2013 rumblefish
Printable View
  • 08-30-2013
    grundy1973
    Originally Posted by VFRLuke View Post
    Nice. Do you notice much difference between those and the bonty tlr's?
    Sent from my SPH-D710 using Tapatalk 2
    The flows seem a lot more stiff. Only one ride so far though.
  • 08-30-2013
    grundy1973
    Originally Posted by bapski View Post
    what size RF is that?
    It's a 21"
  • 08-30-2013
    bapski
    Originally Posted by grundy1973 View Post
    It's a 21"
    oh ok.. just wondering how you have more space (bigger triangle) by the seat post collar..
  • 08-30-2013
    barrymtb
    Re: 2013 rumblefish
    What bottle cage is that?
    Sent from my SAMSUNG-SGH-I337 using Tapatalk 2
  • 08-30-2013
    grundy1973
    Bontrager: Satellite Elite Sideswipe Cage (Model #08242)
    Works well being side entry due to the rear shock position.
  • 08-30-2013
    barrymtb
    Re: 2013 rumblefish
    Yeah the position of the cage vs rear shock SUCKS!
  • 08-30-2013
    bapski
    2013 rumblefish
    Yup i have mine on a side pull as well and the water bottle size is also limited
  • 08-30-2013
    barrymtb
    Re: 2013 rumblefish
    Any problem with a camelbak podium bottle?
  • 08-30-2013
    bapski
    seems like i can only fit in a 20 oz POLAR WATER BOTTLE. over 20 oz either wont fit or it covers the REAR-SCHOCK adjustment levers..
  • 08-30-2013
    grundy1973
    Bottle size is probably dependant on frame size. I removed my cage this morning as ill be using a camelbak this weekend. I'll let you know about whether a podium chill bottle works with my cage on a 21" frame on monday
  • 08-30-2013
    bapski
    exactly! mine being a 19" only has a bit of space.. got suckered into doing a 6hr relay in two weeks and i dont know how to manage just having a 20oz water bottle to use. might still end up using a hydration pack, though the weight will add up to my already slow pace but then again, its all in the spirit of having fun anyway and not for a podium finish.
  • 08-30-2013
    barrymtb
    Re: 2013 rumblefish
    Agree. I have a large frame. In a standard cage the bottle barely clears the ctd control.
  • 09-07-2013
    grundy1973
    Podium chill fit mine no problem. Used it on the trails the other day
  • 09-07-2013
    barrymtb
    Re: 2013 rumblefish
    Thanks for the info!
  • 09-07-2013
    bapski
    ended up doing DIY MOD and it works perfectly.
    Attachment 830255
  • 09-08-2013
    Blind
    This RF Elite followed me home today...
    I haven't ridden it anymore than in the parking lot, down a small embankment, and onto/off of curbs but as you can see from the little o-ring I'm a little rough on this fork. The bike is a 23" model and I'm 6'5" / 210lbs.
    The shop mechanic added +15psi over the trek recommended air pressure and that helped a lot as my first quick spin I managed to bottom the fork out just playing around in the parking lot...I'm used to my 170mm travel Bomber 66 fork on my Santa Cruz ;)
    Has anyone swapped the fork out for something beefier, and if so - what? On a related note, is there a remote lever kit available for purchase for the CTD knob of the front/rear? And finally - what's the most recommended dropper seatpost?
    I think I'm calling in sick for tomorrow morning to play in the dirt before lunch :)
  • 09-09-2013
    Q-TECH
    Re: 2013 rumblefish
    At 210 this fork should be more than enough. Run it in "trail mode" though. The fork is designed for the first bit of the travel to soak up all the little stuff and the last inch or so is for big hits. This gives it a bottomless feel. I've got over a thousand miles on my elite and have never bottomed it out even with jumping all sorts of drops, stair sets, and creeks. I'm 201 fully geared.
  • 09-09-2013
    Blind
    2013 rumblefish
    Ah good to know, thanks!
    I think the settings for the rear is also a little too stiff for my taste so ill be packing a shock pump with me for the first few rides to try to dial it in.
    Typos from my iPhone using Tapatalk while po0ping.
  • 09-09-2013
    Q-TECH
    Re: 2013 rumblefish
    The suspension calculator on Treks site will get you pretty close.
  • 09-09-2013
    Blind
    That's how the shocks were both initially set at the trek store when I bought the bike.
    I need to spend some serious time going up/down trails to get this bike dialed in it seems, enough air in it to not bottom out the fork dropping off a 2' drop caused all of the small bump damping to disapear and my arms went numb on a pretty mild downhill single track I rode this morning, then I let out some air before the next rougher section and the rebound must now be thrown off as the fork was just packing in and getting stuck at 1/4" from fully bottomed out. I think I have the rear setup pretty decent, I used about 7/8 of the full travel with ~160psi in it.
