Results 1 to 12 of 12
    Reputation: |brake-out|'s Avatar
    '08 ex-8 frame protection
    Just got to cleaning up my bike tonight and noticed that on the seat tube where the cables run behind it, the cables are rubbing.
    What can I do to keep the cables from making marks on the frame ?
    "Only silence is your true origin."
    Reputation: FueLEX8's Avatar
    mine too is rubbing... help!
    Reputation: YeahWhatever's Avatar
    How about using something like the Lizard Skins frame patch kit?
    Reputation: liam2051's Avatar
    yep thats similar to what ive got on my ex9 except mine was BBB's tube skin
    What are the odds that any of my mediocre LBS's are going to have these ? *sigh*, guess I'll be ordering online then.
    Thanks for the info !
    most good bike shops should have something, i like the BBB tube skin because its super thick most bike shops just sell that real thin nasty stuff.
    i actually used two tube skin protectors for the whole bike, one on the underside of the downtube as its supposed to be used and the other i carefully cut into neat covers that would protect areas of rub, so far its worked great and the downtube skin saved the paint on the trail the other weekend, i had a nasty run in with some barbed wire that had been left strewn across the track, i managed to get tangled is all ill say but no paint damage
    Lionel Hutz, Esq.
    Reputation: Thirdrawn's Avatar
    I was able to get some Jagwire cable covers within a couple of days. A small LBS probably won't carry them regularly because that item isn't really asked for too often, but they can probably get them faster than you can.
    2007 Trek Fuel EX 8
    1999 Trek 7000 --- Dragonfly Green = Sexy
    2002 Trek 2100
    2008 Felt New Belgium Cruiser
    I've always used electrical tape to tape up my frame where the rubbing would occur. It's cheap, and easily accessible, and if you have a black bike...barely noticeable.
    +1 on E-tape. A bikers best friend.
    electrical tape. The head tube, the front fork, the seat tube, and more, usually need just a spot to keep from rubbing the paint off.
    Sweeper
    Reputation: WeatherMan's Avatar
    I bought a few packs of Lizard Skin Frame Patches in clear. Put them in all the places that the cables/lines rub the frame. Holdind up perfect on my 08 EX8. I also used the Liazard Skin stick on ChainStay gaurds but applied them from the lower headset down to the crank. Little protection from paint chips on my 2000+ dollar bike! LOL.....
    Reputation: wyrm's Avatar
    More E tape
    Bikeless Rider
