Results 1 to 3 of 3
    2011 Trek Top Fuel 9.9 SSL which Sram xx BB / crank is best?
    Hey Guys
    I was wondering if you could help me, i'm putting together a custom Top fuel 9.9 and instead of the Shimano XTR i want to go with the Sram XX Groupset.
    I have a 19.5" Top Fuel 9.9 SSL 2011 Frameset and was wondering which Sram XX crankset/BB combination would best go with this frame?
    Plus what is meant by "164mm Q factor" and "156mm Q factor" when talking about the BB30 cranksets?
    Of course this is all assuming that the frame is compatible with these BB's, Please correct me if i'm wrong.
    Thanks in advance for your help
    Paul
    The frame isn't compatible with BB30. Use the standard GXP version instead. The q factor is the width of the crank from the start of one pedal spindle to the other pedal spindle (outside to outside). I'm pretty sure the narrower on will work with this frame, but it would be worth an email to Trek to confirm.
    Thanks Kdiddy
