Results 1 to 3 of 3
    AW_
    AW_ is offline
    locked - time out
    Reputation: AW_'s Avatar
    Transition Revolution Rims - Tubelessability?
    Is anyone running their Transition Revolution rims with a tubeless setup? If so, what are the ingredients - rim, method, tire combination - and what are your results?
    Thanks.
    sixsixtysix
    Guest
    Quote Originally Posted by AW_
    Thanks.
    I run mine tubeless with Maxxis rim strips, Stans fluid and Maxxis 2.5 Minion/High Rollers. The work great, never had a flat other than a cut tire, but other than that, they have been flawless
    AW_
    AW_ is offline
    locked - time out
    Quote Originally Posted by sixsixtysix
    Right on, thanks. Do the Maxxis strips have a lip to assist with holding the tire on the rim or are they flat?
    Also unfortunately it appears that Maxxis no longer sells those rim strips.... rats!
