Results 1 to 5 of 5
    Jun 2013
    Bontrager 29-3 Expert tire - tubeless?
    I have a 2013 Trek Rumblefish (base model) with Duster tubeless ready rims. Can the stock tire (29-3 Expert) be setup tubeless or do I need to buy TLR tires?
    Reputation: 722ish's Avatar
    I have the xr3 expert on my fuel ex 29, and I had a set of rhythm comp wheels with the cheap 29-3 model mounted up, both tubeless with absolutely no issues for years on the rhythms and for about 8 months now on the fuel. I have used both Stan's sealant as well as caffelatex and have had good luck both ways for sure. The argument can be made I suppose that TLR tires are stronger and better suited to running tubeless and so on, but I haven't had a single issue and I'm 230 and change, and run 17-24 psi depending on how dry and sandy it is etc. I've taken the fuel off 3/4 foot drops to flat with not a single issue as well on the factory dusters fwiw. I know most won't advocate doing do, but I've had no problem with it.
    Sent from my SAMSUNG-SM-N900A using Tapatalk
    10 Gary Fisher Cobia - 13 Trek Madone 5.2 - 14 Trek Fuel Ex8
    Reputation: Robg68's Avatar
    Oct 2013
    I asked the same question at the Trek store where I bought my bike and they said yes. So I bought the tubeless rim strips some Stan's sealant and stems and haven't had any problems.
    Bikes I currently have. 2014 Trek Fuel EX 8 29er. 2013 Trek Mamba 29er.
    Reputation: MTBeing's Avatar
    Re: Bontrager 29-3 Expert tire - tubeless?
    FWIW, I set the 3 Comps up tubeless on a Bonty XR850 rim with ease. 1 layer of Gorilla Tape. No issues. Great tires (but heavy as hell).
    Please donate to IMBA or your local IMBA chapter. It's trail karma.
    Reputation: DethWshBkr's Avatar
    You're good to go.
    My '14 Fuel EX8 29er came with the same Duster 29ers, and 29-3 expert tires.
    Get the actual bontrager tubeless rim strips and valve. PERFECT fit (obviously) and it is excellent. I used the Stan's goop, and no problems.
  1. Bontrager XR3 Expert
    By zachkh in forum Trek
    Last Post: 03-10-2014, 05:08 PM
  2. tire compatibility with Bontrager Race-Disc Tubeless
    By LewisQC in forum Wheels and Tires
    Last Post: 08-23-2013, 10:59 AM
  3. Bontrager Expert 29-2 Tubeless??
    By tailwaters in forum Wheels and Tires
    Last Post: 06-10-2013, 12:01 PM
  4. Comps to Bontrager XR4 Expert, 26x2.35"?
    By weekendthrasher in forum Wheels and Tires
    Last Post: 06-20-2012, 08:39 AM
  5. Bontrager 29-1 Expert, 29x2.2" Tubeless ready?
    By Graysku11 in forum General Discussion
    Last Post: 04-19-2012, 03:50 PM
