Page 1 of 2 12 LastLast
Results 1 to 100 of 137
    Aug 2010
    DIY Trek Remedy 10-11 DRCV Coil conversion
    The DRCV shock on the Trek Remedy is fantastic. It's the closest air shock to a coil I've ridden. It is head and shoulders above any air can that I have ever ridden. It's still not a coil though. I've found that if you set it up stiff enough to handle big drops, dirt jumps and fast aggressive riding it is chatter on the small stuff. Sketchy. If you set it to 35% sag it wallows and bottoms out excessively. It seems like there was not a happy medium.
    Being a big fan of coil and oil suspension I set out to convert my remedy to a coil rear shock. I even talked to a couple of custom shock builders and no one had a solution. Trek has 10mm bearings for the drcv shock so it's not just a bolt it on and go endeavor. To my knowledge no one has done this conversion on a 2010-2011 to date. This is my journey through the conversion. I imagine it would also be possible to convert any standard air can using similar parts to a DRCV as they sell them now to the public.
    There are two different ways to do this. One is with a reducer and the other is with The RWC needle bearing kit. I did this the hard way first. With needle bearings top and bottom. What I found was that there was two much play in the double needle bearing kit top and bottom. There are bearing in the top anyway, so there was no need for the needle bearing kit up top.
    Parts List
    NEEDLE BEARING CONVERSION KIT 39.88mm part number NBKRWC3988. This kit fits the top and bottom shock mounts
    ENDUROģ MAX FULL-COMPLEMENT BEARINGS part number 608 2RS MAX 8mm x 22mm x 7mm. These bearings will convert the 10mm bearing to 8mm.
    Fox Rear Shock Hardware Kits part number 803-03-046
    Homemade press
    Step 1
    Remove the cranks, you will need to get to the bottom pivot.
    Step 2
    Loosen the bottom pivot. The bottom shock mount is under pressure from the main pivot.
    Step 3
    Remove the top and bottom shock bolts and remove.
    Step 4
    Press the bearings 10mm bearing from the outside in. You can use a socket. I used an old stem spacer.
    Step 5
    Press the new 8mm bearings from the outside in. If you don't the you could have the bolt you are using for a press stuck in between the bearings. (Don't ask)
    Step 6
    Bolt the shock up. You will need two 1mm shims for the top. You can get those from a local hardware store.
    Do not tighten. The main pivot should be torqued down first.
    Main pivot 300 inch pounds
    Lower shock mount 85 inch pounds
    Upper shock mount 150 inch pounds
    Done.
    More pictures
    This is when I had it built with needle bearings on the top and bottom. I found it had some play in it. That is when I decided to go with the reducers on the top.
    There are still bearing up there. There is not a single hint of restriction
    Bottom mount with the RCW needle bearing kit. I would highly recommend getting this kit. The main bearing on all the trek FS are so tight that the shock wasn't even moving in the DU bushings. There was huge restriction in that bottom mount, so much so that it was shearing the paint. Basically built in low speed compression.
    Suspension settings.
    I weight 190lb and like a pretty firm setup. I went with a 500lb coil and run about 28% sag. I also tried a 450lb coil and ran about 30% with it. I preferred the 28% sag much better. It is all down to personal preference though. These are the settings I liked for both. I started at the trek recommendations for the scratch, and then tweaked them from there.
    190lb
    450lb coil, 1.5 turns of preload. rebound 8 clicks out, lsc 6 clicks out
    500lb coil, .5 turns of preload, rebound 7 clicks out, lsc 7 clicks out
    My problem with the rear was that it seemed to get overwhelmed in really rough fast terrain. I love this bike, and the coil has made it even better. I don't notice the weight at all. It pedals amazing, I actually prefer it over the air. I still have that stiff pedaling platform that stays high in it's travel how I liked the air setup, but now the small bump compliance is amazing. A huge upgrade. It rips
    I can go out with my XC buddies and hang with them on the climbs, hit dirt jumps without slamming the bump stops, and the next day go keep up with all the dh guys with their sleds. It does it all.
    Can't wait for an MX Tune from Push.
    Aug 2010
    Thanks for posting the awesome write up. What model is the new shock? I recently replaced my EX8's rear shock with another one after the seal around the air valve blew out. If it happens again I might try something like this.
    Aug 2010
    It's a 2011 fox van rc. As soon as push gets its mx tunes done I'm getting pushed. It really did completely change the bike. 28 percent sag is perfect for the coil.
    Sent from my Droid using Tapatalk
    Did this conversion a few months ago. I didn't remove the lower pivot just sized the lower reducer for 0 preload ?
    Aug 2010
    Was there a lot of binding in that lower pivot on your bike ?
    Reputation: macming's Avatar
    Quote Originally Posted by dhalsey View Post
    Wow, good work. Seems like a lot of work to put a coil on a Trek though
    I got the MX tune for my DHX 5 coil, and it's just amazing! Rides like a dream and PUSH even tuned out the pedal feedback in the granny ring on my Nomad!
    Aug 2010
    Thanks it went pretty fast once I had the parts. Even without it push it to me to huge difference. I can't wait till the mx tunes are ready.
