Page 15 of 22 FirstFirst ... 5 11 12 13 14 15 16 17 18 19 ... LastLast
Results 351 to 375 of 530
  1. #351
    riding?
    Quote Originally Posted by VTSession View Post
    So as the original starter of this thread, I felt it appropriate to order aTransAM 29er.
    did you get your transAM running? how you liking it? is it as much "fun" as the 26in version?
  2. #352
    Anyone stick a 140 travel fork on their bike? If so how does it climb/descend/overall ride? Im thinking about throwing on the new xfusion trace.
    X Fusion Shox - RL2 DLA
  3. #353
    Reputation: WarPigs's Avatar
    Dec 2005
    Quote Originally Posted by markd0nalds View Post
    mine is with a 140mm Micro Ti, no problems descending, but climbing is a bit hard, but I am on SS, 32/23. not sure if I run gears, it might be easier. planning to convert to 1x9
    So Where's the Trans AM 29er?
    Si Vis Pacem, Para Bellum
  4. #354
    i'm running a 140mm fork up front on my 2012 TransAM 29
    I'm running a 140mm RS Revelation with a reversed 60mm Funn stem, very wide low rise Azonic bars and 2x9 setup. My 2012 TransAm 29 rides great in all terrain with a 140mm up front and it feels very confident inspiring down the rocky steeps. Now I'm not sure how it would ride with the new 2013 frame.
  5. #355
    Feb 2007
    140
    markd0nalds,
    I am running a fox 140 on the front and it feels amazing on the descent and climbs very well , zero wandering even on steep climbs. I have the 2013 frame and it has been run SS for a few rides but now has a 1x10 set up that I have yet to try out . I will post up tomorrow and let you know if the front end stays down without running SS .
    I had a SC tallboy LTc and decided to swap it out for a couple of new steel frames and I have zero regrets for going this route . I built up the TA 29er now with gears and have a SS rigid soma juice (2013) that I just built up as well . The TA 29 is a very good frame , the steel feels really good even on braking bumps , rocky sections and roots .
    Scab
  6. #356
    i picked up a used 2012 frame in pewter just before xmas. building a set of wheels (hopes and tl28s) and waiting on a fork, hoping to have it built up and hit the trails soon. i've been riding my chromag samurai for the past few months, and recently can't help but feel that, while still a fun ride, a 26" hardtail is probably the least efficient option currently available for wet rides on the lower trails of the north shore. hoping the ta doesn't give up too much in the fun department, or else i'll probably go back to (suffering on) the chromag
    Attached Thumbnails Attached Thumbnails So Where's the Trans AM 29er?-ta29.jpg
  7. #357
    What size is that Frame??
  8. #358
    large/19.5"
  9. #359
    suspension cowboy
    Feb 2007
    is anyone riding a transam 29 with an internal gearhub (rohloff)?
    thanks
  10. #360
    Aug 2005
    Well I have a brand new TransAM 29er frame sitting in my basement shop waiting for a few final parts. Fox Float 34 will be here tomorrow, Reverb post will be here Tuesday and E.13 LG+ chain guide will arrive next week. Wheels, drivetrain, everything else is ready to go. Can't wait to ride this friggin' thing.
    2016 Santa Cruz Hightower 29er
    2015 Trek Farley 26fat
    2013 Transition TransAM 29er
  11. #361
    singlespeed stephen
    2012 TransAM 29er
    Traded my TransAM 26 for this and am building it up. Psyched to ride it but the trails are flooded! It's gonna be singlespeed but I don't have money to order the horizontal dropouts so I'll be using a chain tensioner for now Terrible pic but you get the idea...
    Attached Thumbnails Attached Thumbnails So Where's the Trans AM 29er?-565569_3683629229088_1358230561_n.jpg
    2012 Transition TransAM
    2012 Surly Cross Check
    2010 Rocky Mountain Flow DJ
  12. #362
    Aug 2005
    Well my 2013 TransAM 29er is done. The last parts were chainguide and grips and those arrived yesterday. Still debating if I want to bother to cut the Reverb hose.
    I want to ride this thing but its 15 degrees outside and the trails are a bit snowy. Damn it!
    I quick note for TransAM users looking to use a chain guide, MRP G2 chainguide will NOT fit the frame. The back plate hits the chainstays and won't sit on the tab properly. The e13 I'm using has smaller back plate and fits with some spacers.
