Results 1 to 2 of 2
    Anyone try this kit to run a BB30 spindle crankset in your Trek's BB95 shell?
    BB92 TO BB30 BOTTOM BRACKET KIT
    Intrigued.
    Also, wondering if any of the new Race Face 30mm spindles will have a kit to run in Trek's bb's.
    Nov 2013
    The Trek BB95 shell has an ID of 37mm. This BB92 kit appears to have bearings that are designed to fit in a shell with a 41mm ID and therefore are incompatible with Trek's BB. I just don't think it is physically possible to make a 37mm OD/30mm ID press fit bearing. If you are set on a RaceFace crank then you may want to look into contacting them direct to see if they have any new 2012 24mm spindle cranks left in stock. I just bought a new 2012 Next SL this past August for a Superfly Comp I was building.
  1. Need Advice - BB30 shell out of spec
    By JNG in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-20-2012, 11:46 AM
  2. BB30 hollowgram spindle question
    By bubba888 in forum Cannondale
    Last Post: 07-30-2012, 07:10 AM
  3. Shimano cranks on BB30 shell
    By fredy_signer in forum Cannondale
    Last Post: 05-24-2012, 12:59 AM
  4. Replies: 4
    Last Post: 04-27-2012, 01:10 PM
  5. Help: BB30 crankset with std BB shell ?
    By eric_syd in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-16-2011, 08:21 AM
