142X12 conversion kit
3K views 3 replies 2 participants last post by  BlackMamba2012
#1 ·
Hi everyone. I want to convert my 2013 Fuel Ex 7 rear wheel to a 142X12 through axle. I have found all the frame parts from my LBS but I wanted to check if the standard Duster wheel can also be converted or if I should buy a new one?
#2 ·
Line Metal Tool Stationery Iron
U would need to buy new rim cause the the threw axle is alot bigger than the duster rim hole is on the hub.
Look into getting Sun Ringle Expert are good choice cause they come with adapters to convert the front wheel 9mm or 15mm or 20mm. U would need to buy the rear hub adapter for the rear one. these are what u need for the rear.The adapters give u alot of options if u wanna run something different like 20mm front fork u wouldnt have to buy new rims.:thumbsup:
SunRingle SRD/Pro Axle End Cap Conversion Kit, T-A from ModernBike.com
they also sell the rims also.
Sun Ringle 26" AM Charger Expert Wheelset 9/15/20 Black from ModernBike.com
If you ride alot of downhill with roots or rocky terrain might look into get the Chargers.
