Results 1 to 3 of 3
    2011 Trek Cobia - 10mm through axle?
    Does anyone know if I can convert my 2011 trek cobia from the QR to 10mm through axle? I have searched a bit, and it seems like its possible, but have not found definitive answers...especially for the trek models. I have hope pro 2 hubs that can be converted, just worried about working it with the frame.
    A regular dropout will take a 10mm thru-axle or a Dt Swiss RWS thru-bolt. I use one and the 9mm RWS on the front dropouts.
    Reputation: Ryandurepo's Avatar
    Nov 2012
    Hey just to answer your question, I wanted to do this to my superfly but I have the bontrager wheelset and they do not make replacable end caps for my hubs (non dt Swiss bontrager hubs) I took everything apart and measured out the end caps that are on it now, and a 10mm axle will go all the way through. I just need to drill out the two end caps that take the quick release skewer and make them a slip fit for the 10mm axle. I'm already running a 15mm axle up front so no need to do front. Hope this helps.
  1. 2011 Trek Cobia 29er wheels.
    By tenchichrono in forum 29er Components
    Last Post: 10-09-2013, 07:44 PM
  2. Replies: 4
    Last Post: 04-22-2013, 10:35 AM
  3. Trek Cobia (2011) rear tire clearance
    By tedlove in forum Trek
    Last Post: 12-07-2011, 03:12 PM
  4. What size seatpost collar on 2011 Trek Cobia?
    By DarkKnight369 in forum Trek
    Last Post: 08-19-2011, 10:25 PM
  5. 2011 Gary Fisher Cobia by Trek FS
    By jdizzy8 in forum Trek
    Last Post: 03-21-2011, 05:25 AM
