Page 5 of 7 FirstFirst 1234567 LastLast
Results 401 to 500 of 612
  1. #401
    Reputation: Slurry's Avatar
    Dec 2008
    Bandit Owners:
    Did you buy your frame based on a TT length that you know works for you, or based on the height recommendations from Bandit?
    I own (and love) a Canfield Yelli-screamy in size large (622 ETT). I tried a large Bandit at my LBS (no XLs, alas), but the ETTs on the Bandits run short (596 ETT on large). The XL, however has the same 622 ETT as my Yelli. The large was noticeably short on my brief test ride, though the stand over was perfect.
    So have any of you gone with a shorter TT then you're used to with your Bandit? I run 770mm bars / 70mm stem on the Canfield.
  2. #402
    North Van/Whistler
    I'm used to longer top tubes than the M on the Bandit. I could probably have ridden a Large but went with a Medium. Having said that Transition recommended either a Bandit in M or L for me. My preference was for M given the hoped for emphasis on bike handling
    Locals' Guide to North Shore Rides http://mtbtrails.ca/
  3. #403
    I'm in the same boat, coming off a large Shinobi with a 630mm ETT so going to the 596 ETT on the Bandit was quite a change. I'm running 730mm flat bars with a 70mm stem. First few rides were spent feeling strange on the bike as i'm used to low and long but once I got used to the more upright position. I'm 6'0" w/~33.5" inseam, could probably ride an XL but now that I'm used to the large I'd rather be on a bike that's easier to flick around, which the bandit loves to do.
    ride, eat, sleep, repeat
  4. #404
    RYD W/ FLO
    I am 5'10", usually ride a M but took Transition's advice and sized up to a L with the Bandit. Swapped out the stock cockpit for a 40mm stem and a 760mm low rise bar and now the bike handles like a dream while still giving me the space I need. Not as maneuverable as the M but much more in control on the way down which is where the magic happens.
  5. #405
    Back of the pack fat guy
    6', 34" inseam and I couldn't be happier with my XL. I size my bikes/frames on ETT, so I went with the XL, which matches my other two bikes' ETT measurements. However, unlike my other two bikes which have 105/110 stems and 711mm bars, I'm running a 75mm stem and a 2" rise bar that I think is about 770mm wide. Handles like a dream.
  6. #406
    Propr
    Reputation: Lowball's Avatar
    Just finished up my local after-work loop!
    <iframe height='405' width='590' frameborder='0' allowtransparency='true' scrolling='no' src='http://app.strava.com/runs/10334001/embed/fb6e5c7c0727ebee013d4c93e43fd25cc8a957fa'></iframe>
    Bike is awesome...still!
    Hit a couple of jumps on the DH section and bike felt stable...haven't done all the jumps that I use to do on my Nomad yet, on the same trail, but once I put the HD's back on I'll feel more confident I'm sure.
    10 TransAM SS
    S-Works M2
    Nomad3cc xx1 - Sold
    Hightower LT - 2018 LG
  7. #407
    Finally got around to taking some photos. Taken on Monday in Sun Valley, Idaho.
    Bike isn't complete yet - needs a little steerer trim, a cable re-route, the install of the new 142 x 12 axle on the rear hub and the Blackspire Stinger chainguide, and possibly some XT brakes. Otherwise, what you see is what you get. Which is really good!
    Attached Thumbnails Attached Thumbnails Transition Bandit 29 photo thread-061112163804.jpg
  8. #408
    Kenda Slant 6 DTC!!!!!
    Had to ditch the Nobby Nic's....many slip-n-slides....so Kenda Slant 6 DTC are ripping now.....hook like a MOFO and way faster then the Nic's.
    Ditched the 10 speed 175mm cranks for a a new closeout deal $ set of 9 speed 170mm cranks.....24-36T....170mm works great for spinning and overall seems better then the 175mm. Able to get a tighter chainline using the 9speed cranks with 10 speed rear componets. Ride On!!!!!!
