Results 1 to 7 of 7
    Did Klein Attitudes ever run the cables along the top tube?
    If so, what years did they do this.
    On another forum there is a chap saying he has an Attitude Race that looks a similar colour to my '02 but that the cables run along the top tube rather than being internally routed.
    Not really knowing the Klein history too much, could this be the case and if so, roughly when was it done.
    My frame is a 2-tone blueish colour with a slight hint of green to the blue.
    Carsten
    Guest
    Quote Originally Posted by donboyfisher
    the 1999 (only that year) Attitudes had all cables routed externally.
    like this one
    http://cgi.ebay.com/ws/eBayISAPI.dll...m=250003964741
    Carsten
    thanks for that - all the pics i'd seen so far had internal routing so i couldn't figure it out.
    Jun 2005
    Quote Originally Posted by Carsten
    like this one
    Carsten
    I have one also... I received the frame and built it up in 2001, so the 1999 date seems about right. All the cables run across the top tube, and it has disc mount on the rear... Mine's red and I was told it was a one off color.
    tt
    Weird. I thought I had a '99 Attitude Comp, and my cables are all internal... maybe mine's a '00?!
    No mounting points for discs, though. Bummer!
    Carsten
    Guest
    Quote Originally Posted by 99klein
    does it have the barrel shaped head tube with a smaller diameter at the top and bottom? then it would be a 2000 or younger.
    if it has the "normal" head tube with constant outer diameter and a non-replaceable rear der hanger it is a 1997 or 1998 frame.
    Carsten
    Yeah, its got the barrel shaped head tube. As for the rear der hanger - I can't remember off the top of my head. I'll check tonight.