    Damn, PUSH is out of stock on the MX tune. I know PUSH uses avalanche parts for the MX tune. Perhaps Avy is another place to consider?
    {QUOTE} Loosen the bottom pivot. The bottom shock mount is under pressure from the main pivot.
    I did not have to loosen the bottom pivot on my bike to remove the shock. I did have to size the shock reducers because the Cane Creek's were a bit too long. I would think any fitiment of the reducers other than 0 preload would put tension on the lower chainstay bearings.
    Nightmare on Lyrik st. VI
    Reputation: amrgb's Avatar
    dhalsey & keen
    What shock length are you guys using? I'd guess 7.785"x2.25". Is that right?
    Quote Originally Posted by TNC to whining spammer
    Don't let the nose of your saddle hit you in the @#!#X on the way out.
    Jan 2011
    I was thinking about converting my fuel ex8 with the new Cane Creek Double Barrel Air, but the air can is so big, I'm not sure it would fit.
    Jackbooted Elitist Hipstr
    Reputation: Singletrack Pig's Avatar
    Anybody know if this mod will also work on a Rumblefish?
    Dirtbag since '89
    Oct 2011
    I am wondering what the spec on this shock is? I am looking to switch my trek fuel ex 9
    May 2012
    Hey guys,
    This is my first post on the forum and I wanted to thank the thread starter (dhalsey), great work and great write-up! I bought a brand new leftover 2011 Remedy 8 from LBS for cheap money and then proceeded to pretty much upgrade everything (except for the seat, seat post, and rear shock). At first I thought the DRCV shock would be great, given the reviews its a very decent air shock. However after a few weeks of riding at Highland Mountain Bike Park I've been unable to find a decent balance between sag and excessive bottoming out.
    Because I've already spent to much money on the bike I wanted to get a decent used coil shock, fortunately I just picked up an Elka Stage 5 shock in very good condition for little money. I bought the shock before coming across this thread and was sure I'd have to machine special mounts, at least for the upper mount. Thankfully I came across this thread which is a huge help, now I can't wait to get this shock and parts needed so I can get it installed! I'm especially excited to get rid of the tight tolerances in the lower shock mount, like dhalsey the stock lower mount on my Remedy was very tight (even though the lower main pivot was torqued correctly). Even with the upper mount removed it was very difficult to pivot the air shock on the lower mount.
    Not that anyone will care but I'll post back in the next week or so with photo's and my own experience with the conversion from air to coil. Again I can't thank dhalsey enough, this is really a huge help and beats either machining special mounts or trying to make it work with off the shelf hardware store parts!
    Aug 2010
    Awesome glad you liked it. Make sure you post up pictures. I'm interested to hear the results of the elka.
    Sent from my Galaxy Nexus using Tapatalk 2
    May 2012
    Unfortunately I'm not able to send private messages yet dhalsey but I was hoping you could help me out. I was able to order all the parts I need to convert my Remedy 8 to run a coil shock except for the Fox reducers (part # 803-03-046), I ordered them from CambriaBike but they won't get delivered until next week (but I want to ride this weekend)!
    With that said you mentioned in your article that you initially ran the RWC Needle Bearing kit on both the upper and lower mounts but had issues with excessive play which is why you ended up going with the Fox reducers on the upper mount. I'm curious how it was possible to run the RWC Needle Bearing kit on both the upper and lower mounts considering each mount has a different face to face width (the lower mount is 39.88mm and the upper mount is about 48mm give or take)?
    I couldn't tell from the photo you posted (when the bike was running the RWC on top and bottom) how you made the 39.88mm needle bearing kit fit into the 48mm wide upper mount? I'm asking about all this because until my Fox Reducers arrive I'm just going to run the stock Fox reducers (that I pulled out of the stock DRCV shock) in the lower mount and use the RWC Needle Bearing kit in the upper mount along with the RWC Max bearings which will reduce the bolt size down to 8mm. Thank you very much for taking the time to read this and for sharing your experience!
    Aug 2010
    I used the original drcv spacers that came with the rear shock originally on the bike I think I had to add spacers as well. get it on there annual find you might not need any spacers at all
    May 2012
    As stupid as it sounds I didn't even think about that until you mentioned it. So I just went down and measured the width of the stock DRCV shock (without the spacers), its 39mm-40mm. Once you add in the spacers its the same exact width as the upper mount, good thinking! Assuming the parts arrive before Friday I'll be up and running this weekend! Thanks again for your prompt reply and help!
    I'm trying to figure out could I install the Cane Creek DB coil to my 2011 Remedy and replace the DrCV shock. Fitting the shock will be very tight, if possible at all and the 10mm bolt at the top with press fit bearings complete the challenge, will have to think about the 8mm bolt to both ends.
    Dhalsey: how much clearance do you have at your bike between the seat tube and coil and what year your frame is? Could you upload a picture that shows the clearance?
    Jun 2012
    I stumbled on this page (like many others I'm sure) after searching for a way to replace the rp23 on my 2010 remedy with a coil. I'm over in the UK and wondered if anyone reading this has any knowledge on where I can source the required parts from?