  9. #409
    What type of terrain are you riding the slant 6's on? I just tore the sidewall of my bonti xr4 rear last night and thinking about replacing it with something a little faster-rolling...i've got a slant 6 on the front of my rigid bike so i might throw that on the bandit...otherwise i've got a racing ralph 2.4 laying around...my problem is that i ride a wide variety of stuff from super rock/root technical east coast stuff to fast and flow hardpack...haven't found the perfect do-it-all tire for me yet...starting to think it doesn't exist
  10. #410
    eci
    Reputation: snowskilz's Avatar
    Quote Originally Posted by Lowball View Post
    What is the rear axle your using?
  11. #411
    Propr
    Quote Originally Posted by snowskilz View Post
    Shimano - E thru axle 142x12
    10 TransAM SS
    S-Works M2
    Nomad3cc xx1 - Sold
  12. #412
    Quote Originally Posted by tdotrider View Post
    eastern PA black dirt,lots of roots,muck and some rock....plus the trail is littered with overgrowth of thorns and jaggers...the nic's got beat up in the brush..not one thorn in the casing yet.....more durable on that stuff for sure...i run the 2.0's tubeless with 4oz of slime in each tire. the nics had so much resistance when climbing and these just breeze on the ups!
  13. #413
    Jan 2009
    A little Bandit 29 product testing in Squamish, BC.
    Photo by Brad Walton, rider Sam Burkhardt.
  14. #414
    Dec 2008
    New Bandit 29 Med
    Just thought I'd post pics of my Bandit 29 build
    Bandit 29 Med Green Frame
    Easton Haven 29 Wheelset
    Fox 34 Talas 140 15mm Fork
    2013 Fox Float CTD Kashima Boost Valve w/ Trail Adjust
    Chris King Headset
    Specialized Purgatory S-Works 2.2 Tires (Set-up Tubeless)
    Raceface Turbine 24-36t Crankset w/ BB
    Sram XX 11-36t 10 spd Cassette
    Sram XO Med Cage Rear Der.
    Sram XO Ft Der.
    Sram X9 10spd Shifters
    KMC x10SL Chain
    Avid XO Polished Brakes w/ 180mm Rotors
    Easton EC70 Bars
    Lizard Skin Lock-On Grips
    Thomson X4 70mm Stem
    Rockshox Reverb Seatpost
    Thomson Seatpost Clamp
    WTB Silverado Ni-Cro Saddle
    Crankbrothers Candy 3 Pedals
    Weight: 28lbs 5ozs
    Attached Thumbnails Attached Thumbnails Transition Bandit 29 photo thread-imag1115.jpg
  15. #415
    Reputation: eurospek's Avatar
    Looks awesome!! Any reason for the Talas over the Float?
    konahonzo
  16. #416
    Reputation: Demodude's Avatar
    Angelbcel, have you gotten it to the trail yet? Spot on bike!
    I'm GNARcissistic
  17. #417
    RYD W/ FLO
    Quote Originally Posted by Transition Bikes View Post
    Nice shot! I'll be there in less than a month. 3 weeks through BC (Kootenays/Coast focus) with stops in Bellingham, Duthie Hill, Hood River on the way home. SO PSYCHED!
  18. #418
    Reputation: Joel RW's Avatar
    Update
    There has been a few small changes on the bike since I early this year.
    Adamo Peak seat, 70mm stem(prev 90), thomson seatpost and to top it all off I got some new wheels! Wide all mountain 29" carbon rim from light-bicycle(the one discussed in the 29er forum), with alloy nipples, DT competition spokes and chris king hubs! Running nobby nics on the new wheels and still have my Hans damphs on the stans flows!
    A carbon wheelset will really improve the ride on your bandit. They're not harsh at all, matter of fact they're less harsh and really put a smile on my face at times when I noticed how smooth they are. They flex about 1 inch less side to side under finger force too so super stiff even compared to a burly stans flow. They look great with the glossy finish on the components too!
    Attached Thumbnails Attached Thumbnails Transition Bandit 29 photo thread-dscf2108.jpg
    Pivot mach 6!
  19. #419
    And when I say they put a smile on my face, I'm serious... I must of had a bit of a pedo smile because I looked up and there was some chick in front of me.... and she looked pretty freaked out! LOL
    Pivot mach 6!
