• 12-19-2012
    Divaythe
    2012 Fuel EX 7 3x10 to 2x10
    Alright so I'm trying to go from 3x10 to 2x10 and I've run into a number of things that I'm not sure about. First off I asked the guy at my LBS what I would need to change and he said I'd only need to get a new crankset. Now if that's true would I need to switch out the BB if I went from Shimano to say SRAM X0 or Raceface Respond or Atlas? What size BB is in my bike? Shimano doesn't tell you on their website and I can't seem to find a straight answer anywhere else. :madman: This is driving me crazy.
  • 12-19-2012
    cfrea
    You will need to change the BB if you go from say SHimano to Sram.
    Also you will probrably need to change the front deriauller. THe rear may work, you will need to check with the manufacturer. FInally you will need to change the shifter to a 2x10 shifter unless it has a mode switch from 3x10 to 2x10
  • 12-19-2012
    Divaythe
    Any clue what size BB my bike takes?
  • 12-19-2012
    cfrea
    Try calling trek directly. IT should be a standard press fit or osmething
  • 12-20-2012
    Andyman_1970
    You should be able to use your existing front der, just adjust the limit screws to the reduced spacing of 2 chainrings and not 3.
    Shimano Tech Docs try this and find the part number off your crank/BB that should narrow it down.
  • 12-20-2012
    P1Painter
    Its a press fit and I see Shimano part number SM-BB91-41A as what it came with.
  • 12-20-2012
    Divaythe
    Thanks guys for all the help!
  • 12-20-2012
    Hoban
    I put on a $12 BBG bashgaurd in place of the large ring and adjusted the High screw to limit the 3rd ring. Worked great.