    Also, are there any photos of the process? It just says "more photos" in the original post so I'm guessing there were photos once upon a time. If I could see them it would probably give me a lot more confidence to do this myself!
    Thanks very much.
    Jun 2012
    Ok. I feel a bit stupid now as the photos are working. I guess it must only be visible to registered users. Now I just need to find somewhere in the UK that can supply the parts.
    Thanks again for the original write up.
    May 2012
    Hi there unclesomebody,
    Like the original thread starter I also just converted my 2011 Remedy to a coil shock. Unfortunately I don't know of any other supplier that makes a needle bearing kit for mountain bike besides RWC (let alone specifically for the Remedy). With that said RWC (Real World Cycling) does ship outside the US and actually has very reasonable shipping prices and quick shipping times.
    Before actually buying the needle bearing kit from RWC I simply used stock Fox Racing reducers (bushings) to mount the coil shock and it worked just fine (the only drawback was the tight lower mount but this could be fixed by simply filling down each end of the bushing until there was limited friction).
    So basically I just pulled the lower bushings from the stock DRCV Fox shock and installed them into my 7.875" x 2.25" Elka Stage 5 coil shock (fortunately for me the Elka Stage 5 shock has the same dimension eyelets as the Fox Racing shock) so the bushings fit perfectly. That took care of the lower mount, although its not as good as the needle bearing kit it works just as good as the stock setup.
    The upper mount was a bit more work but after installing the RWC Max Enduro bearings the job was much easier (the new bearings have an 8mm opening which matches that of the stock Fox reducers that I had). These bearings can be purchased at RWC.
    I was unable to find the proper size Fox reducers that the thread starter used (45.72mm in length with an 8mm diameter opening) so I made due with the 35.56mm x 8mm reducer that came with the shock I bought (I bought the shock used from Pinkbike and the seller gave me his mounting hardware from his Rune). I then went to multiple local hardware stores and found what they called (Heavy Duty Steel Bushings), they were found in the traditional hardware store "nuts and bolts" section. They only came fractional sizes so I grabbed an 8mm bolt and found the bushings that fit best with the least amount of "play" (can't remember exactly what size this was but probably 11/32"). Basically I was buying these bushings to mount between the shorter stock Fox reducer I had (from the seller of the shock) and the Trek Evo Link.
    While there I also bought a couple stainless steel 8mm bolts, (8mm x 60mm 1.25 threads and 8mm x 65mm 1.25 threads), of course I also bought a stainless 8mm x 1.25mm nut (non nylon locking threads - just used blue locktite). This bolt would mount through the Evo Link, through the bushings, then through the stock Fox reducers, and out the other side holding the upper mount together.
    I realize this all sounds very complicated (especially without pictures) but once it was done it worked perfectly. Even though it worked great I now have the lower needle bearing kit installed which allows the rear-triangle to travel with much less friction than stock. If you want let me know your e-mail address and I'll send you a bunch of photos I took during the conversion, it might make the write up much easier to understand. Good luck and keep us posted on your conversion!
    Aug 2010
    Quote Originally Posted by TerminusAvid View Post
    How do you like the elka on the remedy?
    Jun 2012
    Terminus, thanks for the detailed reply. Very much appreciated! If you can email some pics to [my username]@gmail.com that would be really helpful. I'm fairly comfortable doing this stuff as long as I know roughly what I'm doing. It gives me some confidence that you guys have done it so I'm hoping I don't go too far wrong. I'll see what international shipping prices look like from RWC but my experience tells me that they are always far more than actual cost. I won't be stateside until September and definitely can't wait that long!
    In terms of what shock to run on the remedy, I've been recommended a van R. What are the other options? Is it just personal preference? I'll see what second hand options I can find in pinkbike.
    Thanks again.
    May 2012
    The difference was like night and day and once I started to get the Elka dialed in a bit things got even better. Granted this could have to do with my old DRCV not being probably setup or not being properly broken in but the Elka just felt much better! Although the DRCV is very linear for an air shock it just doesn't compare to the coil, I felt far more in control no matter where the rear-end was in the travel. This all helped me to feel far more confident on the bike and certainly helped me increase my in-control speeds on the trails. Last but not least, when running the DRCV I had difficulty with excessive bottoming out even with a minimal SAG setting - now I can run 25%-33% SAG and only occasionally bottom out on harsh hits. When measured side by side the Elka obviously weighs considerably more but I truly don't notice it at all when riding (probably because I mostly ride DH type trails) but even when just pedaling around its negligible.
    Jun 2012
    The good news is that I've acquired a Van RC! A very friendly local bike mechanic was really keen to do it for me and has the parts to do it (except the needle bearing - I'm wondering if there is an alternative) so I'm going to hand it over to him and let him work his magic. If anyone else in the UK ever comes across this thread and wants to do the conversion then drop me a PM. I'll update this thread with a progress report once it's done.
    Thanks again to dhalsey and terminus.
