Page 10 of 13 FirstFirst ... 678910111213 LastLast
Results 451 to 500 of 612
  1. #451
    Reputation: almogaver's Avatar
    Here is mine
    Great bike but the freehub broke after two months. Transition sent me a replacement free of charge immediately but I am sure it will break again because the inner walls of the freehub are too thin. Perhaps Hope or Chris King will be more suitable to my riding (and way more expensive )
    Am I the only one having this problem?
    Ascendit omne descendat
  2. #452
    Reputation: Joel RW's Avatar
    awesome bike!
    But no.... I have not seen that problem before, hopefully just some bad luck!
    Pivot mach 6!
  3. #453
    May 2005
    Has anyone had a Fox 120mm fork on the front on a B29....
  4. #454
    They will soon enough...
    Pivot mach 6!
  5. #455
    May 2005
    Quote Originally Posted by Joel RW View Post
    That is a 2012 B29r Joel RW....
  6. #456
    Reputation: jsg04's Avatar
    Still really enjoying the bike. Ditched the 2x10 and put a chain guide on it.
  7. #457
    So sweet! Like the bikes
  8. #458
  9. #459
    That is awesome, did you do it yourself?
    Stripped and clearcoated?
    Pivot mach 6!
  10. #460
    +1 nice looking bike, I've thought about doing the same to mine once the paint starts scuffing up...called around and apparently there's a place in town (Toronto) that'll strip the frame for $60 via chemical dip, not too bad at all...
    ride, eat, sleep, repeat
  11. #461
    May 2005
    Can the 2012 Bandit Two9 run an external bottom headset cup? .....looking at plugging in the Fox F29 120mm.....
  12. #462
    delete-
    Pivot mach 6!
  13. #463
    Reputation: in the trees's Avatar
    Mar 2005
    The Bandit29 uses a Zero Stack headset top and bottom. I'm not sure that they is a manufacturer making an external cup lower headset for 56mm diameters.
  14. #464
    just ordered my B29 '12 frame today (pewter, M)
    pics are coming soon
    it will replace my Covert '10
  15. #465
    Bandit 29 FTW!!!
    Reputation: In-Yo-Grill's Avatar
    Can't believe I've had my bike for two weeks and haven't added it to this thread.
    Here she is...
    Let's make like a Bike and get the Huck outta here...
  16. #466
    Feb 2005
    Nice build! Question for you. How many spacers did you have to use on the drive side for your XT crank and BB to work?
    I tried mine during the build but even with one spacer on the drive side it was way to close for comfort with the chainstay. I then installed the sram BB and crank and that had more space away from the chainstay.
  17. #467
    In case anyone is interested, I have a Medium Bandit 29 for sale in the Classifieds section..
    Transition Bandit 29 - Buy and Sell and Review Mountain Bikes and Accessories
  18. #468
    Bandit 29 FTW!!!
    Quote Originally Posted by trailbrain View Post
    I took a quick look and I only had to use one spacer for the XT Cranks.
  19. #469
    140 Reba + 1.5' CC Angle Set.
    Attached Thumbnails Attached Thumbnails Transition Bandit 29 photo thread-img_2168-medium-.jpg
  20. #470
    RYD W/ FLO
    Quote Originally Posted by esku View Post
    Sharp! Diggin the '13 colors (on the bandit anyways)
  21. #471
    Feb 2005
    2013 Bandi 29 XL
    Reverb post
    Fox 34 at 130mm
    XT brakes
    and the rest is build kit that came with it. Still need to cutdown some hoses and maybe a Stans/Hadley wheelset next year. I gotta say that after 3 rides I am thoroughly impressed. The best way to descride the ride is FUN! I don't know what magic ingredient you put in the mixing bowl at Transition, but this bike is dialed.
    It loves rocks!
  22. #472
    now ready to ride.
    Fox Foat 34/140
    12.7 kg
  23. #473
    Maiden Voyage
    Maiden Voyage on my 2013 Bandit 29. Lot's of WOW'S! Woohoo's! and Yehaw's!
    Attached Thumbnails Attached Thumbnails Transition Bandit 29 photo thread-securedownload.jpeg
  24. #474
    rider
    Jan 2005
    Quote Originally Posted by cgcharlie View Post
    Is that a proto Xfusion fork?
    Abandoned the 26" wheel in May '03
  25. #475
    Bandit 29 FTW!!!
    Quote Originally Posted by flowbike View Post
    now ready to ride.
    Fox Foat 34/140
    12.7 kg
    Very nice...what are the specs?
  26. #476
    Quote Originally Posted by 29erchico View Post
    No it's a Slide 29 with a 15mm thru-Axle. Set at 120.
  27. #477
    Dec 2009
    X-Fusion is the best fork on the market..Hands down
  28. #478
    Quote Originally Posted by In-Yo-Grill View Post
    look at the pictures
    Bandit 29, 2012, M
    Fox Float 34 O/B 150
    Sickpack headset
    wheelset from actionsports.de with blue Chosen-Hubs, Pacenti TL28, Sapim D-lights
    Conti Mountain King 2.2 racesport tubeless
    Brakes: Magura MT6 with Shimano XT-Levers, Storm SL Discs 180/160
    Reverb, SQ-Lab 611 active saddle, seatclamp from superstar
    Zephir stem (50mm) from superstar with blue faceplate
    CB Cobalt 11 lowriser handlebar (cutted to 745mm)
    Excel Grips form superstar
    2x9 gears
    Shimano XTR Cassette 11-34
    Truvativ Noir Crank /36/22 with X.O Carbon bash, blue bolts
    X9 rear, SLX front
    X9 Trigger
    Superstar Ultra Mag Ti pedals
  29. #479
    Goes to 11
    Reputation: TheNewOriginal's Avatar
    2013 White Bandit
    Size L
    Reba 120mm
    1*9 setup (for now)
    Pacenti TL28 on Hope
    and a Reverb post..