  20. #420
    just a man
    Reputation: Bombin4X's Avatar
    I thought that bike looked familiar! She really is a beauty Angel. Was cool chatting with you about it after your Table Rock ride yesterday. Maybe see you out there again soon.
    [URL=https://www.juststopandthink.com/david-nassar-religion-the-movie-religion-video/[/URL]
  21. #421
    I went for what ended up being the muddiest ride I've ever been on today. It was a new high speed flow line winding along and around Sumas Mountain. After a day of heavy rain I was assured that since it's a new, built up trail it should drain well and be fine. Instead, the fresh, young dirt turned into the deepest, slickest, clay-rich mud I've experienced. We still went fast, but our bikes were rarely pointed the direction we were moving. Also, I came face to face with a bear blocking my path on the trail, and had to nervously make my way past once he got off the trail.
  22. #422
    Quote Originally Posted by Angelbcel View Post
    Chris King Headset
    Sram XO Ft Der.
    KMC x10SL Chain
    Easton EC70 Bars
    Weight: 28lbs 5ozs
    ******2013 Fox Float CTD Kashima Boost Valve w/ Trail Adjust*******
    Dang Fox seems to never be able to dial in a shock.....every year time to switch it up.....how about a trade in program for us with the 2012? How's it compare to the 2012?
  23. #423
    Wet, muddy XC ride at Swinley Forest on Sunday. Gotta love the British summer - tights and overshoes mandatory!
    On a side note, I bought a Shimano SM-AX75 axle, so I'd have a quick-release rather than bolt-through. Doesn't fit! Not enough threads to tighten the q/r lever. Does that make the dropouts Shimano-ish standard?
    Attached Thumbnails Attached Thumbnails Transition Bandit 29 photo thread-swinley_little_dropper.jpg
  24. #424
    Quote Originally Posted by NickyTee View Post
    I thread mine in until it stops then flatten the lever, seems to work as intended? I know it doesn't look like the threading is long enough though. Mine has been fine for 3 months.
    Pivot mach 6!
  25. #425
    No, it definitely doesn't close tight enough to hold the wheel in place, at least on my bike. It was barely touching!
  26. #426
    Jan 2009
    Are you using the Shimano nut, or the stock nut? You are supposed to take out the nut on the driveside and replace it with the Shimano one (multi fluted) so you can clock the QR lever where you want it to line up.
  27. #427
    The stock nut. I took it as gospel that a standard is a standard
  28. #428
    Mar 2011
    Quote Originally Posted by staz View Post
    After short ride (25 km in wet) i'd say the new CTD shock with BoostValve is very nice for a stock shock.
    The CTD lever has very good indexing and like rebound has excellent indexing too, the different positions actually do something, climb is very platform heavy, descend is good for rooty pedally sections and going downhill, i used Trail 1 on pedally root sections but Descend mode seemed more supple.
    (this ride was on M Bandit 29)
  29. #429
    Jan 2009
    Yeah, but confusing but the axle+nut fit into dropouts that are designed to Shimano's standards. Their QR lever comes with it's own nut. So the dropout of the frame is the Shimano 142 standard, but you do have to use the entire axle kit.
  30. #430
    I still dont understand this fully, obviously I have been using mine incorrectly because my QR didn't come with the nut, but I have been fully unaware its been incorrectly set up because it has worked fine for months?
    Pivot mach 6!
  31. #431
    Jan 2009
    Quote Originally Posted by Joel RW View Post
    That is very strange. Where did you buy the axle? It should have come with the nut. Shimano's QR nut has about 12 channels that line up with the set screw in the drop out, with those different channels you get to choose where the lever has been correctly tightened. It is integral to their design and works exactly like the Shimano partnered Fox 15mm axle.
    Here is an example of what should have been included with your axle.
    Our dropout nut only has one rotational position and it is intended to ONLY be used with our bolt on axle and the corresponding steel lock screw. It does not let you set the position that the QR lever closes.