    May 2012
    That is great news man, glad you found a Van RC and even better a local bike mechanic who is willing to do the conversion for you and has the parts (even without the needle bearing I think you'll be just fine)! Although I'm not a bike mechanic I've always tried to do the work myself, its enjoyable for me and I love learning how things work, plus I've got all the tools needed and a shop which makes it much easier! If you or your mechanic have any questions please feel free to post them. I'll be looking forward to progress reports and maybe even some photos, good luck!
    Jun 2012
    Can someone give me the spec of the normal lower bush kit? I need to order some parts but don't know the size of the normal lower bushes and I don't have access to my bike until Saturday. If one of you knowledgeable gents could let me know I'd appreciate it.
    May 2012
    The lower stock bushing/reducer (the lower shock mount hardware) is as follows (at least on my 2011 Remedy 8),
    Bushing/Reducer Overall Length: 39.88mm
    ID of Bushing/Reducer: 8mm
    Post back if you need additional info or if I didn't understand your question properly.
    Got the DB shock home with the 10mm machined bolt, nut & spacers and installed the beast to my bike. Coil is 450 (lb/in) and my weight with the gear is about 176 lbs.
    First impression is that bike feels much solid now and is more efficient to pedal as it doesn't bob anymore, it also eats the small hits easily, will get to the bigger hit handling later as I have tested the bike more.
    At the rocker there are the Trek's original 10mm bearings, with the machined parts it installed like a dream and the coil side has the original 8mm bolt from the DrCV shock.
    [QUOTE=Nemesis-FIN;9421107] Got the DB shock home with the 10mm machined bolt, nut & spacers and installed the beast to my bike. Coil is 450 (lb/in) and my weight with the gear is about 176 lbs.
    Nice! Where did you get the "machined parts" you used? Are they the fox reducers folks have mentioned in this thread, or something else?
    Dirtbag since '89
    May 2012
    Nemesis,
    I am very impressed to say the least, that was a very smart way to make the coil work and it looks like a stock part! Although my upper mount works perfectly it looks like a two year old's science project compared to your setup, lol! Keep us posted with your thoughts on the conversion as you get more ride time on it (yesterday was my second full-day riding the coil and it truly feels like a different bike)!
    I ordered the machined parts with the shock, it didn't rise the price of the shock greatly. So it's not DIY really, but I thought that I'll post the pictures to help others with the installation and to give other option where it's not necessary to change the original rocker bearings.
    Correction to my earlier post: the reservoir side bolt diameter is also 8mm, NOT 10mm as I posted before.
    The bolt, adapters and the nut all have shoulders that sink in to the bearings to fit the 8mm bolt tight. The reason for that 8mm bolt for both ends was to give second option with the installation, the way it's installed now was however the only option since the piggy bag would touch the down tube if mounted upside down.
    Also worth mentioning is that Cane Creek does not give warranty to the shock used in this setup as the Remedy original shock was shorter. Maybe Elka, BOS, or Fox have different views about the warranty?
    May 2012
    If you don't mind me asking Nemesis where did you buy the shock and mounting hardware (I researched for hours looking for mounting hardware that would be a bolt-on job, basically I was looking for exactly the hardware you have now)! Even though my setup is working I'd still go out and try buying the upper mounting hardware you have. Thanks for your help and time with this, I realize you have already been asking many questions!
    I bought the parts from local Finnish store that sells and repairs shocks & forks. I'll assume that most of the shops (no matter what country they are in), that sell, maintenance/repair shocks and forks have access to the lathe for manufacturing custom spacers and other parts needed for mounting parts to different bikes.
    Making custom parts is easier for the shop if you take the bike there, but also possible if you take exact measurements with caliper.
    Jun 2012
    I'm still waiting on some parts to arrive but I did get an interesting email from a chap at Mojo (here in the UK). I asked for advice on how to get the Van RC to fit and he said this;
    Itís way simpler than that!
    If you go to pro-bolt they do Ti bolts for race motorcycles Ė pro-bolt.com or tastynuts.com!
    Go for a Ti 75 x M10 flange bolt bolt with a 1.25 thread and get the Ti flange nut to go with it. You can use the stock bearings in the linkage and the stock black aluminium DRCV spacers. If you go to our web store and order a bush kit that consists of your normal lower bushes (donít go for the needle bearings the wind up and bind, they DONíT work! Trust me Iíve tried them...) and a 39.88 x M10 steel pin bushing for the top of the shock. Bolt goes through the linkage, spacers inside the linkage bearings, 39.88 bushing between. Good luck!
    Hopefully my parts will arrive soon so I get cracking with this. My bike is being transformed at the moment as I'm also changing forks from 32 Float FIT RLC to Lyrik RC2DH. It's going to ride like a completely transformed beast when it's all finished!
    May 2012
    unclesomebody,
    Thanks for sharing that information with us, greatly appreciated! As stupid as it sounds I didn't even think to try looking for specialized nuts/bolts online (in hindsight it seems obvious that there are online retailers that carry just about anything you need)! By the way I think your new fork choice is an excellent one, especially since I did the same exact thing, lol! It was one of the first things I changed after buying the bike. I bought a 2012 RS Lyrik RC2DH (white in color with tapered steerer). Not that you asked but its been a great fork so far and a nice upgrade from the stock Talas 32 RL that came on my rig (please let me know if you have any questions about setup, servicing, or rebuilding as I just went completely through mine after only 15hrs on it).