  13. #363
    Reputation: eurospek's Avatar
    ^ Is your Reverb cable NOT contacting the tire when slammed? I have mine routed around the post for this exact reason. And the 2013 graphics are a huge improvement over old TransAMs.
    konahonzo
  14. #364
    Aug 2005
    Quote Originally Posted by eurospek View Post
    It's off the side of tire, but I haven't even ridden it yet to see if it hits the tire or rubs the frame. I'm hesitant to cut the hose, because I don't want to bleed the Reverb.
  15. #365
    Reputation: in the trees's Avatar
    Mar 2005
    Great build, VTSession!
    Tell us more about the interference with the MRP G2.
  16. #366
    Aug 2005
    Quote Originally Posted by in the trees View Post
    Thanks! I'm stoked to get it dirty.
    I originally had this MRP G2 guide and if you look at the back plate its got a much bigger diameter so the bottom left of the back plate hits the chain stay before it contacts the tab. You can use spacers but it will push the chain guide way too far out.
    This e13 TRS+ has a much lower profile back plate and only needs a 2.5 mm spacer (that comes in the box) to clear the chain stay.
    The e.13 is a perfectly functional guide but it lacks the bash guard of the MRP. Oh well.
  17. #367
    Reputation: ruppguts's Avatar
    @VTsession you can shorten the Reverb hose without rebleeding. Reverb hose shorten - YouTube
    tip: In my experience, it's easier to twist the remote, like you're screwing it into the line, then to turn the line back and forth like they do in the video.
    Binary • Transition Bikes • Demon Dirt •
  18. #368
    Jan 2013
    Has anyone raced xc on a transam or ran it with a 100mm fork. I'm keen to do some racing and have a frame waiting to be built up. Just wondering if i should move it on and get something more racy, i like the transam's classic looks and the fact it has iscg tabs but the geo and weight may make it unsuitable.
  19. #369
    Aug 2005
    Quote Originally Posted by ruppguts View Post
    I saw that video. It seems like some people need to rebleed after shortening the hose and some don't. Is there some trick to having to not rebleed it?
    I did reroute the cable since that pic was taken so it is through the seat stay yoke instead of off to the side. I dob't think I'm going to shorten it unless it becomes a issue.
    Edit: One more thing about the TransAM that hasn't been mentioned yet, the back end easily fits a Continental 2.4 Trail King. 2.5s look to be doable as well.
  20. #370
    Quote Originally Posted by boomforeal View Post
    final major piece of the build (2013 marz 44 mirco ti TA) showed up yesterday and after staring at it for weeks i'm finally putting this thing together. looks like i need a 31.8 low clamp top pull front derailleur, correct? i think that's the last piece, and if i can get it sorted out in the next day or two i'll have 3 new bikes ready for the trails this weekend (wtf)!
    edit: i think i'm in love
  21. #371
    twinsdad
    Got mine
    Here's Mine...2012 with a Fox Talas 34 Kashima...First ride will be this Sunday...
    Attached Thumbnails Attached Thumbnails So Where's the Trans AM 29er?-rsz_xanax_001.jpg
  22. #372
    The Tyranical Teabagger
    Reputation: cyrjm's Avatar
    Wow...it's been a while since I've been on this thread. Stoked to see so many people on this bike. I've been running my TA geared and want to convert it to SS for a few months. I'm running the DT Swiss RWS 10x135 thrubolt and wondering if that will be sufficient enough to maintain the wheel position in the horizontal dropouts or are there chain tugs that people are using?
    I like bikes.
    2012 Transition TransAm 29er
    2010 Rigid Salsa Selma SS
    2015 Transition Smuggler
    2015 Cannondale Scalpel
  23. #373
    May 2013
    I was really suprised it was a bandit.
  24. #374
    I'll figure out how to nuke this post in a minute, i guess i posted wrong window, I need to narrow down the old tab count
    Attached Thumbnails Attached Thumbnails So Where's the Trans AM 29er?-038fb14e37ca11e282e022000a1fbc68_7.jpg
  25. #375
    Dec 2005
    Just completed a grueling 55km jamboree on my SS TA bike, in 6 hours. Don't mine the human on the bike.
  1. Trans-WI race VS Trans-WI Adventure Trail
    By FishMan473 in forum Minnesota, Wisconsin
    Last Post: 05-23-2011, 07:03 AM
  2. Replies: 10
    Last Post: 06-04-2010, 02:52 PM
  3. TRANS-IOWA V.2 is 29er Friendly
    By KERKOVEJ in forum 29er Bikes
    Last Post: 10-26-2005, 07:49 PM
  4. colour for 05 v10 trans blue or trans red
    By Yoshimura in forum Santa Cruz
    Last Post: 12-15-2004, 05:50 PM
  5. Replies: 0
    Last Post: 11-07-2004, 04:09 AM