  32. #432
    Propr
    I have this same one and it works great. But yeah, you remove the factory stuff and put in the new shimamo package.
    10 TransAM SS
    S-Works M2
    Nomad3cc xx1 - Sold
  33. #433
    Ok, I understand now, thanks. My axle kit came with a channelled-nut, I see how it should work. Too late for me, because I've returned the axle for a refund now
  34. #434
    Jan 2009
    Oh well. On a plus side, our bolt on axle is lighter weight than the Shimano QR. It's a weight savings thing for you...
  35. #435
    Heheh! Awesome
  36. #436
    Quote Originally Posted by LeeL View Post
    Mack Ridge was so nice I had to do it again
    Some more Moab
    Killa!! i like!
    ride.
  37. #437
    Quote Originally Posted by Demodude View Post
    I just started to consider a 29er about a week and a half ago. I come from a DH/FR/AM background and really liked all the numbers surrounding this bike. I can confirm that the Bandit is pure awesomeness. The only 29er I've ever rode was about 7 years ago- a Canyon rigid SS. So looking to reduce my stable I'm selling my 2011 Enduro and P2 street bike- enter the Bandit. I looked for a longer travel 29er with trail bike geometry and arrived at this bike.
    The only changes I've made are the Shimano XT brakes and a Command post. Frame size is a large, - weight is around 32lbs
    Oh, mind the crazy mess, I work at a dental lab
    hello, nice ride !!
    can you tell me how long i need minimum the rear brake cable?
    thank you! with the standard cable routing...
    ride.
  38. #438
    hello, is tte 12x142mm axle incl. with the bandit 29 frame?
    thank you.
    ride.
  39. #439
    rider
    Jan 2005
    Quote Originally Posted by 8664 View Post
    thank you.
    Yes it is included. Not a QR but nice and stout.
    Abandoned the 26" wheel in May '03
  40. #440
    Quote Originally Posted by 29erchico View Post
    thanks
    hope that works with my ringle charger rear wheel and the new conversion kit from ringle 12x142mm caps
    ride.
  41. #441
    rider
    Jan 2005
    thanks
    Should not be an issue. The only difference in the two 142x 12mm standards is the way the thru axle interfaces with the dropouts.
  42. #442
    Reputation: jmontroy's Avatar
    If any of you wagon-wheel riders are looking to unload an XL Bandit frame give me a holler!!
  43. #443
    on a routine expedition
    Reputation: Marshall Willanholly's Avatar
    I've been loving my Bandit29 for enduro racing this summer. I did a couple rounds of the Oregon Enduro Series and last weekend raced the Capitol Forest Enduro in Washington. I'm just bummed the season is over. Can't wait until next year!
  44. #444
    Reputation: italiancarbs's Avatar
    Dec 2008
    Dolomiti - Italy
    my bandit has been breathing clean air this past weekend
    Attached Thumbnails Attached Thumbnails Transition Bandit 29 photo thread-sdc12148.jpg
  45. #445
    Jun 2010
    Does anyone know where I can snag a large Frame or complete?
  46. #446
    Quote Originally Posted by atekt View Post
    if you have trouble finding a new large frame/complete, there are a few sweet L B29 builds for sale on pinkbike at the moment
  47. #447
    Any chance you could give us some feedback on how the bike handles at Swinley?
    It's my local spot and l'm interested in how it feels with the constant small ups and downs, standing up stomping etc...Have a covert and find it a bit of a chore round there, so much so that I'm currently on a rigid Cotic Solaris which flys round. Going to sell the covert and get a 29er full suss but didn't want to make the same mistake again and over bike myself with too much travel.
    Any advice much appreciated. Surrey hills is my other local.
  48. #448
    Quote Originally Posted by tim.johnston View Post
    It handles Swinley just fine Flows with ease around the, uh, flowy bits. Fast as you like around the bermy bits. Does constantly beg to be thrown off stuff, though
    Think it really depends what you're used to, I've been riding a long time and gravitate towards bikes that you can rag downhill. My other 29er is a carbon Tallboy. Of the two, I'd take the Bandit to Swinley, unless I was going for a solo blast (read: training). Taking the Bandit always makes for a fun ride, I love this bike!!!