    Nemesis,
    Thanks for your help and time!
    Jun 2012
    Qiuck update; I'm still waiting on the steel pin bushing kit to arrive but it should be here this week! I went out on the Lyrik's and can say they feel MUCH better than my Float 32 140mm Kashima. Initially I was a bit underwhelmed but once I got going I really noticed the difference. Now it's just the rear shock that needs to be upgraded in line with the front!
    In terms of rear shock compatibility, should any rear shock of the right size fit on a Remedy? This is on the assumption that it can physically fit. It would be great to see a list of all the coil shocks that people have used for this conversion. I'm worried that the Van RC is just a stepping stone to something more expensive... ha ha.
    May 2012
    From the research I've done unclesomebody just about any shock of the correct e2e length should work (the actual eyelet dimensions seems to be the same on most mainstream shocks, Fox, Elka, Cane Creek, Rockshock, etc..). Just keep in mind that some shocks might have different eyelet dimensions which would require modified mounting hardware. I might be wrong but most eyelet dimensions are 15mm ID without the DU bushing installed and 12.7mm with the DU bushing installed, basically you need 1/2" OD bushings to fit through the shock eyelet when the DU bushing is installed.
    According to RWC's website these are all compatible with each other (that is to say the eyelet dimensions are similar).
    FOX SHOCKS (ALL)
    ROCKSHOX MONARCH AND VIVID SERIES SHOCKS
    ROCKSHOX ARIO SHOCKS 2010 AND NEWER
    MARZOCCHI ROCO
    MANITOU SHOCKS 2011 AND NEWER
    ELKA SHOCKS (ALL)
    X-FUSION SHOCKS 2011 AND NEWER
    DIVERSE/DUELER (ALL)
    Jun 2012
    Thanks for the info terminus. I think I'll aim to get the Van RC fitted before moving any further or spending any more money! All the parts have now finally arrived so I'll be giving this a go over the weekend. If I don't come out on top then my friendly mechanic will be pulled in. Will try to post up pictures of the whole process...
    Also, as a side note, I accidentally ordered double the required parts, so I have 2 sets of bushings. If anyone is in the UK and wants to do this conversion then email me at my username at gmail dot come and I can sell you the required bushing kits for cheaper than anywhere else!
    PS. Once I get to 10 posts I'll be PM'ing you to find out about the Lyrik's (set up, servicing, etc).
    Jun 2012
    Could someone advise on whether or not I really need to remove the cranks to get to the lower pivot in order to remove the shock? Can't I just remove the shock (maybe after removing some air from the shock)?
    Jun 2012
    Good news. I've just said goodbye to air and hello to coil!
    Jun 2012
    https://www.dropbox.com/s/a9m956ldhr5o9dk/P1050165.JPG
    https://www.dropbox.com/s/dvxa5u7renr9un4/P1050184.JPG
    I can't tell you all how easy it was. Once I had the parts in front of me it literally took me 30 minutes (because I made a mistake at one point!). I've taken photos and will do a little write up in a minute.
    EDIT: Images aren't working, so use the links instead.
    Jun 2012
    I've done a write up with pics and a full breakdown of parts. Hopefully it will prove useful to someone!
    English man in Font Ľ Trek Remedy 2010-11 Coil Shock Conversion
    Can't wait to hit the alps in 3 days. Thanks to dhalsey for starting this thread and to terminusavid for helping me greatly along the way.
    May 2012
    I apologize for not staying up to date in the forum unclesomebody because I would have replied much sooner! With that said I'm very impressed with your conversion, you did an excellent job! I think your blog write up was also very good, in fact I find myself wishing I would have done exactly what you did because your method was much easier and much cheaper (as you mentioned there is no need to use a needle bearing for either the upper or lower mounts, like you I've heard nothing but negative opinions about them since I installed mine - figures)! Fortunately the hardware you used did not cost all that much money so I think I'm just going to re-due my conversion using your method (if you don't mind), lol? Thanks again for keeping us posted and please write back once you have some more time riding the coil, I'm curious about your thoughts. In my case I still think it was one of the best investments I made on my Remedy - the bike feels more solid overall and far more plush than with the air can!
    Jun 2012
    Just got back from the alps a couple of days ago. This was my first outing on the coil remedy and I am honestly blown away. This bike made a lot of people look very stupid as a guy with a single crown all mountain bike came blasting past them on their full on DH machines. It's hard to describe just how capable this set up now is. I didn't do a lot of pedalling up so I can't give an honest opinion of how it pedals but I can give a very honest opinion of how it descends/jumps.
    The coil is another league from the RP2 that it replaced. It's difficult to measure how much more plush it is but the Van RC has performed admirably. Whether it was tearing down a green/blue/red/black run, it always felt very planted in the rear. Hitting some decent sized drops/jumps/gaps and the difference was even more apparent. Landing was always a smooth affair and the bike made me look like a much better rider than I really am.
