Results 1 to 10 of 10
Thread: Broken crank!
    almost there!
    Reputation: AJ541's Avatar
    Sep 2003
    Broken crank!
    Well I've broken my 1st crank, I was climbing a short steep hill and suddenly the left pedal felt all wobbely, I thought my cleat came loose. After 4 years of racing and riding I guess everything will eventually break (Bontrager Select from 2002 Big Sur):
    Reputation: hallin222's Avatar
    Note that this proves that aluminum does NOT have an infinite life like steel does regarding repeated loads which are all applied with a force well below their yield strength. Sorry, that was the mechanical engineering degree talking. What I meant to say was: Wow, dood That's wicked awesome! You ah like SO my freekin' hero!
    Ian
    niiiice
    is the crank solid the whole way through?
    almost there!
    Sep 2003
    Ya it's solid.
    CURB HUCK!!!!!!
    WOW, think about all these new hollow cranks out, i wonder what kind of life they're going to have
    Kona Coiler
    about the same as a solid crank because the material close to the neutral axis has very little effect on the strength.
    On MTBR hiatus :(
    Quote Originally Posted by frknlitebike
    Agreed. That failure is likely the cause of a surface ding / gouge that eventually carried through.
    Given the condition of the crank arm (pretty banged up all around), this isn't so inconceivable. However, given the location of the start of the failure (on the "backside" of the non-driveside crank, close to the bottom bracket), that's pretty friggin' odd.
    AJ, do you recall any significant dents or scratches in this location prior to the failure? Honestly, that's creepy! How'd you ride out?
    speedub.nate
    MTBR Hiatus UFN
    possibly a hard landing with the cranks horizontal and taking all the body weight caused the initial stress?
    I have to say, i've never considered a crank as a fail component if you know what i mean. I've always assumed the frame would break first.
    almost there!
    Sep 2003
    Quote Originally Posted by Speedub.Nate
    There is a small ding that is 2mm away from the start of the crack.
    No large or noticeable dings where the crack started.
    I do find it odd the crack is 40 mm from the centre of the bottom bracket and it is a 175 mm crank. What I mean is it is so close to the centre, you would think it would crack further out.
    I rode with one leg when I was on the flats and walked up the hills. The crank is actually still quite solid - I can't bend it with my bare hands.
    rad to the power of sick
    Reputation: superlightracer's Avatar
    My LX hollowtechs from 2002 with 12000km on em just gave way. The spider is moving around 2-3 mm on the crank... So yea there is another example of fatiguing cranks
    Some great sets for the trainer:
    http://soundcloud.com/deejayfeelgood