    Surrey Hills - Judges Seat drop and Two-Headed Dog are perfectly do-able on the B29
    I'm not really a stand-and-stomp kinda rider (ex- time triallist), but can tell you that the bike sprints plenty well enough. I haven't ridden a Covert, but my last 26er XC bike was a Knolly Delerium-T. If you want to have a ride on my Bandit 29, PM me and we can maybe set something up? How tall are you?
    Meanwhile, I'm just back from a road trip to Scotland. In the last week, I've ridden.....
    Mon - Mabie
    Tue - Ae Forest
    Wed - Kirroughtree
    Thu - Dalbeattie + Newcastleton
    Fri - Glentress
    Sat - Innerleithen + Glentress
    Sun - Whinlatter
    ...and the Bandit rode faultlessly. Sadly, a rock strike at Glentress has dented the downtube! Noooooo!!!
    Hey, Transition guys - any chance of a "crash replacement" for a white Covert 29 please?
  49. #449
    Hey, thanks for all the detail, you've made my mind up!
    Just needed to hear from someone local who can vouch for its sprinting capabilities. I too prefer a playful bike over a speed machine any day but the covert was way too much for me and I tended to wallow around a bit on it. Great fun further afield in Wales though.
    I have a demo booked for tomorrow and the chance to get one of the last 2012 completes in medium. I'm 5'10 so right on the edge of a large, but that would mean waiting for the 2013. I'm sure with a few tweaks it will fit. I'll find out tomorrow in any case.
    Thanks for the offer of a test ride, if all goes well I may see you on the trails on a green one!
  50. #450
    No problem, Tim. We have a regular sprint point at Swinley, it's the drain cover at the top of the long fire-road near the dirt-jump gulley, so I can vouch for it's abilities.
    My XL may've been a bit big, then! I'll look out for you.... Good luck with the test ride tomorrow
  51. #451
    Reputation: almogaver's Avatar
    Here is mine
    Great bike but the freehub broke after two months. Transition sent me a replacement free of charge immediately but I am sure it will break again because the inner walls of the freehub are too thin. Perhaps Hope or Chris King will be more suitable to my riding (and way more expensive )
    Am I the only one having this problem?
    Ascendit omne descendat
  52. #452
    awesome bike!
    But no.... I have not seen that problem before, hopefully just some bad luck!
    Pivot mach 6!
  53. #453
    May 2005
    Has anyone had a Fox 120mm fork on the front on a B29....
  54. #454
    They will soon enough...
    Pivot mach 6!
  55. #455
    May 2005
    That is a 2012 B29r Joel RW....
  56. #456
    Reputation: jsg04's Avatar
    Still really enjoying the bike. Ditched the 2x10 and put a chain guide on it.
  57. #457
    So sweet! Like the bikes
  58. #458
  59. #459
    That is awesome, did you do it yourself?
    Stripped and clearcoated?
    Pivot mach 6!
  60. #460
    +1 nice looking bike, I've thought about doing the same to mine once the paint starts scuffing up...called around and apparently there's a place in town (Toronto) that'll strip the frame for $60 via chemical dip, not too bad at all...
  61. #461
    May 2005
    Can the 2012 Bandit Two9 run an external bottom headset cup? .....looking at plugging in the Fox F29 120mm.....
  62. #462
    delete-
    Pivot mach 6!
  63. #463
    Reputation: in the trees's Avatar
    Mar 2005
    The Bandit29 uses a Zero Stack headset top and bottom. I'm not sure that they is a manufacturer making an external cup lower headset for 56mm diameters.
  64. #464
    just ordered my B29 '12 frame today (pewter, M)
    pics are coming soon
    it will replace my Covert '10
  65. #465
    Bandit 29 FTW!!!
    Reputation: In-Yo-Grill's Avatar
    Can't believe I've had my bike for two weeks and haven't added it to this thread.
    Here she is...
    Let's make like a Bike and get the Huck outta here...
  66. #466
    Feb 2005
    Nice build! Question for you. How many spacers did you have to use on the drive side for your XT crank and BB to work?