    I was filled with confidence and pushed things as hard and far as I could. This culminated in a crunched back wheel (literally snapped the rim) when I came up 6" short on a fairly large step down river gap. Luckily the bike shops are very capable out there and 2 hours later I went back up with a new wheel and finished it off.
    However, by the end of the week I was left wanting... wanting something with a tiny bit more travel. I saw a lot of Session 88's out there and definitely had a bit of envy. I also saw a couple of Scratch's (a much rarer bike than you might think!) and that is probably where I'll head next. One guy on a session commented that I had a "nice bike" and only after saying it he realised it was a Remedy! Perhaps the 150mm travel will do for now, especially in England, but I think the next big trip will require something with a bit more travel. I do think it's a bit crazy to chase a Scratch for another 20mm travel so we'll see what happens...
    In conclusion, if you are reading this and you have a remedy with an air shock then don't think twice about following the instructions above and putting on a coil shock. The coil has made this bike a monster. The weight penalty is so minor when compared to the fact you'll end up with an all mountain machine that probably can't be beat in my opinion...
    Thanks again to the original fella's on this thread; you're responsible for my insanely amazing week of riding in Les Gets/Chatel.
    Reputation: Highwaystreets's Avatar
    hmmmmm very interesting.... this is tempting to say the least. Does anyone noticed any loss of performance when peddling uphill?
    Current Rides:
    Trek Stache
    May 2012
    That was an absolutely perfect description unclesomebody of the difference I experience once installing a coil on my Remedy, I've tried to articulate it a few times but you summed it up perfectly! I've now got about 20hrs of riding with the coil at Highlands (local mountain bike park) and you hit the nail on the head in regards to wanting a bit more travel, because I've spent more money on my bike and gear this year than I expected I'll probably finish out the year on the Remedy but like you I'll be going after something in the 180mm range - hell I sometimes wish I just built a damn DH rig instead of dumping all this cash into building up the Remedy (for now I'll just try to enjoy riding and pushing this Remedy to the edge)!
    Man, you guys are really making wish I had gone the Remedy route instead of the Rumblefish... I just HAD to have those 29in wheels. Now all I want is something with little wheels and more travel, and now with a coil. Maybe I could fit a coil on the Rumblefish... Nah, not worth it.
    Or is it... Time to do some research.
    Hi,
    should the conversion work the same way for the Remedy 2012 models?
    Jun 2012
    I couldn't say for sure but I would think it's very similar. You could post a photo of the top and bottom mounts, along with details of the mount width (ie. 43mm) and the shock length (ie. 200x57mm). If all of those are the same then I suspect it will be exactly the same. I would be surprised if you couldn't swap the shock fairly easily...
    Jun 2012
    In case anyone's interested, here's how my Remedy currently looks;
    May 2012
    What a difference a coil makes! That is an awesome setup you got there, can't tell what your running for brakes but those rotors are sick! By the way would you mind sharing what your running for settings on your Lyrik (High/Low speed compression and rebound) and about what weight you are? I've actually had to modify the settings quite a bit as the fork broke in, its only been in the last couple weeks that the fork has really started to go through all of its travel. I'm running (from fully counter clockwise) 5 clicks on the HS, 6 clicks on the LS, and 18 clicks on the rebound - I'm about 194lbs with riding gear (oh yeah I also run about 65lbs in the air spring). Thanks for posting your ride unclesomebody!
    Jun 2012
    The brakes are Hope M4 Evo up front with a Hope X2 Evo on the rear. Interesting that you mention you weren't getting full travel on your forks for a while. I didn't think I was getting full travel on mine but after a rather large drop I noticed the little red marker had gone all the way to the top stanchion! Most of the time it didn't seem to be bottoming out. I'll send you an update on my fork settings once I get back to my bike (probably the weekend). I'll PM/email you so I this thread doesn't go too off topic.
    Any updates on how it climbs with the coil as compared to stock?
    Current Rides:
    Trek Stache
    Here's mine, I followed unclesomebodies instructions ... thanks again for the blog post.
    The bike rips, I wish I've done it sooner. Weight difference is negligible and with turned LSC to max there's almost no bob at all.
    Jun 2012
    Nice work devaHT. Looks very clean. Welcome to the coil club. It's the future!
    Quote Originally Posted by Nemesis-FIN View Post
    What size Cane Creek DB coil is on your Remedy? Is it a Remedy 9.8?
    Sorry for the late answer, my operating system disappeared during partition format (and drinking whiskey) and I had to install everything again... =)
    The answer your question;
    My bike is 2011 Trek Remedy 9.8 and the CCDB coil size is 2,25/ 500lbs (200x57 shock) and I'm ~85kg= 187,4lbs with full gear. I didn't want to change the bike geometry (the CCDB is about 4mm longer than the Trek's original shock), so I installed 160mm RS Lyrik coil fork (the coil is better for winter riding also, I had problems with Talas fork last winter).
    I tried the 450lbs coil first but find out soon that it wasn't enough for the type of riding I do. Now the 500lbs coil has been in the bike about 2 months and I'm pretty happy with all settings at stock except the LSC, to compensate the harder coil I made the LSC 4 clicks to the "supple" direction.
