Results 1 to 3 of 3
    likes bicycles
    Reputation: vitale232's Avatar
    V1.5 Covert - Slight play in linkage
    I've got a V1.5 Covert bought back in 2008. While putting it up today, I felt the slightest amount of play as I unloaded the rear. Lightly lifting the rear reveals a slight popping feel that's detectable throughout the bike. You can even feel it on the handlebars.
    After spending about an hour trying to chase it down, I'm fairly certain it's the forward most shock mount. Perhaps the bushing became rounded out or something? I'm not that familiar with suspension linkage.
    First up, has anyone else come across this? If so, how'd you fix it? I was planning on replacing the bearings and hardware this winter, but maybe I should fast forward those plans. Do you think new hardware could take care of the issue? Student budget, so I don't want to just start throwing new stuff on there. Also, should I park it until it's all sorted?
    Aug 2005
    Its probably a shock bushing, you can order the bushing and do it yourself, but most shops stock the part and will probably do it for $20 or so. Its a pretty quick fix.
    You can still ride it, once the bushing is worn, it won't get much worse.
    2016 Santa Cruz Hightower 29er
    2016 Chromag Surface 27.5+
    2013 Transition TransAM 29er
    2017 Motobecane Lurch FS 26 fat
    likes bicycles
    Sweet. I'll take her by the local Transition dealer for a little slice of love