  • 09-09-2013
    Blind
    oh and pics from the first ride, 6 personal records on the hills I climbed today...so apparently it does climb better than my 38lb Bullit ;)
    Probably would have gotten another PR if I didn't stop to take a picture
    Bike Ride Profile | First ride with the fish near Malibu | Times and Records | Strava
  • 09-16-2013
    Blind
    Have any other 2013 rumblefish elite owners had the clicking duster wheel issue?
    http://forums.mtbr.com/trek/issue-bo...-517317-5.html
    My rear wheel started clicking after my first ride 1 day after I bought the bike. I brought it in after my next ride with the bike (Monday first ride, Friday 2nd ride) and the shop 'fixed' my wheel and it doesn't click anymore.
    After another ride yesterday (Sunday) exactly 1 week after purchase, the front wheel seems to be developing a similar issue, though the sound from the front I'm hearing occurs with the brake applied and the wheel turned while I am standing...sort of like a track stand balance.
    Some people in that thread say their LBS fixed the issue by drilling the wheels and center punching the pins at the weld joints, others more recently are saying that Trek warranty replaced their wheels with Rhythm Elite wheels in place of the Dusters.
    Any experience from 2013 rumblefish owners?
    I'm up to 74 miles on the bike now, thinking that if I'm seemingly breaking the wheels at this point I might need to return the bike.
  • 09-16-2013
    DukeNeverwinter
    Re: 2013 rumblefish
    Take it in. Happens all the time. It's a crap shoot what Trek will give as warranty. It's just the sleeve rattling around. First step is to try a punch to immobilize the sleeve. Second is file a warranty claim.
    I have had two rims do it. Both were Rhythm Comps. Both were solved by using a punch.
  • 09-26-2013
    Silverfern
    Curious to know if any rumblefish riders have changed their wheelsets ?
    And were the changes in riding noticeable for the better ?
    Have been contemplating an upgrade, but then wonder if its a waste of money .
    Cheers
  • 09-26-2013
    Amp98
    anybody else have any creaking noises coming from thier fish?
    I have the elite, and I thought it was coming from the crank/bb area, but a while ago I had it on the stand wiping off the fork tubes and now I think it may be coming from the front end of the bike.
    there's no play in the headset that I can feel or anything like that, but if I grab the bars and the front wheel and push them in opposite directions I can hear a creak noise. I haven't tried to tighten anything yet. is this typical of a stem being loose?
    Did you ever figure out the source of the creaking noises? I'm also getting a lot of creaking/cracking/poping kind of noises that sound like it is coming from the cranks/BB. 2 trips back to the LBS where I bought it and the noise is still there.
  • 09-26-2013
    Blind
    I would suggest another bike shop / mechanic look at it.
    creaks can come from anywhere, I had a fun one to track down that ended up being a bit of grit stuck in the headset at the top of the fork on my Bullit after a good bail, practically took apart and cleaned/lubed/rebuilt every other part of the bike until I figured it out.
  • 09-27-2013
    de lars cuevas
    Hi there,
    if the noise is coming from the front ad your Fork is a Fox...
    https://www.google.nl/search?q=fox+c...Hq7Q7AbMkoHQDA
    Mine started as well :-)
  • 09-28-2013
    VFRLuke
    Re: 2013 rumblefish
    I believe my creaking to be coming from the seatpost and seat. I have taken it all apart and put a thin film of grease on it and it shut up for a few rides then started again. Need to try again. I have a reverb post, but I think it is down in the frame where the noise is coming from.
    I also suspected the maxle at one time.
    Im not going to take it in because I dont want to be without the bike for long and have them do 5 minutes worth of work and tell me everything is fine.
  • 09-28-2013
    bapski
    what kind of grease did you use.. i have the same minor issue... bigger issue was the REVERB POST not holding pressure. had to send it back to LBS 10 days ago and have not heard from them yet...
  • 09-28-2013
    VFRLuke
    Re: 2013 rumblefish
    The reverb itself has been great. I just used the tub of belray motorcycle grease that ive had for 15 years. Im guessing I missed a little bit of dirt. Im still not sure if its the clamp/seat rail, or where the post goes into the frame
  • 09-29-2013
    Silverfern
    I rode the Fuel 29er out of curiosity today at a trek demo day ,
    It was nice , if I didnt have the Rumblefish I would be very interested, has a slightly different feel , bit more racy,
    but for me , the improvements were not enough to rush out , sell the RF and get the Fuel .
