    Jun 2012
    Cannot dislodge Fox rear shock from Fuel Ex frame
    Hi
    I am attempting to remove the fox rear shock from my frame for the first time to service.
    The top 2 bolts have been removed from the EVO swingarm and the shock is free of the swingarm. However the bottom single bolt that holds the stanchion end of the shock to the full floater extension of the chainstay has been removed but I cannot seem to pull the shock out. Should this pull out or is there another step involved to free the shock?
    Should I tap it lightly with a soft hammer?
    BTW, my frame is a 2012 Trek Fuel Ex. Top of the can is bolted to the swingarm and the stanchion end is wedged between the floating extension of the chainstay (full floater).
    Thanks for your assistance
    Old N Slow
    Reputation: Hound's Avatar
    Dec 2012
    If you can loosen up the bolt at the frame pivot you should be able to remove the shock. Had a similar problem on my 9.9.
    Jun 2012
    Quote Originally Posted by Hound View Post
    Thanks hound your advised worked a treat to get the shock refitted after service!
    Old N Slow
    Dec 2012
    Glad I could help.
  1. Cannot dislodge Fox rear shock from frame
    By Red Ant in forum Shocks and Suspension
    Last Post: 03-10-2013, 05:02 AM
  2. upgrading rear shock on fuel?
    By joshman108 in forum Trek
    Last Post: 03-07-2013, 01:45 PM
  3. Fuel EX8 rear shock lockout
    By stygz1 in forum Trek
    Last Post: 10-02-2012, 05:35 PM
  4. 2011 Fuel EX6 rear shock..
    By bamxiv in forum Trek
    Last Post: 07-13-2012, 05:53 AM
  5. 2011 Fuel EX 8 rear shock
    By joshhan in forum Trek
    Last Post: 03-28-2012, 03:56 PM