    30lb and ready to ROCK
    Attached Thumbnails Attached Thumbnails Transition Bandit 29 photo thread-bandit5.jpg
    Roads? Where we're going we don't need roads..
  30. #480
    Cannonball!
    Reputation: coiler-d's Avatar
    Sep 2004
    Quote Originally Posted by TheNewOriginal View Post
    Size L
    Reba 120mm
    1*9 setup (for now)
    and a Reverb post..
    Seems heavier than I would have thought, for such a light build. Looks awesome!
  31. #481
    Pic from early summer I came across again! A muddy good time that day. I remember it well because I came face to face with a big black bear while by myself in an area I didn't know.
  32. #482
    Quote Originally Posted by LostBoyScout View Post
    Haha you always take great shots, do you ride mud often and does it take a toll on your reverb?
    Pivot mach 6!
  33. #483
    I ride year round (though less in winter) and Vancouver winters are pretty muddy! This is the second winter the bike has seen and (knock on wood) the Reverb has required zero maintenance and works as well as new.
    Thanks on the photo quality... I have a decent camera and enjoy using it
  34. #484
    Dec 2005
    My new XL Bandit. Can't wait for the first ride....
    <a href="http://fotos.mtb-news.de/p/1298488"><img src="http://fstatic0.mtb-news.de/f/kd/26/kd26hylydyxn/thumb_IMG_1205.JPG?0"></a>
  35. #485
    the 14.2 kg i've seen in another forum
    what about embedding a smaller pic, even if the frame is XL?
  36. #486
    Cannonball!
    Sep 2004
    Can someone with 2013 B29 (with a 120mm fork) measure your static bottom bracket height? Trying to decide whether I can get away with an angled headset or not. Thanks.
  37. #487
    Cannonball!
    Sep 2004
    So stoked on this thing!
  38. #488
    Cannonball!
    Sep 2004
  39. #489
    Any particular reason you're not using the dropper post cable routing?
  40. #490
    Reputation: titusquasi's Avatar
    Quote Originally Posted by coiler-d View Post
    Wow...I REALLY like that blue. Did you do an angleset and if so, how much?
  41. #491
    Cannonball!
    Sep 2004
    -1.5 degrees
  42. #492
    Angleset 1.5'
    Attached Thumbnails Attached Thumbnails Transition Bandit 29 photo thread-img_2169-medium-.jpg
  43. #493
    RYD W/ FLO
    XX1 looks proper on the B29. Nice ride/build!
  44. #494
    Cannonball!
    Sep 2004
    Thanks, I am really happy with this thing so far. It turned out just as I hoped, light enough to do some casually competitive racing, yet still a blast as a trail bike!
  45. #495
    Reputation: bettes's Avatar
    Just finished my build... What do you think?
    Medium 2013 stealth black/grey
    Revelation RCT3 140 20mm
    FSA Cheapo headset (CK on order)
    Renthal duo stem
    Element nickel-wide bars cut to 730mm
    yellow esi grips
    Reverb 125
    fizik antares carbon (cadel evans edition)
    Easton Haven wheels
    Schwalbe Rocket ron 2.25 setup with stans
    X9 shifter
    X9 type 2 RD medium
    1070 11-36 Cassette
    1071 chain
    s2210 (X.0) crank with 33T E13 guide ring
    E13 TRS+ chainguide (only the top part for trail riding)
    Formula the one brakes (180-160)
    CB mallet pedals
    Weight on the bathroom scales 12,4 kg... That is quite a bit less than what I was hoping for!
    Can't wait to take her out!
  46. #496
    Reputation: rideut's Avatar
    Dec 2008
    I think it's great!
  47. #497
    Reputation: eurospek's Avatar
    Nice touch with the yellow components. I like it a lot!!
    konahonzo
  48. #498
    this thread needs more love...my new '13 build kit 2. Sorry for crappy phone pic.
    Attached Thumbnails Attached Thumbnails Transition Bandit 29 photo thread-2013-05-10-13.50.15.jpg
  49. #499
    just some small updates: Tires, LEV, Pedals, Discs, Stem. The stem on the picture is not mounted anymore.
    next updates: Pike, Angleset, 66sick el Flaco. maybe 1x9 instead of 2x9
  50. #500
    AOK
    AOK is offline
    Reputation: AOK's Avatar
    New, shiny, and clean...
    Took a few pictures of my new B29 before the inaugural ride today.
  1. Looking for a great photo of big mountain singletrack (no rider)
    By stalking_horse in forum Photography for mountain bikers
    Last Post: 01-11-2012, 07:47 AM
  2. Searching a thread for OBVIOUS words = no results
    By Loonytik in forum Site Feedback/Issues
    Last Post: 01-10-2012, 08:09 PM
