Results 1 to 5 of 5
    Really I am that slow
    Reputation: SlowerThenSnot's Avatar
    Trans-AM29er build idea
    Thinking about building one single speed and using a Surly Kranpus fork and 29er+ tire and 50mm rim on the front of it, whats this biggest tire/rim you can make fit in the rear triangle of this frame?
    link to the fork specs: Krampus Fork | Parts | Surly Bikes
    rim: Rabbit Hole | Parts | Surly Bikes
    tire: Knard 29 x 3 | Parts | Surly Bikes
    Thanks for an beta that could be shared
    Read my BLOG!
    just a guy who loves bikes and exploring
    rider
    Jan 2005
    I'm on the road at the moment, but when I get home next week, I can mount up a WTB Dissent 2.5x29 and a Minion DHF 2.9x25 on my KH Uni rim with an internal width of 31mm. At that point I can measure how much room is left with each tire on my 2013 TA29 and I can also give you a total outside width for each tire. What psi do you want the tires inflated to? That, or get your hands on a Knard and send it to me to test fit and measure it for you on my KH rim.
    I do know that a Dissent 2.5 at 24psi on a MTX 33 rim, 26mm internal, fits fine in the back but I never measured the clearance.
    I have been thinking about running a Knard rigid up front on my TA29 also...
    Abandoned the 26" wheel in May '03
    Cool thanks for checking that out! =)
    Read my BLOG!
    Reputation: Jstews's Avatar
    Oct 2011
    I think Krampus fork with RH/knard will be a great rigid for option for frames built for 100+mm travel forks.
    i was thinking of this idea just last night! stripped down my ta29 to build a fully, and have slowly been piecing a build kit together. but i'm still missing a front wheel, and feel like this might be fun project. will be interested in your build and impressions if you go this route sts. have you priced it out?
    edit: doing a bit of digging and i found at least one reviewer has tried a krampus front end... and there's a guy selling a front wheel and tire in eastern canada
  1. Replies: 14
    Last Post: 12-20-2012, 08:27 PM
  2. trans am ss 150mm 26er build advice.
    By 5power in forum Transition Bikes
    Last Post: 12-19-2012, 10:51 PM
  3. Trail idea, first build. help me get it right.
    By RobinGB in forum Trail Building and Advocacy
    Last Post: 12-01-2012, 10:49 PM
  4. Fun build idea?
    By Crashman1 in forum General Discussion
    Last Post: 07-21-2012, 12:44 AM
  5. Transition trans am build
    By AMCAT in forum All Mountain
    Last Post: 03-28-2011, 08:02 PM
