
    By digitalayon in forum Clydesdales/Tall Riders
    Last Post: 07-02-2013, 09:05 PM
  3. Bottom Bracket Help
    By gsheffer in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-02-2013, 04:55 PM
  4. A9C bottom bracket
    By dirtdiva in forum Niner Bikes
    Last Post: 01-23-2012, 09:36 AM
  5. Which bottom bracket do I need?
    By smartytime in forum 29er Bikes
    Last Post: 01-15-2012, 07:14 AM