    I tried mine during the build but even with one spacer on the drive side it was way to close for comfort with the chainstay. I then installed the sram BB and crank and that had more space away from the chainstay.
  67. #467
    In case anyone is interested, I have a Medium Bandit 29 for sale in the Classifieds section..
    Transition Bandit 29 - Buy and Sell and Review Mountain Bikes and Accessories
  68. #468
    Bandit 29 FTW!!!
    Quote Originally Posted by trailbrain View Post
    I took a quick look and I only had to use one spacer for the XT Cranks.
  69. #469
    140 Reba + 1.5' CC Angle Set.
    Attached Thumbnails Attached Thumbnails Transition Bandit 29 photo thread-img_2168-medium-.jpg
  70. #470
    RYD W/ FLO
    Quote Originally Posted by esku View Post
    Sharp! Diggin the '13 colors (on the bandit anyways)
  71. #471
    Feb 2005
    2013 Bandi 29 XL
    Reverb post
    Fox 34 at 130mm
    XT brakes
    and the rest is build kit that came with it. Still need to cutdown some hoses and maybe a Stans/Hadley wheelset next year. I gotta say that after 3 rides I am thoroughly impressed. The best way to descride the ride is FUN! I don't know what magic ingredient you put in the mixing bowl at Transition, but this bike is dialed.
    It loves rocks!
  72. #472
    now ready to ride.
    Fox Foat 34/140
    12.7 kg
  73. #473
    Maiden Voyage
    Maiden Voyage on my 2013 Bandit 29. Lot's of WOW'S! Woohoo's! and Yehaw's!
    Attached Thumbnails Attached Thumbnails Transition Bandit 29 photo thread-securedownload.jpeg
  74. #474
    rider
    Jan 2005
    Quote Originally Posted by cgcharlie View Post
    Is that a proto Xfusion fork?
  75. #475
    Bandit 29 FTW!!!
    Quote Originally Posted by flowbike View Post
    now ready to ride.
    Fox Foat 34/140
    12.7 kg
    Very nice...what are the specs?
  76. #476
    No it's a Slide 29 with a 15mm thru-Axle. Set at 120.
  77. #477
    Dec 2009
    X-Fusion is the best fork on the market..Hands down
  78. #478
    Quote Originally Posted by In-Yo-Grill View Post
    look at the pictures
    Bandit 29, 2012, M
    Fox Float 34 O/B 150
    Sickpack headset
    wheelset from actionsports.de with blue Chosen-Hubs, Pacenti TL28, Sapim D-lights
    Conti Mountain King 2.2 racesport tubeless
    Brakes: Magura MT6 with Shimano XT-Levers, Storm SL Discs 180/160
    Reverb, SQ-Lab 611 active saddle, seatclamp from superstar
    Zephir stem (50mm) from superstar with blue faceplate
    CB Cobalt 11 lowriser handlebar (cutted to 745mm)
    Excel Grips form superstar
    2x9 gears
    Shimano XTR Cassette 11-34
    Truvativ Noir Crank /36/22 with X.O Carbon bash, blue bolts
    X9 rear, SLX front
    X9 Trigger
    Superstar Ultra Mag Ti pedals
  79. #479
    Goes to 11
    Reputation: TheNewOriginal's Avatar
    2013 White Bandit
    Size L
    Reba 120mm
    1*9 setup (for now)
    Pacenti TL28 on Hope
    and a Reverb post..
    30lb and ready to ROCK
    Attached Thumbnails Attached Thumbnails Transition Bandit 29 photo thread-bandit5.jpg
    Roads? Where we're going we don't need roads..
  80. #480
    Cannonball!
    Reputation: coiler-d's Avatar
    Sep 2004
    Quote Originally Posted by TheNewOriginal View Post
    Size L
    Reba 120mm
    1*9 setup (for now)
    and a Reverb post..
    Seems heavier than I would have thought, for such a light build. Looks awesome!
  81. #481
    Pic from early summer I came across again! A muddy good time that day. I remember it well because I came face to face with a big black bear while by myself in an area I didn't know.
