Results 1 to 5 of 5
Thread: 3X10 vs 2X10
    3X10 vs 2X10
    Why is everyone so stuck on 2X10? I have both but I like the lower gear on the 3X10. I know the 2X10 is a little lighter and shifts a little smoother but I don't feel its worth giving up the extra gears especially when you use the lowest gear when trying to climb really big hills. I know someone will say just get stronger but a lot of the guys I ride with race pro level and can't turn the bigger gears on some of the hills. I think it's a lot of hype by the bike companies to sell the 2X10 because it cost less to produce than the 3X10 and they sell it for more.
    Apr 2013
    For someone who doesn't have as steep or as many hills to climb it can save a little weight and make for smoother shifting. We have some pretty aggressive hills out here and I have considered it myself.
    May 2013
    You got to check out the rings to get the whole story. For example, the 2014 Stache is coming 2x10 - 36/22. This is lower than the 3x10 - 42/32/24 that comes on the Fuel 29'er for the lowest gear. Both have 11-36 cassette in the rear. I believe I have that correct.
    Reputation: skitchy's Avatar
    Dec 2011
    I remember when 29" wheels, disc-brakes and tubeless tires didn't make that much sense either.
    One of the joys of mountain biking is the freedom to run whatever gear you want. But I wouldn't knock it until you've tried it.
    maladroitus extraordinairus
    May 2013
    Re: 3X10 vs 2X10
    I personally like 6x9 better. It's very smooth to shift and no confusion what gear should be doing what.
    Sent from my LG-MS870 using Tapatalk 2
  1. 3x10 to 2x10
    By DJohnson in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-15-2013, 07:52 PM
  2. 2x10 FD-m785 work on 3x10 FC-m660 converted to 2x10?
    By govertime in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-03-2012, 07:17 AM
  3. 3x10 to 2x10
    By outlaw in forum Turner
    Last Post: 10-10-2012, 11:42 AM
  4. Q Factor XTR 2x10, 3x10 and XT 3x10
    By fishy in forum Shimano
    Last Post: 04-19-2012, 11:44 PM
  5. 3x10 to 2x10
    By cavo in forum Ibis
    Last Post: 10-28-2011, 09:38 AM
