Results 1 to 3 of 3
    Reputation: justaguy's Avatar
    Jun 2005
    2005/2006 Remedy 6 Seatpost Size?
    I got a Remedy 6 front triangle as a warranty replacement for a cracked frame. Looks like the seat tube is about 1-1/16 in diameter. I am guessing 27.2 mm.
    Can anyone confirm the seatpost size?
    Oct 2007
    either 27.2 or 31.6mm - I have seen both - if it should be 31.6, and you want to be able to lower the seat post all the way, you still for example need a 27.2 with a shim, because the ID changes somewhere at the location of the rocker link pivot.
    Jun 2005
    27.2
    It is 27.2. Seemed a little loose in the tube, but tightened down fine. Thanks
    "Like dogs, bicycles are social catalysts that attract a superior category of people" ~ Chip Brown