  82. #482
    Quote Originally Posted by LostBoyScout View Post
    Haha you always take great shots, do you ride mud often and does it take a toll on your reverb?
    Pivot mach 6!
  83. #483
    I ride year round (though less in winter) and Vancouver winters are pretty muddy! This is the second winter the bike has seen and (knock on wood) the Reverb has required zero maintenance and works as well as new.
    Thanks on the photo quality... I have a decent camera and enjoy using it
  84. #484
    Dec 2005
    My new XL Bandit. Can't wait for the first ride....
    <a href="http://fotos.mtb-news.de/p/1298488"><img src="http://fstatic0.mtb-news.de/f/kd/26/kd26hylydyxn/thumb_IMG_1205.JPG?0"></a>
  85. #485
    the 14.2 kg i've seen in another forum
    what about embedding a smaller pic, even if the frame is XL?
  86. #486
    Cannonball!
    Sep 2004
    Can someone with 2013 B29 (with a 120mm fork) measure your static bottom bracket height? Trying to decide whether I can get away with an angled headset or not. Thanks.
  87. #487
    Cannonball!
    Sep 2004
    So stoked on this thing!
  88. #488
    Cannonball!
    Sep 2004
  89. #489
    Any particular reason you're not using the dropper post cable routing?
  90. #490
    Reputation: titusquasi's Avatar
    Quote Originally Posted by coiler-d View Post
    Wow...I REALLY like that blue. Did you do an angleset and if so, how much?
  91. #491
    Cannonball!
    Sep 2004
    -1.5 degrees
  92. #492
    Angleset 1.5'
    Attached Thumbnails Attached Thumbnails Transition Bandit 29 photo thread-img_2169-medium-.jpg
  93. #493
    RYD W/ FLO
    XX1 looks proper on the B29. Nice ride/build!
  94. #494
    Cannonball!
    Sep 2004
    Thanks, I am really happy with this thing so far. It turned out just as I hoped, light enough to do some casually competitive racing, yet still a blast as a trail bike!
  95. #495
    Reputation: bettes's Avatar
    Just finished my build... What do you think?
    Medium 2013 stealth black/grey
    Revelation RCT3 140 20mm
    FSA Cheapo headset (CK on order)
    Renthal duo stem
    Element nickel-wide bars cut to 730mm
    yellow esi grips
    Reverb 125
    fizik antares carbon (cadel evans edition)
    Easton Haven wheels
    Schwalbe Rocket ron 2.25 setup with stans
    X9 shifter
    X9 type 2 RD medium
    1070 11-36 Cassette
    1071 chain
    s2210 (X.0) crank with 33T E13 guide ring
    E13 TRS+ chainguide (only the top part for trail riding)
    Formula the one brakes (180-160)
    CB mallet pedals
    Weight on the bathroom scales 12,4 kg... That is quite a bit less than what I was hoping for!
    Can't wait to take her out!
  96. #496
    Reputation: rideut's Avatar
    Dec 2008
    I think it's great!
  97. #497
    Nice touch with the yellow components. I like it a lot!!
    konahonzo
  98. #498
    this thread needs more love...my new '13 build kit 2. Sorry for crappy phone pic.
    Attached Thumbnails Attached Thumbnails Transition Bandit 29 photo thread-2013-05-10-13.50.15.jpg
  99. #499
    just some small updates: Tires, LEV, Pedals, Discs, Stem. The stem on the picture is not mounted anymore.
    next updates: Pike, Angleset, 66sick el Flaco. maybe 1x9 instead of 2x9
  100. #500
    AOK
    AOK is offline
    Reputation: AOK's Avatar
    New, shiny, and clean...
    Took a few pictures of my new B29 before the inaugural ride today.
  1. Looking for a great photo of big mountain singletrack (no rider)
    By stalking_horse in forum Photography for mountain bikers
    Last Post: 01-11-2012, 08:47 AM
  2. Searching a thread for OBVIOUS words = no results
    By Loonytik in forum Site Feedback/Issues
    Last Post: 01-10-2012, 09:09 PM
