Results 1 to 7 of 7
    I Tried Them ALL... SuperModerator
    Reputation: Cayenne_Pepa's Avatar
    Bontrager RXL Scandium 29er wheels
    Can the hubs be modified to take 15mm thru/front and 142x12mm rear? Or, are the RXXXL carbons the only exception?
    "This is a male-dominated forum... there will be lots of Testosterone sword-shaming here" ~ Kenfucius
    Yup. I believe if you buy the wheelset aftermarket it comes with all of the adapters for any of the axle conversions. They also come with the tubeless kit.
    Nov 2012
    This is the million dollar question. I did tons of research on this (as you know, I'm selling a pair of RXL wheels) apparently the ones that come with new bikes are NOT convertible but the aftermarket ones as seen on bontragers website are made with dt swiss 240 hubs and are convertible and they include the conversion pieces when you purchase. The set that I have are already 15mm front and 142 rear and there are options to easily get qr on the front if someone really wants it but there doesn't appear to be an option to go to 135 on the back though I'm sure someone could fabricate something.
    I found a guy on eBay who hand-machines billet alloy 15mm>9mm QR adapters. These simply slide straight into the 15mm front hub and is secured by two o-rings. This is about the best, precision axle reduction you can buy to date:
    Mountain Bike 15mm thru Axle to Standard 5mm Quick Release Wheel Adapter | eBay
    And, here is his rear 142x12>135x10 QR bit. Get all the benefits of thick axles, while running your old QR forks and frames:
    Mountain Bike 12mm thru Axle to Standard 5mm Quick Release Wheel Adapter | eBay
    Nov 2012
    Re: Bontrager RXL Scandium 29er wheels
    I have seen those and knew it could.work up.front I just can't visualize how the rear can possibly work
    Sent from my DROID RAZR using Tapatalk 2
    Nov 2012
    Zachariah, I still cant conceptualize how this can work in the rear. I took my set of bonty wheels and put them up to my frame and the front is obvious; the 15 thru ax hub is still spaced at 100mm so the adaptor slides through the hub and has the little nubs on the end to rest in the dropouts or you get a DT SWiss 9mm rws thru bolt and that will rest in the dropouts and clamp the wheel in. But I can't picture how the rear can work because the hubs are 142x12, not 135. Without being able to remove the endcaps, I must still be Shittouttaluck with the rear wheel.
    I really love the look of these wheels, I'm wondering if I should see if I can find a hub with the same dimensions and just relace the wheel. I'd like to get a chinese carbon frame with the 142 rear end but it's just not in my budget right now
    Yeah, there is NO WAY your 142x12 RXL will ever fit inside a 135x10 rear dropout...
  1. Bontrager AT-650 wheels - need info
    By shyamrox in forum Trek
    Last Post: 04-04-2013, 11:37 AM
  2. Bontrager 29er wheels tubesless info
    By likeaboss in forum Wheels and Tires
    Last Post: 06-25-2012, 11:53 AM
  3. Bontrager Mustang Wheels 29er
    By cycling51 in forum Wheels and Tires
    Last Post: 10-27-2011, 05:18 PM
  4. Bontrager Rhythm Pro Scandium actual weight
    By noot in forum Wheels and Tires
    Last Post: 08-30-2011, 04:05 PM
  5. Gary Fisher RIG Rigid 29er w/ Bontrager Wheels
    By vtwfo in forum Wheels and Tires
    Last Post: 07-28-2011, 06:35 PM
