Results 1 to 6 of 6
    Dec 2012
    Bontrager AT-650 wheels - need info
    Hey All,
    Can anyone provide me with any information about the Bontrager AT-650 wheelset? I'm looking for weight, inner and outer rim width..
    I can't seem to find any specs on this wheelset online. I'm trying to find out if the Sun Ringle Black Flag Comp or the Charger Expert would be a significant upgrade to the AT-650 wheelset. I'm hoping they are significantly lighter...
    Shyam
    Reputation: Britishnate's Avatar
    Yes they will be a significant upgrade. If for nothing else than the Sun Ringle's are tubeless ready but I know they are a lot lighter.
    Are you talking 26" or 29" wheels?
    Dec 2012
    Thanks BritishNate - I'm talking about 29" wheels.
    I'm torn between the blackflag comp (lighter?) or the charger expert (more durable?) ...any opinions there?
    The AT-650's that came on my Cobia weighed in at 1080 Front and 1275 Rear. I dropped almost a full pound switching to Arch/CK.
    Quote Originally Posted by shyamrox View Post
    I had looked into both of the wheelsets at one point. I contacted Sun Ringle and was told that the Black flags are an XC wheel that if you are conscious of the lines you pick would be great but the Chargers are more of an all mountain rim that will take more of a beating. I think part of it depends on how tough you are on your parts and how heavy you are. I know for me being 225lbs I was a bit concerned with the black flags but I am sure you will do great either way. I have seen the Black flags 29" in person and they are a well built wheel. I have also seen the Charger pro but in a 26".
    Hope this helps.
    Dec 2012
    That helps a lot! I think I'm going to go with the Black Flag Comp mostly because its QR, 15/20 through axle compatible so I'm not limited when I eventually upgrade the fork - I'm about 165 without gear...the only gear I put on is a helmet & gloves I'm mostly doing just XC, rolling through small rock gardens and over logs...no huge drops or jumps..
  1. Bontrager 29er wheels tubesless info
    By likeaboss in forum Wheels and Tires
    Last Post: 06-25-2012, 11:53 AM
  2. Bontrager Mustang Wheels 29er
    By cycling51 in forum Wheels and Tires
    Last Post: 10-27-2011, 05:18 PM
  3. Bontrager wheels + tire bulges
    By charron34 in forum Trek
    Last Post: 04-07-2011, 11:56 AM
  4. Trek 8000 Bontrager wheels
    By carbonsnail in forum Trek
    Last Post: 02-19-2011, 10:33 PM
  5. Bontrager Ti Lite ~ Info
    By idoru in forum Vintage, Retro, Classic
    Last Post: 06-10-2004, 03:45 PM
Members who have read this thread: 13
