Results 1 to 13 of 13
    Reputation: Just J's Avatar
    Feb 2005
    Anyone have any experience of using the tubeless kit on Duster rims?
    I've just picked up the tubeless rim strips for my Stache's rims, I was surprised to see they were literally just a rim strip, no tape and just designed to run with a Stans valve.
    Just wondering if you guys had any experience of this setup, if you used any tape and how you got on with the kit?
    Reputation: shenny88's Avatar
    As long as you got the Rhythm rim strips, it should work. Not the exact same, but i've used TLR strips on Mustang rims, which was fine because theyre the same shape as the RL/RXL series. So, i think the Dusters are the same profile/shape as the Rhythm series.
    You may want to use Bontrager valves, the Bontrager tubeless rim strips are keyed specifically for them. You will not not any rim tape. Super easy conversion have fun!
    Feb 2005
    Thanks guys, I assumed they would have arrived with the valves but I'll try them with the stans ones first and see how I get on.
    Feb 2005
    Just checked the Bontrager site and their valves look exactly the same as the Stan's, so we should be good! I'll let you know tomorrow though! 😄
    Feb 2005
    Worked perfectly and definitely a much easier system to fit than Stans own kit, their valves work fine with the Bontrager rim strips though. Seated first time and after a 40psi inflation, dropped them down to 30. Should keep their air after a couple of rides, I'm guessing...
    My bike went from 26.75 down to 26.1 lbs (with pedals, light mount, Garmin mount and bottle cage) so not a bad weight saving.
    I hate that name.
    Reputation: blunderbuss's Avatar
    The Bontrager mtb TLR valves have a round base which fits into strip. The Bonty road valves are the rectangular ones that look just like Stan's.
    Worked at Trek/Fisher dealer 2008-2013. Only a little biased.
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by Just J View Post
    The Bonty valves are NOT the same as any other brand. They have a metal base with a rubber O-ring. Very secure, reliable and durable. I have been using the same pair since 2004. Same TLR rimstrips, too.
    mtbtires.com
    Feb 2005
    Yup I'm having big issues keeping air in my tyres so I'll be swapping out for the Bonty valves this week.
    psycho cyclo addict
    Reputation: edubfromktown's Avatar
    Left one is Bonty, right is Stan's. Makes a huge difference using the proprietary ones.
    【ツ】 eDub 【ツ】
    Feb 2005
    Quote Originally Posted by edubfromktown View Post
    That's fantastic thanks for sharing. I'm using the Stan's one on the right but will make sure I fit the Bontys as soon as possible.
    Feb 2005
    Picked the Bontrager valves and swapped the Stans ones out, everything was nice and straight forward, they seated nicely on the rim strips. Got up this morning and they haven't lost any air, I'd go as far to say that this is the best tubeless kits I've used, at least in terms of setup and everything points to them being right up there in use too. Very happy and thanks for all your helps with this, I think I'll use the Stans valves on a ghetto setup for my Crossrip.
    Sep 2013
    I have the official kit in my Fuel. Really happy.
  1. My experience going tubeless on Pacenti DL31 rims
    By GTscoob in forum Wheels and Tires
    Last Post: 09-03-2013, 12:09 PM
  2. Duster rims?
    By noosa2 in forum 29er Bikes
    Last Post: 09-24-2012, 12:14 AM
  3. Tubeless on Mavic X139 Rims - Anyone with Experience?
    By desertred in forum Wheels and Tires
    Last Post: 05-27-2012, 03:19 PM
  4. which rim strip for my Duster rims
    By noosa2 in forum Wheels and Tires
    Last Post: 09-23-2011, 05:12 PM
  5. Duster Rims clicking
    By hysteriamk2 in forum Trek
    Last Post: 03-03-2011, 08:18 AM
