Results 1 to 18 of 18
    Feb 2005
    Transition guys - smuggler ride question
    Now that the news it out can you give your thoughts on how the Smuggler fits into the lineup with only 111mm of rear travel?
    As someone who has been on both a newer Bandit 29 and Covert 29 I'm wondering what end of the spectrum the Smuggler hits. The Bandit 29 was a good peddler, but seemed to get a little overwhelmed in the chunky high speed. The Covert 29 hammers chunky high speed however in my opinion is a tradeoff for pedaling efficiency and snappiness. Thanks
    29ers Forever
    Reputation: CannondaleF9's Avatar
    Nov 2012
    The Smuggler has 115mm of rear suspension travel, 5mm down on the Bandit. The fork has 10mm more than the Bandit.
    It has a shorter chainstay and it should climb better. It is definitely on my radar for my next bike.
    2013 Trek Cobia- 29er
    2015 Raleigh Misceo- Gravel bike
    2013 Trek 3700 Disk- 26er
    1994 Cannondale R300- narrow tire roadie
    Jan 2009
    I think you have us mixed up with another brand
    The Smuggler is definitely "different" than both the Bandit 29 and Covert 29. But all in good ways.
    As CannondaleF9 pointed out, your are only 5mm down on rear wheel travel but you are gaining the 130mm Pike which is a major improvement in DH performance and confidence compared to the 32 Float 120.
    Suspension performance is much improved. Pedaling is equally improved over both the Bandit 29 and Covert 29. Travel is closer to the Bandit, but the chassis is much stiffer, the head angle is slacker, chainstays are shorter.
    If you liked aspects of both the Bandit 29 and Covert 29 I think you will be blown away by the Smuggler.
    Feb 2005
    Thanks guys. Just caught the 111 reference. One more question. If you wanted to run a 140mm fork instead of 130 how would that do with the Smuggler? Just slacken the head out more?
    Jan 2009
    No problem! And I should have said... you are only down 5mm of travel, but the quality of that travel is improved as well. The Smuggler is like a Bandit 29+ with a weight savings from the Covert 29.
    Quote Originally Posted by Transition Bikes View Post
    "Like Bandit 29+..."
    I am riding 1st generation 29 Bandit. Is it close to that then?
    @Transition-Bikes
    What is the shock size? Thanks!
    Nvm, just saw it in the other post.
    7.5" x 2". Nice!!!
    Quote Originally Posted by mrniceguy42 View Post
    7.5" x 2". Nice!!!
    Transition guys,
    Any problems with running a Monarch plus rc3 deabonair on this bike? Or is the RT3 more than sufficient for long descents without fading?
    Feb 2005
    Thanks guys. I preordered a black smuggler frame. XL baaaaaaabby.
    Any reason why I could not run a 140mm fork up front?
    The reason I'm asking is I have a fox 34 at 140mm that installed an avalanche damper in. The thing is completely dialed now.
    29ers Forever
    Nov 2012
    Quote Originally Posted by trailbrain View Post
    I don't see anything wrong with it. It is only 10mm of added suspension travel, and if anything it will slack out the bike even more.
    clk
    clk is offline
    Dec 2012
    I'm planning on running a 140 as well. In the other thread the transition guy said that would be fine.
    Feb 2005
    Cool. That's the route I'm going then.
    I'm running a bandit 29er 2012 model which i love just had rear shock pushed and rides a sweet as question is will the new smuggler bike be a vast improvement
    over this?
    Reputation: sandman012's Avatar
    Quote Originally Posted by kitess View Post
    over this?
    I'm also wondering about the differences between the smuggler to the original bandit, I have mine with a 140 fork on it
    Guys
    From all bikes i looked for this season Smuggler is prettiest - this clean build - internal cable routing and no FR-Dir mount - just like i wanted.
    Moreover Geo is almost as like Spec Enduro.
    The biggest competitors are now SC Tallboy LT and Banshee Prime - both longer travel and same 140mm fork.
    I know numbers are not always all but is that 115 travel enough - enough for AM/Enduro.
    I'm just moving from Anthem 29 and need something definitely more Enduro oriented but still not as aggressive as WFO.
    some know me as mongo
    Placek - while I dont have the bike I feel I can speak to your issue. Yes this biek does have less travel and will ride like a much bigger bike than the Anthem ever could. the Smugler I am sure will be more than capable of clearing pretty much any line you choose to pick with out worry of damaging it. I'm looking to possiable it a Smuggler frame in the future.
    All this being said, it is a shorter travel bike. It will be harder to get through some of the bigger line, it will be rougher on you while hitting bigger lines.
    But it will be a more rounded bike than many others out there I bet. It should pedal pretty well. It can take a water bottle in a useable location (or to hold a light battery) it is fairly light for what it is. It will give you alot more trail feed back than bigger bikes (some like this some dont) and should be more playful and the bigger bikes out there.
    As a reference point I am also looking into the Prime and the Tallboy LT.
    999.6 miles ridden (going to be a slow start because of work )
    1868.3 miles ridden in 2013
    Unfortunately i have to take in account that my actual Anthem has 120 fork and changing it to 130/115 is only a 10% of a change.
    Geometry for sure is more important matrix and Transition is expected to improve comfort, but as You mentioned will be harder to hit bigger lines - this is my biggest concern.
    On Anthem i could ride between rocks, now i'd like to take them over - longer travell/fork matters....i think
  1. Smuggler
    By nitrousjunky in forum Transition Bikes
    Last Post: 2 Days Ago, 11:14 AM
  2. Replies: 8
    Last Post: 08-29-2014, 11:48 PM
  3. 2012 Transition Bandit- Wheel question
    By dejock in forum All Mountain
    Last Post: 12-23-2012, 11:48 PM
  4. transition tr250 question,,,
    By delirian in forum Downhill - Freeride
    Last Post: 04-17-2012, 09:15 AM
  5. Any clydes ride a transition?
    By shawn lichtfuss in forum Clydesdales/Tall Riders
    Last Post: 07-14-2011, 12:53 PM