  • 10-01-2013
    Blind
    Got the first mods on my new RF -
    Gravity dropper knock-off dropper seatpost (tmars)
    XT shadow plus RD
    XT shifters
    SLX m660-10 crankset
    Ergon knock-off lock-on grips
    Looks like I need to take the cable off the dropper post in order to route it to the trek cable clamps above the shock, the dropper came in the mail this morning so I quickly slapped it on before riding in to work
  • 10-03-2013
    bapski
    question for the RUMBLEFISH PRO owners.. did you get the BLEED KIT for your REVERB SEATPOST when you got your bike?
    my REVERB post was replaced under warranty, and saw the replacement in a box and came in with a bleed kit... i asked the LBS if i could have the BLEED KIT just in case i need to bleed the post in the future which seems like a likely occurrence and they have said they can't give me the BLEED KIT because it did not come with the bike when i purchased it..
    really does not make sense to me, but before i send an email out, just wanted to make sure if its a CASE-TO-CASE basis or the BLEED KIT should have been sent out with the bike..
    thanks.
  • 10-03-2013
    PaulX
    No Reverb bleed kit came with my Pro (UK Supplied). Bit tight of your LBS not just let you have it though...
  • 10-03-2013
    bapski
    yup $34 tight..
    but from the LBS standpoint id understand it too... i may just go gung-ho everytime i have/feel that there is something wrong with the seatpost and just BLEED away...since i have a BLEED kit..
    but still...$34?
  • 10-24-2013
    ecobykr
    Cheers
    Yes! I built some wheels with Stan's Crest hoops, American Classic hubs and DT SuperComp spokes.
    The wheels, combined with new Schwalbe Nobby Nic tires changed the bikes personality enormously. It still rips downhills but now accelorations and climbing are both very noticeably easier.
    The stock wheels (on my 2012 elite) were solid, but they're the BEST part to upgrade in my opinion.
  • 10-25-2013
    elkootcho
    Might be picking up base model Rumblefish this weekend. My brother has the 19" Elite. We're about the same height (5'11"ish) but I have slightly longer legs (he has longer torso). What size do you guys ride and how tall are you?
    My other option is 2013 Fuel EX 7 (26er).
  • 10-25-2013
    ecobykr
    I'm 6'1" with a long upper torso so a 21 is perfect for me.
    I just bought my son 5'11" a base model 2013 (they're on clearance sale right now!) and I got him a 21 too, just because it's design provides loads of standover and he's still growing like a weed.
    That said, I think you'll be fine on a 19 or a 21
  • 10-25-2013
    elkootcho
    Thanks for the response ecobykr...I just sent you a pm.
  • 10-26-2013
    elkootcho
    Joining the rumblefish club... just got home with a 2013 Rumblefish marked down to $1600. Couldn't resist.
  • 10-26-2013
    Q-TECH
    Re: 2013 rumblefish
    Cheers
    I put some Mavic Crossmax SLR wheels on my Elite. Huge improvement in handling. Much crisper and predictable in turns. Saves just over 1 pound or nearly 2 pound if tubeless.
    I'm 6' with longer legs and riding the 19.
  • 10-27-2013
    elkootcho
    I bought the 19 but after a 3 hour ride I am pretty certain that I need a shorter stem. Everything else feel good. However, the stem doesn't have the length and rise stamped on it. Does anyone here know the stock stem length/rise on the base model Rumblefish 19"?
  • 10-27-2013
    grundy1973
    Not sure on length as I have a 21 but rise is 7 degree
  • 10-27-2013
    Q-TECH
    Re: 2013 rumblefish
    Should be 80mm.
  • 10-28-2013
    Silverfern
    Here in Australia , the 17 came with 90mm the 19 with 100mm , Im 5 11 brought the 19 but swapped over for the shorter stem .
    Am thinking of going shorter again , 80mm
  • 10-29-2013
    cmg71
    My 21" came with 100mm, swapped it for 60mm, love it!!!!!
    Everyone tells me the bike is not setup properly, but l love like that.
  • 10-29-2013
    cmg71
    Oops,, lm 6"2' btw
  • 10-29-2013
    elkootcho
    qtech and grundy got it right: the 19" stock stem is 80mm, 7 deg. Confirmed by cust. serv. at Trek.
  • 10-31-2013
    Blind
    I measured the stem on my 23" before swapping, it was 90mm center to center, swapped for a raceface 60mm and pretty happy with it, might swap to some carbon bars with some rise that are wider next, not sure.
  • 11-05-2013
    Silverfern
    Ive got a Thomson 70 mm stem and a carbon 730mm low rise bar on the way , I wanted a wider bar , but am rolling the dice a bit on the new length of stem , wanting to sharpen up the steering , bit nervous it may feel a bit cramped though.
    Am currently running 90mm stem and 690 bar that came with the bike.
