placed a order for a 2013 Superfly 100 Elite SL (17.5) today. was told wont be available till march 2013 !
Wow, that's impressive.Well, I had my first race this weekend on the new SF100. 50 miles of technical and rugged racing in southern utah (True Grit 50). The bike handled great. It responded well, didn't drag on the technical ascents (in propedal), and it provided just enough forgiveness to keep me relatively comfortable. I still have a little to do to dial in the suspension.
I did have one problem. The pivot bolt attaching the rear shock, came loose twice during the race. I torqued all bolts to spec when I got the bike a few weeks ago, but it looked like the threadlock (blue) was dry and of no use. Hopefully it is not a problem in the future, but something to keep an eye on.
It's definitely a full suspension racer. Thumbs up.
Here's the bike. An XL weighing in at 21 lbs 2 oz with pedals and cage. Roval control sl wheels, XX1 drivetrain, and a couple other changes.
View attachment 782092 View attachment 782093
The bolt threads directly into the pivot. This is a picture of the link with the bolt missing. I would love to hear a logical reason for the bolt to unthread on its own. When I get home I'll get a pic of the threaded side of the pivot. Thanks.I also have received my bike and could not be happier with it. 17.5 is 24.5 lbs totally stock with older xtr pedals installed. The bike rides excellently compared to my fuel ex 9.9. It rides just like a new bike should! Trimming the fat on this bike will be an expensive endeavour as nothing is too heavy out of the box, even the wheels(which have bladed spokes). Tires are not as listed on the website and are a 2.0 instead of 2.2. They are lite but twitchy. I have. Four rides since last Thursday(I ride a lot) all off road and the bike is smooth, fast, and quiet. I e ridden abp for years so I knew what to expect in that department but adding the big axles on both ends definitely made a difference in off camber stiffness.
JTHOPS please send a picture of the "nut" side of the bolt that loosened. My guess is it is the upper bolt. I'd like a close up of the "nut" seated in the frame. I have an idea as to why it loosened.
I have ridden oclv for seventeen years and this fit and finish is the best by far. I am unhappy that trek moved offshore especially for the top end mountain frame BUT the bike is amazing!! If there was a frame only option, the availability of the bike would be non existent not that it isn't already.
If you have a chance to ride one, you will not be disappointed, except by the wait to get one after you order
So long story short, coming from a high end fully kitted carbon fuel ex to this bike was a noticeable upgrade in technology and "feel"
Kudos Trek... Just work on your supply line logistics.
