Results 1 to 11 of 11
    Transition Patrol (linkage analysis)
    Hello guys,
    Just to share my analysis of Patrol and a comparison with Rune.
    Bye
    Nov 2015
    Rad.
    Sent from my GT-I9505 using Tapatalk
    Reputation: el_guillyt's Avatar
    Mar 2013
    Ex rune owner, and just ordered a patrol!!! Did you just read my mind?? Thanks for sharing
    Enviado desde mi Nexus 7 mediante Tapatalk
    Reputation: JREinMN's Avatar
    Awesome! These were the two bikes I was trying to decide between. Went with the Patrol.
    Any chance we'll see a TR500 analysis?
    I live in Denver but Minneapolis is home.
    2015 Transition Patrol
    2015 Transition TR500
    Yes, I will do it for the TR500... It might take a few weeks, but it's on the plan.
    Mar 2013
    How do you think the patrol will work with coil shock, canecreek in my case? Some ppl say it's not progressive enough for a coil, and the ccdb it's one of the most linear coils out there...
    Quote Originally Posted by andrextr View Post
    How about the 2016 Turner RFX and maybe compare to other new DW links or the Evil Insurgent.
    It will work well, the only problem might be the bottom-out. It depends on your type of riding. You can increase the progressivity of CCDB by increasing HSC (but you start to lose small bump sensitivity). With debonairs, vivid or float x2, you can tune the progressivity of the spring curve without messing around with damping.
    Unfortunately there is no progressive coil springs available in bike industry...
    Bye
    Mar 2013
    Bye
    Well, as the fist 1/3 of the travel is regressive I think it will be fairly easy to find a sweet balance between sensitivity and bottom out resistance playing with HSC, the only base setting I found for the patrol is with ccdbair and HSC settings are in the middle, I believe with with the coil the small bump sensitivity increases so more HSC control will be required which will help bottom out resistance, will find out in the upcoming days, tomorrow will start building the beast....
    Nov 2013
    Awesome, thanks for this!
    Nov 2015
    Hello guys,
    Bye
    May I ask you to run this program on an Intense Spider 275A with a 160mm xfusion sweep?
    Pretty please...
  1. Santacruz NOMAD 3 vs YT Capra (linkage analysis)
    By andrextr in forum Santa Cruz
    Last Post: 11-01-2016, 02:26 AM
  2. Banshee Rune (linkage analysis)
    By andrextr in forum Banshee Bikes
    Last Post: 03-09-2016, 04:36 AM
  3. Santacruz Hightower linkage analysis
    Last Post: 03-06-2016, 09:40 AM
  4. Canfield Jedi 2016 - Linkage analysis
    By andrextr in forum Canfield
    Last Post: 01-26-2016, 04:38 PM
  5. Canfield Balance 2016 - Linkage analysis.
    Last Post: 01-20-2016, 12:12 PM