    How much did the 200x57mm CCDB coil with the additional 4mm shock length raise the BB when unloaded? How does it handle with 160mm fork(Lyrik)?
    Im very interested in this conversion. I have a trek slash Im thinking about converting. What size shock would I use? The stock size is 8.25x2.375. The closest matching size is 8.5x2.5 will that work?
    Quote Originally Posted by fcaw11 View Post
    I didn't measure the BB height with the original shock and fork so I can't tell the difference.
    The bike feels more solid/ sturdy now on descends and it still pedals well uphill, only limited by skills of the rider and I don't even use the U-turn because we don't have big mountain climbs here, just constant up and down. Recently I switched the stem to 50mm and handlebar to 720mm and the Joplin to the KSi Lev and those felt like good changes also.
    The bike absorbs small bumps now without a notice, it's so smooth that it feels like pedaling on the street and I haven't yet bottomed out the fork, or at least I haven't noticed it. IMO the Remedy could have 2 build options, one for air and other with full coil.
    I'm not going back to the air shock/ fork combo anyway. The Blackspire Defender 120bcd chainguard is the final step and then my bike is done
    E to E length
    Has anyone noticed a difference in the geometry when installing the the coil or other aftermarket shock?
    The stock DRCV size is 7.75X2.25 (according to the trek website and Fox's website) and the closest e to e in an aftermarket shock is 7.87X2.25.
    Thanks,
    @Nemesis-FIN
    What size 2011 Remedy frame do you ride? I am considering this conversion for my 15.5" frame.
    Reputation: socalMX's Avatar
    Quote Originally Posted by Ominous View Post
    Im in the same boat! The Slash needz a new shock! Any help please!
  67. #67
    Ive been doing alot of reading, and so far the only Shock/Manufacturer I could find that may work for the Slash is Avalanche.
    http://http://www.avalanchedownhillracing.com/chubie.html
    The Chubie is 8.25x2.25, not an exact match but pretty close. I don't know how much of a difference that .1mm would make. However that's alot of dough to drop for something that may not work. Its a bit frustrating. I really wanna drop a coil in there.
  68. #68
    I contacted ISOTUNED suspension here in Southern California and they do a custom fitted RS Vivid Air for the Slash for $500 direct from RS or $700 custom tuned! They claim that the Vivid Air has an awesome coil feel! I will call Monday to find out if they can make the upper hardware kit for any other shocks! The Slash would be sick with the Vivid Air RC2 matched to a Lyrik RC2DH!
  69. #69
    Nice find, I think even a Vivid Air would be an improvement over Stock. I dont think the Rp2 stock works well for a bigger rider as the riding get more aggressive. Think ill give these guys a call come monday and get some more info! By chance do you have link or info?
  70. #70
    Easiest way to contact them is here- ISOtuned on Pinkbike
  71. #71
    Nov 2012
    Installed my coil today big shout out to unclesomebody and nemisis-fin for all the info posted up here, 2010 Remedy 8!
  72. #72
    Aug 2010
    Sweet, can't wait to try this.
  73. #73
    Reputation: CaRaBeeN's Avatar
    Mar 2012
    Have you already figured out if 8.5x2.5 works for slash?
  74. #74
    Quote Originally Posted by CaRaBeeN View Post
    Too long! I no longer have the Slash frame as I traded it for a carbon Remedy but I pulled the 8.5 x 2.5 shock off my Yeti to try it and would need to compress it just to get the bolt through!
  75. #75
    Mar 2012
    Quote Originally Posted by socalMX View Post
    Well then one size smaller is 7.875 x 2.25 (for fox) which would be too small to effect geo negatively!
  76. #76
    Dec 2012
    what type of marzocchi bomber fork is that
  77. #77
    I used the same spacer kit for the coil but decided to try the new CTD shock! Im really liking it so far!
    Attached Thumbnails Attached Thumbnails DIY Trek Remedy 10-11 DRCV Coil conversion-trek3.jpg
  78. #78
    Jan 2013
    Hi,
    Great write up, but I am just unclear on a certain part of the process. This could be due to the fact that I am not an expert when it comes to biking mechanics. The part that confused me is the purpose and implementation of the homemade press. Please elaborate and dumb it down better for me.
    Mar 2013
    what year is it
  80. #80
    Mar 2013
    does .1 of a mm make any difference???
  81. #81
    Jun 2012
    what size shock is this? any particular length? this is not a proprietary size shock is it? i'm researching for a friend. thanks guys.
  82. #82
    Mar 2013
    what size shock do you use because treks Length is 7.75x2.25 and fox only have these ones, so is it better to short shock it with 7.50x2.00 or go over and risk it being too big by getting the 7.875x2.25??
