Results 1 to 6 of 6
    Reputation: fishercat's Avatar
    2.3 rear tire on 2001 sugar?
    will it fit?
    Reputation: crankpuller's Avatar
    depends on manufacturer
    A 2.3 Continental will fit - a 2.25 geax probably won't.
    I have a 2.1 Mitsubishi Superheat in my 2002 Sugar + right now and it barely fits - but Mitsubishi's are HIGH volume. That 2.1 is almost the same size as the 2.5 weirwolf.
    Crank monkey
    Reputation: Smytty's Avatar
    It might - but you should check Shiggy's site.
    I have the stock IRC Backcountries on mine, and there's still a bit of wiggle room there -about 3/16" on either side at the chainstays, 1/4" at the seat stays. Check out Shiggy's site if you're not sure - http://www.themudzone.com/tire/tire_...ecs/index.html for measurements.
    Cheers,
    Smytty
    Just rode with a buddy with a 2001 sugar 1, was running a 2.3 conti explorer ust. the thing barely fit under the brake bridge . Wet and muddy conditions and that thing was USELESS. keep the 2.3 on the front and stay with a 2.1 rear.
    Crank monkey
    I think the rear triangles are different between the...
    older Sugars and the newer Sugar+'s, so I don't think you can compare the 2 for tire width. Anyone know for sure?
    Cheers,
    Smytty
    Yes. I ride a 2003 2+, and it will easily fit a conti 2.3 as it does not have the brake bridge that the earlier sugars have. It isn't width that ends up being the problem, it is height.
  1. Blur rear tire choice thread from old boards
    By CraigH in forum Santa Cruz
    Last Post: 03-03-2004, 05:16 PM
  2. Rolling resistance front vs. rear tire?
    By keen in forum Wheels and Tires
    Last Post: 02-21-2004, 05:17 PM
  3. Replies: 2
    Last Post: 02-15-2004, 09:35 PM
  4. Good rear Mud tire?
    By KMan in forum General Discussion
    Last Post: 02-13-2004, 12:18 PM
  5. Biggest rear tire for the Superlight?
    By Earthpig in forum Santa Cruz
    Last Post: 02-12-2004, 12:20 PM
