Results 1 to 2 of 2
    142x12 on 2013 SF100 AL elite
    Can the SF100 AL elite be converted to 12mm through axel using the stock hub? You just buy a kit from the trek dealer for around $100?
    2017 Santa Cruz Tallboy CC
    Oct 2012
    Quote Originally Posted by stygz1 View Post
    The good news is that your SF100 frame is the same as the Rumblefish (which is factory equipped with a rear 142x12 TA), so the parts should be available to complete the conversion.
    The bad news is you'd have to replace the hub with a model that accepts a 12mm thru axle. You can purchase the hub separately, or as part of a new wheel or complete wheelset.