    Length / Travel
    7.50 x 2.00
    7.875 x 2.00
    7.875 x 2.25
    8.50 x 2.50
    8.75 x 2.75
    9.50 x 3.00
  83. #83
    Mar 2013
    Quote Originally Posted by Mr. Moco View Post
    Thanks,
    i was wandering the samething
  84. #84
    Quote Originally Posted by Aussie_Remedy View Post
    what size shock do you use because treks Length is 7.75x2.25... "SNIP"
    I went with the 200x57mm Cane Creek DB (FOX DRCV shock 7.75x2.25= 196,85x5715mm), the rear linkage had to be pushed open a little when I installed the shock and by little I mean about 2-3mm, if even that much. After the shock was in place the geometry was so little changed that I didn't notice it at all.
    Only when I changed the fork to 160mm there was a small, but noticeable difference when pedaling uphill, the front was now lighter than with the standard fork (specially if Talas was dropped to 120mm, then it climbed really well). However the benefits when going downhill with 160mm fork were greater than the small worries when going up.
    And after that I guess climbing with the 160mm wasn't difficult enough (sarcasm LOL) because I had the Lyrik U-Turn travel changed to 170mm with DH-model parts and at the same time it was shimmed properly.
  85. #85
    Mar 2013
    Hi I have a medium trek remedy 8 with the stock 7.75x2.25 DRCV shock. And I was wondering if it is possible to fit a larger shock to boost the travel. Does anyone think a a 8.5x2.5 shock might fit? DHX Air 5.0 Bike Shock | FOX. It doesn't seem like any good companies make shock that is 8x2.5
  86. #86
    Quote Originally Posted by 2012bikerguy View Post
    9.8 has very little clearance with the coil, about 2,5mm from the seat tube (with CCDB 200x57mm), so I couldn't fit the 2.5" (63mm) wide shock at least, not sure about the Remedy 8 frame though.
  87. #87
    Mar 2013
    personally if you were going to change the shock stick with the 7.875x2.25 because it is over size already by 2-3mm and if you go any more it could change the geometry where the extra 2-3mm doesnt so i personally would go with the 7.875x2.25
  88. #88
    Mar 2013
    was that on a 2013 Remedy or was it 2012??
  89. #89
    It's 2011 Remedy 9.8.
  90. #90
    Mar 2013
    I'm looking for a frame with a little more travel, in like the 170-180mm range. I am trying to be as cost conservative as possible. Anyone know of a good bike like that. I am trying to spend less than 1300.
  91. #91
    I just installed a CCDB on my 2013 Remedy 8. Big thanks to unclesomebody for the guide, I used the same parts he listed and everything fits like a glove.
  92. #92
    Oct 2012
    Great looking conversion, mmmike! What's the length of your new shock?
  93. #93
    Mar 2012
    And how's the ride changed? First impressions?
    2012 Trek Slash 9
    2012 Trek Session 9.9
  94. #94
    Mar 2013
    Quote Originally Posted by mmmike View Post
    Looks amazing I have the same bike and size?
    What size shock did you use I'm very very interested because I think it is different to other year models?
  95. #95
    Quote Originally Posted by tryinghardrider View Post
    The shock size is 7.875x2.25.
  96. #96
    Won't be able to ride it for a couple weeks due to leg injury from road biking. I haven't even set the sag yet.
  97. #97
    Mar 2013
    Does anyone know how it rides compared to the stock DRCV. Does it take big hits a lot better, does it make pedaling uphill noticably harder?
  98. #98
    Jan 2009
    I did the conversion using UncleSombody's instructions. Thank You, the fox part numbers were a big help. I used a 70mm bolt and it fit a little better. For reference I'm ~195lbs. and used a 500lb. spring.
    I've done a few rides so far. There are definitely some pro's and cons to this. Overall it's a keeper. The small bump tracking is excellent. I had the air pressure in my RP2 fairly high to handle bigger drops. The trade off was the back end being too stiff for the rock gardens. With the coil, the bike feels as it should through the rocks. However, the frame with its falling rate ratio, feels too soft in the end stroke. Now that can be fixed with a better shock. I haven't bottomed out harshly yet, so I will just live with the end stroke mush. The other con is pedaling. Now the bike is a sit and spin bike, standing up and mashing is no longer an option.
  99. #99
    Jun 2013
    does anyone ride a larger Remedy frame, and have done this conversion? I have 21.5 frame, and looking at doing the conversion. should i be staying with a 7.785 x 2.25, or could i sneak up to a 8.75 x 2.75 (fox rc4) without messing with the Geo of it all? Thanks!
  100. #100
    Feb 2013
    I think that would raise the bb. It would also mean at full travel the wheel would probably scrape your butt.
  1. Trek/Fox DRCV Shock
    By Cutbert in forum Trek
    Last Post: 01-10-2013, 10:34 AM
  2. DRCV in trek EX 6
    By davechen in forum Trek
    Last Post: 05-11-2011, 02:39 AM
  3. 2010 Trek DRCV Shock on 2009 EX 8
    By fritz's_suby in forum Shocks and Suspension
    Last Post: 07-12-2010, 08:22 AM
  4. Will Trek support G2 forks and DRCV 140mm shocks?
    By monteverest in forum Gary Fisher
    Last Post: 06-22-2010, 07:13 AM
  5. Remedy Coil
    By tombate911 in forum Trek
    Last Post: 10-25-2009, 10:22 AM
Members who have read this thread: 4
